Old 01-25-2017, 12:13 PM   #1
MugenRep
iQ innovator & researcher
MugenRep's Avatar
Drives: 2012 iQ
Originally Posted by JustDidIt View Post
The downpipe looks large enough 2"-2.5", but I'm looking at upgrading the manifold depending on how much boost i end up running. I'll keep it as is for now...
I meant, make copies, lol. The Scion iQ with it's 1NR-FE has a similar arrangement for most of where our (iQ and Prius) turbo systems would lie and our compression ratios are up there 11.5:1. There are at least 5 guys with budgets of $2000 that were interested in turbo kits for the iQ. Biggest thing holding it back is lack of downpipe & manifold, although flipping a 1NZ-FE turbo manifold upside down would work.
MugenRep is offline   Reply With Quote
Old 01-25-2017, 01:39 PM   #2
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
I currently do not have the means for welding. Anything I need welded has to be done offsite. Once I get this kit actually functional and I determine that i need larger piping on the header, I'll pull it off and have one fabricated. Once thats completed, I'd def let someone try to fit the old Quantum header on their car.
Has anyone tried the Zage kit? If someone grabbed one of those, especially if you have confirmed the 1NZ header works, with some different intercooler piping, it would probably work. Piping is relatively cheap...$200 for what you would probably need. Not even sure what the Zage kits runs these days...used to be under $2K i thought.
Heck, if I COULD weld and had a welder, I'd probably started this process a long time ago. I'd LOVE to fab my own header and downpipe...
JustDidIt is offline   Reply With Quote
Old 01-25-2017, 04:01 PM   #3
MugenRep
MugenRep's Avatar
Drives: 2012 iQ
Sounds good. I actually posted up in the "Forced Induction" section a month or so ago with all the emails, names and connection info for the Zage kit and they're around $1200 now plus shipping.
Old 01-30-2017, 08:29 PM   #4
JustDidIt
JustDidIt's Avatar
Quantum turbo kit on 1NZFXE NHW20...Prius?
Greddy E-Manage Ultimate arrived today. Still haven't made any more headway on the ECM pin outs. Been referencing the 1NZFE diagram for help.
Old 02-09-2017, 11:21 PM   #5
JustDidIt
JustDidIt's Avatar
Been looking into tuners in the Texas area...
PRT Performance flat out said "No!" to me and the prius. lol
MVP Motorsports Inc also said "No!"
Dallas Performance - still need to call
EngineLogics - still need to call
The company i work for has offices in Austin and Houston so if I don't have any luck in Dallas, i was planning on hitting up Meghani Motorsports in Houston - they have done some work with MapECU and a turbo 2GR lotus.
I'd definitely check out Boostlogic and or Cobb if i can get a contact to confirm what they can work with Toyotas.
Dynosaur Performance was at least able to recommend a guy, Dusty from DAP Tuning, he's been busy, but i'm following up with him. He originally thought he could tune the oem ECU. He's been anle to do some stuff with the Tunda. So far this is the most promising yet i still have my doubts knowing the past history of people attempting to modify the ecrypted toyota ecu...
I'm currently trying to figure out if I can make my own custom ECM harness so I won't have to cut up my OEM wiring. Looks painstaking and tedious....
Old 02-12-2017, 10:52 AM   #6
JustDidIt
JustDidIt's Avatar
Realized my earlier post of the first ever supercharged then Turbo NHW10 1999 Classic Gen Prius story - the PDF didn't attach, so here it is again.
It's a good read - the trouble that Julian Edgar went thru to get the Prius up from 43kW (57hp) to 55kW (73hp)...a rough 30% increase in power. I'm hopefully I can get more..
The article just goes to show what i'm up against... in for a world of issues...
Summary of Turbo Modifications:
• Turbo – GT1241 from hydrogen turbo kit
• Fabricated exhaust manifold – Hydrogen Turbo Kit
• Fabricated intake and intercooler plumbing – 2 inch and 1.75 inch mandrel bent – Hydrogen Turbo Kit
• One heat range colder Iridium spark plugs – 2 step colder NGK 2667
• Intercooler – Hydrogen Turbo Kit came with a Spearco
• 2-inch exhaust – Car is already setup with a custom 2” Magnaflow exhaust.
• Airflow meter – use the one I made for my custom air intake
• Intake airbox – Will use a cone style filter, not concerned with the extra noise from not using a air box.
Still need to buy:
• GFB recirculating blow-off valve
• Turbo oil lines
• Fuel supply system – in-tank pump, external pump, two pressure regulators, solenoid, one-way valve, two control relays
Still need to figure out:
• Electronic switching of oxygen sensors and fuel pressure via the Simple Voltage Switch kit working off airflow meter signal - Hopefully the Greddy EMU will help with this.
• Airflow meter electronic interceptor – Hopefully the Greddy EMU will help with this.
• Decrease in high load boost using a solenoid-controlled bleed on BOV pressure line via Simple Voltage Switch working off airflow meter signal – Either Greddy EMU or some other Electronic boost control.
• Engine 'on' signal provided for 30 seconds after boost event via a modified Simple Voltage Switch working on hybrid ECU 'full air con request' input – still need to figure that out.
File Type: pdf 1st_Supercharged_then_Turboed_NHW10_Prius_optimized.pdf (2.10 MB, 35 views)
Old 03-17-2017, 11:28 AM   #7
JustDidIt
JustDidIt's Avatar
Test fit the Header and Turbo. Ordered some oil lines and connectors. Puzzle is starting to come together.
Old 06-17-2017, 04:21 PM   #8
JustDidIt
JustDidIt's Avatar
Well, this happened.
Decision has been finally made - ALL non-damaged aftermarket stuff has got to go. Car is being totaled and damage is more than the car is worth. Shameful...
All aftermarket parts being sold... :(
Old 06-17-2017, 04:23 PM   #9
JustDidIt
JustDidIt's Avatar
I'll start a new thread in the for sale section... this is painful to do.
This is my 2nd Prius to total and neither were my fault. I'm getting a check for this one, but I can't fix it for the amount, I'm getting.
Old 06-17-2017, 08:55 PM   #10
heeroyuy01195
Post count means nothing.
Sorry to see the project end like this. Glad you're safe!
Old 02-16-2018, 07:46 AM   #11
JustDidIt
JustDidIt's Avatar
Posted the turbo for sale here.
Quantum Technology Hydrogen 1NZ Turbo Kit GT1241
https://r.tapatalk.com/shareLink?sha...0&share_type=t
WTB Turbo kit ynnek317 Willing to Buy by private party 5 07-04-2014 01:53 PM
For Sale: ZPI Turbo Kit CTScott Items for Sale by private party 27 12-10-2013 06:00 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
