Old 02-13-2015, 08:40 AM   #1
2slowjetta
Drives: 2013 yaris
water sloshing sound?
when ever i star my 2013 yaris i can hear this sloshing sound out of the car is this normal or was it me that never heard that sound?
2slowjetta is offline   Reply With Quote
Old 02-13-2015, 09:00 AM   #2
WorkTL
WorkTL's Avatar
Drives: 2013 Yaris LE
I am also interested, I have the same sound in my 2013. I always check the coolant level, it's always full.
WorkTL is offline   Reply With Quote
Old 02-13-2015, 09:01 AM   #3
yougojay
25, 550 MILES!
Drives: Yaris L Coupe
I hear it in my 2013, too...I'm guessing it's the gas in the tank...
yougojay is offline   Reply With Quote
Old 02-13-2015, 09:06 AM   #4
Kar98
Drives: 2011 Scion tC
Did it rain a lot recently?
Old 02-13-2015, 04:35 PM   #5
WorkTL
WorkTL's Avatar
Not here in San Diego.
Old 02-13-2015, 08:33 PM   #6
If the sloshing sound is from the dash, then the AC box condensate drain is likely clogged.
Old 02-13-2015, 10:46 PM   #7
2slowjetta
Drives: 2013 yaris
just verified mine not cloged still have the water sloshing
Old 02-15-2015, 02:32 AM   #8
Ben_
Drives: 2010 Yaris Hatch
I noticed my gas tank sloshing recently. Can only hear it when the car is at idle and no ambient noise
I drive a 2010 hb
Ben_ is offline   Reply With Quote
Old 02-15-2015, 12:35 PM   #9
2slowjetta
Drives: 2013 yaris
sound source is from the dash not from the gas tank when the car is starting is when the car makes the sound
Old 02-15-2015, 01:03 PM   #10
In that case it is likely condensate in the air box. How did you go about trying to clear out the drain tube? You need to insert something all the way up the rubber hose to poke though whatever may be blocking the end within the box.
Old 02-15-2015, 02:22 PM   #11
2slowjetta
Drives: 2013 yaris
took out the hose used a wood stick and had nothing in there
Old 02-15-2015, 02:41 PM   #12
The only other water containing item behind the dash (other than things you might shove in the glove box) is the heater core. The only way I could see it making that kind of noise would be if it had air trapped in it from a prior coolant change.
Old 06-20-2016, 01:19 PM   #13
2014Yaris
Drives: 2014 Yaris LE
I hear the same noise in the rear of my car when I start to drive it like fluid slosh. Is this normal or need to be serviced? Thanks
2014Yaris is offline   Reply With Quote
Old 06-20-2016, 08:56 PM   #14
I was going to say air in coolant system
Jack up the front of the car, take off rad cap, start it, see if you get bubbles
Old 06-25-2016, 07:12 AM   #15
AntrimMan
Drives: 3G3DMT
Water in the A/C unit will slosh, that's not what this noise is.
It's more like walking in rubber boots that contain water, that squelch noise.
The noise emanates only on the initial movement of the vehicle.
Ensure manual gearbox is in N, depress clutch pedal, start the engine, select first gear, apply foot brake, release hand brake, engage clutch, within less than one revolution of the vehicle wheels one can hear the squelch.
The important part here is the revolution of the wheels.
No noise until the vehicle is in motion. Happens in forward or reverse.
I think it is part of the ABS system charging itself and getting ready for a traction control demand.
Mine has done it since new, still does, and continues to stop well.
Probably happens in Auto gear box models too.
AntrimMan is offline   Reply With Quote
Old 06-25-2016, 07:54 AM   #16
It couldn't be the brakes or ABS system, but it could be the torque converter of the automatic transmission. I have never noticed sound out of any of my AT Yaris though.
Old 08-17-2016, 11:44 AM   #17
UpLateAgain
Drives: 2008 Yaris automatic
Reading this thread might be worth consideration:
http://www.yarisworld.com/forums/showthread.php?t=6053
It was the case with my '08.. and unplugging the drainage tube fixed it.
UpLateAgain is offline   Reply With Quote
Old 07-20-2018, 07:35 PM   #18
kdhmed
Drives: 2010 Toyota Yaris
Update
Thanks for the advice on this thread. I am technically illiterate and wasn’t able to pull up the pics but figured this one out. Found the drain hose, used a straight plastic stick to break up debris. This alone didn’t do the trick but I popped it back in and then “milked” it like others suggested and probably drained two liters of water out. This is the second time this has happened to my 2010, first one was about 5yrs sho and I didn’t know better and just paid Toyota. Now time to get a cabin filter in there...
kdhmed is offline   Reply With Quote
2007 hatchback making a weird whirring sound robkay DIY / Maintenance / Service 20 03-19-2016 06:53 PM
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 05:35 PM
sloshing sound when starting up CPALK719 Third Gen Yaris General Discussion 10 03-27-2012 05:59 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
New Sound System - Sound Issues click.mine In Car Entertainment + Electronics (audio / video / alarm) 11 03-20-2009 03:11 AM
