Old 01-24-2016, 11:59 AM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
My car does not have immobilizer, so I bought a non-immobilizer ECM. I believe all pre 2010 Xd's are non immobilizer.
If your car has immobilizer....I still dont know what exactly has to be done regarding keys. Someone will have to try it, or have the system removed.
Old 01-25-2016, 09:45 PM   #2
ArmstrongRacing
Data doesn't lie
For those of you with a auto transmission: If you use a Xd harness you won't need this step. If you used the Corolla harness pin#57 needs to be moved to #58. This is for the Sl/Slu+ solenoid.
Old 01-25-2016, 10:40 PM   #3
ArmstrongRacing
Data doesn't lie
This is the lock on the main harness connector(C20). You have to pop this grey tab out about 1mm before you can release the pins.
Old 01-25-2016, 10:45 PM   #4
ArmstrongRacing
Data doesn't lie
Next you need to slide a small pin into the pin release hole. Pull on the white #57 wire and wiggle a bit until it slides out.
Old 01-25-2016, 10:54 PM   #5
ArmstrongRacing
Data doesn't lie
Pop out the little rubber seal in pin location #58, and slide the wire in until it clicks. Install the rubber seal back into #57, then push the grey lock tab back in.
FYI: This pin removal/install procedure is the same for the ABS module plug, in case you used a Xd trans with no speed sensor.
Old 01-27-2016, 10:42 PM   #6
ArmstrongRacing
Data doesn't lie
This is the last of the auto trans related wiring. Because the Corolla/Xd have different ground circuits than the Yaris for the Sl solenoid, you need to open the trans harness about 8" from the plug and cut the blue wire at pin #9. Pull the wire out of the harness while still connected to the connector and attatch a eyelet, the ground the wire to the trans case here.
Old 01-27-2016, 10:55 PM   #7
ArmstrongRacing
Data doesn't lie
Now that all the wiring is complete, lets be sure the ECM is happy........yep, time to charge the a/c and take it for a drive...
Old 01-28-2016, 04:14 AM   #8
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
YAAAAAY!
Congrats....
Only reason I am upset is because you have a CamCon that you were going to tune with the 1nz and share a mild tune with me.................
-Derrick-
Old 01-28-2016, 10:40 AM   #9
ArmstrongRacing
Data doesn't lie
Thanks man.
Haha, Im sorry about the tune.....I never had a chance to install the Camcon either, life threw me a lemon and I had to make a batch of oh-so-sweet lemonade!
On a side note.....holy crap this car is a BLAST!
Old 01-28-2016, 11:42 AM   #10
tmontague
tmontague's Avatar
so was the faulty trans ground the reaosn for the previous CEL that was regarding the torque converter?
Old 01-28-2016, 12:14 PM   #11
ArmstrongRacing
Data doesn't lie
It wasnt a faulty ground, just a difference in how the Corolla/xd is wired inside the transmission valvebody...2 wire changes and done.
Old 01-28-2016, 02:11 PM   #12
tmontague
tmontague's Avatar
I see, but that wire you just grounded above was the reason for the torque converter cel?
Old 01-28-2016, 04:03 PM   #13
ArmstrongRacing
Data doesn't lie
That's correct
Old 01-28-2016, 05:42 PM   #14
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Why, oh why, are you holding out on the first start and test drive vid!
Old 01-28-2016, 11:21 PM   #15
ArmstrongRacing
Data doesn't lie
Ive edited the videos together up to this point, I need to do a test drive video along with some footage of this weekends autocross.
Old 01-29-2016, 09:50 AM   #16
aspro
Im curious to see your time differences in autocross between the 1nz and 2zr... Ill be watching this closely. Good job btw, i bet a lot of people have been putting diesel fuel in there yaris' to justify an engine swap... Or maybe thats just me. :p
TRD sway bar, h&r coilovers, tanabe strut tower bar, konig feather, bfg sport comp 2, MI intake manifold, aem cai, dc header, trd catback, MI crank pulley, trd short shift kit, phillips hid kit, morimoto led fogs, parrot navi indash, alpine 6.5 speakers, alpine amp, alpine reverse camera, led interior lights, thule roof racks, netz badges...
aspro is offline   Reply With Quote
Old 01-29-2016, 11:15 AM   #17
tmontague
tmontague's Avatar
Old 01-29-2016, 01:15 PM   #18
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I wonder...is there a big weight difference between the 2 engines?
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog
invader166 is offline   Reply With Quote
unusual engine swap CoryM Performance Modifications 26 10-09-2015 12:17 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
Scion/Yaris engine swap mrrock Performance Modifications 1 03-02-2011 06:56 PM
