yeah. did you swap the electronics of the throttle bodies?
did you pull the codes from the ECU? |
![]() ![]() Drives: 2012 Black sand pearl <3 Join Date: Feb 2018
Is the spacer mandatory for this swap? I have an mr2 spyder here and I’m wondering if I should just go ahead and take the sensor and TB
^^^no. but it makes installing the throttle body where it can be removed easier more convenient...
![]() Drives: 2013 Yaris LE Join Date: Jun 2018
Hello, Thank you for putting together these details. i was able to swap my TB with your valuable info. I need help with the size of the coolant hoses, I ordered couple on amazon but none of them are the right size. for now, i bypassed the coolant lines. can you please share any link where you got them or the size. appreciate your help.
Newbie
Drives: vios ncp42 Join Date: Sep 2020
Bro how im 1nzfe engine (1st gen vios ) also but without piggyback
And TB (cable ) How to upgrade it to 1zz TB Since the Manifold just only 55 mm and the TB 70mm |
![]() Drives: yaris 2002 t sport Join Date: Oct 2021
I'd be interested in this too - mine is also a 1nz-fe 1.5 t sport (UK). I think the tb mount is only three bolts
![]() ![]() ![]() Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
I think this is my next mod, these throttle bodies are cheap over here in NZ.
has anyone mounted the 1zz airbox too so the intake size matches? does it/would it fit? |
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
you would probably scare the mass airflow sensor with the corolla intake
i did not see that post ill look for it, i dont see how a pedal would help with throttle lag, but i ended up taking the oem celica pedal pad and epoxied and screwed it on the oem yaris pedal
I will research this more and if i can find one I will try it for science.
https://www.yarisworld.com/forums/sh...ad.php?t=27172, i know of this one i was looking to solve my heel toe issue and came across this thread but i did not screw around with the lexus pedal i just took the aluminum pad and shaved it down flat on the back side and then epoxied and screwed it into the stock yaris pedal, it works very well and is sturdy and not going anywhere. i highly recommend getting a oem celica gts pedal and trying it, also get a spare gas pedal from a junkyard so if you screw up you dont fuck up your good gas pedal
#13 | |
![]() ![]() Drives: Yaris 2009 Join Date: May 2021
Anyone done this in Australia?
![]() Drives: 2016 Join Date: Feb 2024
Need some advice, so I did a 1nz to 1zz throttle body swap and after successful completion of the swap I did a retune, however my car won't pass 188kmh @ 5500rpm. Before the swap I was going 210kmh at close to 7000rpm. Why is my car limited to that top speed after the swap? NB. This car is a 2016 vitz Gs, mods replaced headers, cold air intake with K&N filter, 2 inch pipe from the resonator. 115hp before mods, 123hp after mods.
#17 | |
| 1zz or 2zz throttle body swap | BoostedTRD | Performance Modifications | 1 | 11-25-2014 10:05 AM |
| Installed the 1zz throttle body - | AlexNet0 | DIY / Maintenance / Service | 135 | 08-01-2014 07:57 AM |
| 1nzfe throttle body swap and fitment questions | EchoBob02 | Performance Modifications | 14 | 05-01-2014 08:02 AM |
| Throttle Body Swap | Ryze268 | Performance Modifications | 12 | 04-27-2014 01:46 PM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
