Old 06-19-2017, 12:18 AM   #1
alias06
Drives: 2008 Red Toyota Yaris
Originally Posted by DiCaprio View Post
It all comes down to the launch and conditions.
I've done a before and after test with new tires, lightweight alloys and air intake.
The car was stock before.
Before with winter tires and stock air intake the best i could do was 11.1 sec
After with new sticky summer tires and aftermarket air intake the best i could do was 11.3 sec.
So after i did the mods my 0-62 times were worse than before.
So i guess my winter tires stick well enough to put the power down and it all comes down to the launch and your shifting.
You can scrape off some time with good shifting.
But with a bad launch my times are always in the 12-13 sec range.
My engine is the 1.3l 2SZ-FE
The biggest difference that comes into play between your time and mine is that our engines are different. I have the 1NZ, and even with a wheel/tire setup that is heavier than stock and an axleback I've been able to get a 10 second range 0-60 with everything stock otherwise.
Sticky tires can take away performance of a car also. They have a higher rolling resistance, which basically means that you need more energy to move them than a tire with lower rolling resistance tires such as snow tires or energy conserving tires. With the 2SZ being limited on power already as is, sticky tires can negatively impact the performance.
Honestly, just by adding an intake and exhaust isn't going to make any car much faster (there are exceptions). It will however make your car louder, and if that is what floats your boat then
alias06 is offline   Reply With Quote
Old 04-28-2017, 04:53 AM   #2
tmontague
tmontague's Avatar
I don't even think my 2zr swap netted me 2 seconds....
Old 04-28-2017, 05:28 AM   #3
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
You better check your timing device :) 2 sec sounds very optimistic !
ncp13 is offline   Reply With Quote
Old 04-28-2017, 09:32 AM   #4
its worth it especially if you plan on some day getting a header and full exhaust (not just a muffler section)
Old 04-28-2017, 12:58 PM   #5
Yaris709
Drives: 07 yaris
Will probably go with an intake soon and sometime in the future maybe a header will be installed. Probably wait for the manifold to leak and replace it with a header then
Yaris709 is offline   Reply With Quote
Old 04-28-2017, 11:49 PM   #6
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Install a 1zz (Corolla/ Matrix) throttle body to really open up the performance.
Sent from my phone. Please excuse any typpos.
tarkus is offline   Reply With Quote
Old 04-29-2017, 02:45 AM   #7
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
not just opens up the performance...it really kick in :)
Sent from my SM-N920C using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 04-30-2017, 07:32 PM   #8
Won't happen
Old 04-28-2017, 07:43 PM   #9
SirDigby
Drives: 2007 yaris 3 door
sound system and leather adds weight=slows vehicle down.
spoiler adds drag=slows vehicle down
i have an injen intake. i think it was $130
injen flow tunes intake tube=speeds vehicle up (maybe .2 second faster 0-62)
k&n flow tune (???)
Old 04-29-2017, 08:10 AM   #10
miiser
miiser's Avatar
Drives: yaris 2009
Cold air intake?
k&n flow tune (???)
Wait you really think that a sound system will slow down your car?? about 0.001 sec?
As I said they don't give any speed upgrade but neither filter gives any speed bump.
miiser is offline   Reply With Quote
Old 05-05-2017, 08:59 PM   #11
SirDigby
sorry. when i think "sound system" i think lots of heavy gauge wire, amplifiers, subs, etc. i forgot we were talking $300...
Old 06-15-2017, 05:34 PM   #12
NJP440
2010EGGHATCH
NJP440's Avatar
Drives: White 2010 Yaris Hatch
Ok time for me to jack this thread. I ordered an intake for my 2010 yaris 3dr and the air sensor does not bolt up at all! Very far off on the bolt holes. Yes I bought a cheap intake but for those who are on the facebook page and remember Aimee and her 3rd gen "laboon" she had the same problem with her AFE intake. Now we are talking $50 intake vs a $300 intake so I can't call quality here, there must be something else at play. Anyone run into this issue? Does our car have 2 different model air sensors?
Pic of my cheap intake for hilarity purposes
Sent from my LG-H918 using Tapatalk
IG: 2010EGGHATCH
NJP440 is offline   Reply With Quote
Old 06-15-2017, 06:14 PM   #13
ecampos
ecampos's Avatar
Drives: 2017 Toyota Yaris S XP-150
I ran into the same issue and had to do this:
Basically modify the stock depurator cap, cut the intake, fit it with couplings. No issues so far.
2017 Toyota Yaris S XP-150: K&N Cold Air Intake, Megan Racing MO-E Muffler, DNA Motoring Exhaust Headers, Pedal Commader throttle controller, NST Pulley Kit, STR 526 17x8.25 rims (Volk TE37 Replica).
ecampos is offline   Reply With Quote
Old 06-15-2017, 06:15 PM   #14
NJP440
2010EGGHATCH
NJP440's Avatar
I'm trying so hard not to cut up my stock parts 😭
IG: 2010EGGHATCH
Old 06-15-2017, 06:19 PM   #15
ecampos
ecampos's Avatar
Oh I didn't... I put away the stock piece and ordered a new one to experiment, it was like $30 xD
Old 06-15-2017, 06:21 PM   #16
NJP440
2010EGGHATCH
NJP440's Avatar
Ohhh ok ill take a look on eBay see if anything pops up
IG: 2010EGGHATCH
Old 06-16-2017, 09:14 AM   #17
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I know it seems simple to me, but are you sure you were mounting the MAF in the correct direction. It only goes in one way because the holes are offset.
Old 06-16-2017, 09:16 AM   #18
NJP440
2010EGGHATCH
NJP440's Avatar
110% sure. There's a 4mm difference in mounting hole spacing and even the hole for the sensor to go in is 1mm too small
IG: 2010EGGHATCH
Simota CF650-6 Air Intake Review invader166 Performance Modifications 16 12-21-2015 03:31 PM
For Sale: Fujita F5 Cold Air Intake invader166 Items for Sale by private party 2 11-21-2015 11:10 AM
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 02:03 PM
cold air intake 400 dollar yaris Performance Modifications 10 10-02-2012 06:33 PM
