![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
Thanks. It has served me well throughout my daily drives and road trips.
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
I'm curious mate i actually still have the factory head unit. I've actually seen a facia kit and a wiring harness on ebay for the Mk2 yaris and i was planning to swap a kenwood unit in because my factory unit is playing up. Did you need a cage adapter to make it fit in the hole or is a standard size?
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
#3 | |
#4 | |
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
#5 | |
Sent from my SM-T713 using Tapatalk
There was an adapter kit that made my head unit fit. I believe it's both a metal bracket that goes on the radio and into the dash, as well as a plastic trim that goes around the radio to fill the space around the face. Although my radio is a double din, they vary a bit in size so an adapter kit is typically needed.
