![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
Mine is attached to the spoiler, where the hatch water sprayer would be. Mounted high up because it acts as a rear DVR as well, so i get the entire car/people behind me.
Cable runs through the 3rd brake light and around the hatch moulding into the car tucked under the trim panels leading up to the DVR mirror clip on.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
![]() Drives: 2010 Yaris Join Date: Mar 2016
I have a 2010 yaris liftack and this interests me too, but i cant see any existing plstic cut out / spot where the camera would go on my hatch.
is this just a euopean thing for 2010 ? |
#3 | |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
Sorry if this caused any confusion.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#4 | |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
How I'm doing it is by replacing the licence plate light with a special aftermarket bracket that has a back-up camera built into it. (http://www.ebay.com/itm/121697810323...%3AMEBIDX%3AIT) ...and wiring it to an aftermarket head-unit I previously installed. If you want to keep your head-unit though, you can order a rear-view mirror with a built in LCD monitor to replace the original mirror, to have a more factory look. (http://www.ebay.com/itm/Auto-Turn-On...NSaS2v&vxp=mtr)
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
![]() Drives: 2013 Yaris YRS Join Date: Mar 2016
I found the Toyota instructions on how to install the camera online. I posted the link here but got a message about my post requiring mod approval. Sucks to be a noob I suppose.
Posted it this morning, no sign of it yet. |
Can anyone tell me, on the back of the yaris (liftback) what that black plastic/rubber part is on the top center ?
not the antenna, but on the very top of the gate dead center in this picture http://imgur.com/xOdY4wr |
![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
The nozzle for the window washer.
ooooohhhhhh
derp. |
what was up with the brake light tap? I expect to do the same thing in a few days when it gets here
#10 | |
I was not going to buy a solder kit just to do the one job and it was seriously annoying me so just took it to the shop around the corner. |
![]() ![]() Drives: 2014 Yaris L Join Date: Mar 2016
BACKUP CAMERA ALTERNATIVE
This is a wide angle plastic lens that is applied to the back window. It's 8 x 10 and is available at Camping World and Amazon.com . You often see them on motorhomes, vans and mini buses. They help in backing and parallel parking. Even in a Yaris ,the view out the back window isn't all that good if you want to see something short a couple feet behind. The view from my back window to the ground is about 30 ft. , With the lens it's as little as 2 feet. The biggest problem with these lenses are sky reflections on the bottom 3rd of the lens , unless it's applied to a vertical window. So I had to cut that 3rd off , and that helped. The photo shows the lens which is applied with water to the inside of the window. The other shows the view from the inside looking back. The photos are poor quality, but are better when reduced from your computer.Normally , only the gate can be seen. With the lens you can see the driveway before the gate. So you don't have to worry about running into a small kid or pet. This is a much less expensive alternative to a backup camera. The lens is like a convex mirror, so images will look distorted. But you get a much wider view.
Updated a day later. Decided to move the lens to the left side of the rear window, because when I'm driving I want to be able to see cars driving behind me at a distance. This lens is like a convex mirror, showing objects close behind best. Tried using it for parallel parking and it's helpful. Last edited by cparker; 04-25-2016 at 07:10 PM. |
.....and it took some work, but its complete!
![]() ![]() ![]() That being said the location of the map light makes the image a little too low for my liking, but it really does allow me to get up really close when parking. I have yet to do any tinkering to use it for a parallel parking cut The hole for the light needs to be modified, so i can retain my map light function, and I am pulling power from the rear light, as i could not find a proper constant 12+ anywhere without cutting wires and pulling apart bundles. using the rear while going forward is just a novelty anyway. Wires are coming up though the bumper, through the grommet under the plastic cover, into the wire harness area by the driver tail light, and then under the door trim until it hits the front seat... then across and under the center console.
2010 hatchback Fog lights, Kenwood touchscreen, backup camera |
Drives: Volkswagon Join Date: Dec 2016
Hi everyone...i am a new user here. In my case hardest part was feeding the cable from the camera through the door and into the car body. I used a straigntened wire coathanger to fish the wiring around the rear door and through into the roof. From there to the side of the roof and split the wiring to get switched power and earth at the reversing light, and down to the floor for the video feed cable.
| Install 2010 Front Grill in a 2008 Yaris Sedan | dilandias | General Yaris / Vitz Discussion | 3 | 01-21-2016 10:37 PM |
| 2010 yaris ? | bigdoglover | New YARIS Purchase Forum | 0 | 01-01-2016 08:28 AM |
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 02:14 PM |
