Thanks for the feedback.
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
FWIW...When I installed the MI springs (the way back like 8 years ago) i DIDNT cut my bumpstops and my reason was well better to have a little too much then not enough. Then I went to Tokico blues and still didnt cut them. About a year and 130~ thousand miles later I switched back to the stock springs and my oem bumps were still in fine shape and my shocks are just fine
And I thoroughly use my car ;)
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#3 | |
![]() ![]() ![]() Drives: 1986 Toyota Corolla Join Date: May 2009
Does anyone know how the TRD set up is configured?
Is your question does a car equipped with TRD suspension utilize different bump stops than one with standard suspension? If so, the answer is they both use the same bump stops.
You answered my question! I figured the TRD set up would not require me to mod the oem bump stops
![]() Drives: 2012 Sedan Join Date: Nov 2018
i dont know if this helps anyone but on my Tein Street Advance Z's they require the fronts to be cut to 60mm and the rear to remain unaltered. cutting the fronts down leaves the stiffer upper portion. i'm going to change them to a softer 58mm option i found.
Obsessed with 1.5L
Rediscovered this thread trying to pick out my next danpers.
Last year I changed out my stock front bumpstops for progressive Feal units. As even when I went back onto my stock springs I was still engaging the BSs too soon and it was causing the car to push mid corner on the road course. So when I changed them out I also put ny MI springs back in to gain some spring rate. The car is great. In fact in the 10 years ive owned it its never been better. However...these Tokico blues are just a little firm on the low speed dampening and also allow too much lift which allows the car to roll pretty hard even with my big sway bars. Mind you this is on all seasons
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
i got my new bilstein b8 front and rear shock and tein s tech springs i cut the factory bump stop like tein recommended and it rides really good! gives you a lot more cinfidence in cornering now. i will say that the rear feels a little obessesivly stiff compared to front but overall im happy
| Bump stop length for drop springs. | PetersRedYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 19 | 02-17-2010 08:37 AM |
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 05:02 PM |
| Option and Best motoring DVDs for sale | kustom play | Items for Sale by private party | 1 | 07-08-2009 08:04 PM |
| I found My New Sound/DVD/Nav system! | pp.sweet | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 07-05-2009 01:47 PM |
