02-20-2016, 10:08 PM | #1 |
Drives: 2015 yaris le Join Date: Feb 2015
Annoying bushing sounds
I've had this problem for quite a while, and I haven't been able to figure it out. I replaced three out of four of the mounts for the automatic yaris, and the one that is shaped like an L is that one I didn't replace. I may end up putting windshield urethane on the side.
It's noticeable many times when shifting to d and standing still in d. You would hear annoying squeaks and clunks. I checked the control arms, sway bar links, struts etc, nothing I can notice. I was thinking of using my grease needle to grease up everything, but I dont know if it will do good. I was also told to spray engine sealer on the bushings to make them softer. So far I have spend around $200 in mounts and sprayed alot of grease everywhere with no luck. Sometimes though I hear sounds seemingly coming from the heat shields. Where my exhaust manifold was, I had a loose heat-shield. Bolts at the bottom were completely rotten, but I solved it by tying rebar wire to the pipe in the middle to hold it firms. I'm thinking the sound can be from a exhaust hanger. The heatshield are all in place. The ones that fell off, I've fixed. Anyone else have a similar experience? |
02-20-2016, 11:24 PM | #2 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
a squeak/sort of rattle noise I had in my Echo was a water pump getting worse and I eventually replaced.
That said, try to isolate where it is coming from the best you can and then go with that. I have a feeling it may be the last engine mount you didn't replace. The toughest one to replace (at least in an Echo) is the one at the back of the motor which is where your sort of hearing the sound.
No one ever wants to give a Yaris the point by... |
02-21-2016, 08:11 AM | #3 |
did you rule out the spring bolts holding the exhaust to the header?
02-21-2016, 11:17 AM | #4 |
upper front strut rubber mounts isolators , they are on top of the strut i had this odd sound that sounded like from the back so i sprayed flexfilm from the top where the floating caps are and the problem is gone.
02-21-2016, 01:05 PM | #5 |
Gonna suck if it turns out to simply be a $40 donut gasket on the exhaust manifold. I'm with Bluevitz-rs on this one until you can come back and prove the gasket is not shot. If it hasn't been replaced, your car's age says it is past due.
If you're getting the noise while idling in D as you state, then I'm ruling out any suspension components.
02-21-2016, 02:03 PM | #6 |
Ya, if that bushing has never been replaced then it is likely very worn out by now and the spring bolts woul would be very rusted.
Keep in mine with bad engine mounts you typically don't hear much creaking, it's more of a vibration that's the issue
02-21-2016, 09:03 PM | #7 |
I actually did take apart the last bushing. It was fine. I was put some urethane around it and painted it to reinstall it. The three ones that I bought new http://thumbs3.ebaystatic.com/d/l225...Ae24IK6VNg.jpg
I know for sure the one with the circle shape was bad. I took it to a mechanic and he said it needed replacement, and I bought all three on ebay because they were cheaper than anywhere around here. Around $200 canadian with tax and shipping I do hear a creak sometimes when I push the engine back on the mounts by hand, but I have had a really hard time isolating it to anything. It comes and goes.I will have to look into the exhaust donut gasket. Does anyone have the part diagram and number for it? |
02-25-2016, 04:57 PM | #8 |
I check the doughnut gasket today, someone put the mesh gasket which is the wrong one for the front. I bought an aftermarket one for $9 with tax, and had to sand it a little to make it fit properly. After that, seems to be no sound as of now.
Sure beats paying the dealer $50+ for the gasket |
02-25-2016, 05:26 PM | #9 |
Well at least you know 3 of your motor mounts should be good for a long time to come.
Tags |
car, engine, sealer, squeak |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
bushing came off metal sleeve on rearstrut? tein coilover | TRD.RiC | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 03-18-2012 10:14 PM |
alternator bushing JAMMED ! | Siffleu | DIY / Maintenance / Service | 12 | 10-22-2010 10:12 AM |
Engine sounds sick=(! help | Jenn103 | DIY / Maintenance / Service | 7 | 10-01-2010 01:16 PM |
abnormal sounds | Mzsumwun | DIY / Maintenance / Service | 7 | 07-23-2010 01:24 PM |
NEW NST SS Shifter Bushing (AE86) | NonStopTuning | NonStopTuning | 3 | 10-01-2007 03:12 PM |
