![]() ![]() ![]() Drives: yaris 2009 Join Date: Nov 2014
Also check chrisFX channel. In one video he uses this product over a Chrysler I think and he shows the whole procedure
Sent from my iPhone using Tapatalk |
![]() ![]() Drives: 47 2013 yaris l hatchbacks Join Date: Nov 2016
This may sound crazy but I have seen it done and it does work. Buffing the lens with bug repellent that contains DEET bug repellent. I know sounds crazy but it works. Now I cannot say this is going to last as long but it works fast and easy. I have seen it done and 6 months later they still looked great. Maybe combining this with some of the other methods to make the job quicker. Just a thought.
https://youtu.be/9-jtpzzFoNo Here is a demo video. Sent from my SAMSUNG-SM-N900A using Tapatalk |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
If your headlights are only a little hazy than you can use any mildly abrasive compound. That usually means a rubbing or polishing compound meant for car finishes but many people get away with using toothpaste. Toothpaste works because it's a very mild abrasive compound (whiting toothpaste is more abrasive and works better). If you have really yellow or clouded over lenses than you need to go with the wet sanding & polishing route or wet sanding & clear coating. The clear coat method is the best for long term durability as the polished lenses with go back being hazy after about 6 months unless you're very diligent about waxing them every couple months.
You can use any old spray can clear coat that's sold at Walmart, Home Depot, etc (Dupli-Color, Kryon, and Rustoleum are the most common). The most important thing when clear coating is to sand and clean the surface as the clear coat doesn't bond well to a super smooth or dirty surface. A 2K clear coat is the best for ultimate durability but they are generally only sold in auto body supply stores and are much more expensive than the common 1K clear coat. |
![]() Drives: Yaris 2007 Join Date: Nov 2022
Sanded down my headlight and clear coated it. it looks great. It is still slightly more yellow than the brand new headlight on the other side, but its barely noticeable. I even forgot about it completely until I remembered that the other day.
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| WTS: 2008 OEM Headlights, headlight harness, misc parts | wildcard | Items for Sale by private party | 1 | 05-17-2016 08:50 PM |
| diy HID projector w/ halo headlight install | tmontague | DIY / Maintenance / Service | 17 | 02-04-2016 11:34 AM |
| Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal | V70R_Blackbrick | Cosmetic Modifications (Exterior/Interior) | 26 | 11-27-2013 10:14 PM |
| Glassylite Headlight Restoration Kit | TEHxFALLEN V1.2 | Photo-Video-Media Gallery | 1 | 07-03-2010 12:51 AM |
