Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Cable #1 goes to the starter positive terminal.
Cable #2 goes to the alternator positive post, should be connected to the other attachment point on the front of this fuse block. The left-over connection #3 in the back is your main ground point to the battery negative post, see how its grounded to the strut tower? |
#2 | |
Yes, using the fusible link plus battery terminal clamp from the yaris is correct and currently how mine is set up.
Look at the picture you just posted and notice how your yaris negative tab has 2 ground wires coming from it. Then look at your xd negative tab and notice that there is only one wire running from it. Now go outside and test if your transmission case is grounded. This is something that you still have yet to report in but was mentioned to you pages ago. This will answer the question of what seems to be your issue to all of your problems. In case you aren't sure how to do it just attach your positive probe from your multimeter to the battery positive and the negative probe to your transmission case and read the voltage. If you have no voltage then you have no ground. Or read resistance and you should have little to no resistance. Then report back. Typically when the fusible link is blown you have a hell of a lot if issues opp up and the dash can light up like a Christmas tree
I looked for a pic of my xd harness but cannot find one.
I'm pretty sure you have to use your yaris battery ground tab with the 2 wires from it (one to chassis and one to trans case) The other ground tab from the xd harness I couldn't remember but Tom is likely correct that it goes to the fuse block, I just never remembered that part
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
Well, good it's not a blown fuse/fusible link - that could indicate other problems either current or on the prior xD that hopefully wouldn't have damaged the wiring harness.
Those 2 connectors from the Yaris that you have labelled look like the 2 grounds - body and transmission that I recall. What I don't recall is any heavy gauge cable on an engine harness going to the negative terminal on the battery. Have you run that black cable (2) back to it's source... ? For giggles, with everything sitting where it is now (battery out), check for continuity between the alternator terminal and that cable (2) - I'm wondering if you've been hooking the alternator up to the negative battery terminal instead of the side of the positive terminal block - which in the pictures you show is missing a connector.. which a quick look at my Yaris I think the red cable to the starter should be on the front of the block and the alternator - which has a black cable with a blue stripe on mine - should be to the backside of the positive terminal block. edit: apparently while I ran to the garage the other guys already nailed it. ![]() -- Adam |
#6 | |
You guys freakin rock! And I feel like an idiot!
14.6 Volts!!!! I will however put the battery on charge rather than expect the alternator to do that job. I am going to sleep well tonight! Tomorrow I will do up the wiring on the trans plug. I still have the P2770 BUT I have neither wire grounded. Just so I'm clear, I should still ground brown wire#9, correct? Soon it will be... except auto!
EDIT* very sorry for the huge images, still learning how to use imgur, but at least these pics won't ghost in a couple weeks
Alright, in just spent some time looking st my old yaris harness and took a look in my engine bay and I'm pretty sure I know what your problem is. The xd harness does not come with any large ground terminals that you hook up to your negative post on your battery. You keep your yaris ground cable for that ![]() The xd harness comes with 2 large black wires with terminals and one will have red electrical tape on it and the other will not. These are both power cables that go to your positive terminal on the battery. The one with red tape is the direct line to the starter. They both attach to the two spots on the fusible link junction that you keep from your yaris. ![]() I think your are either missing one of these positive cable ends or are attaching one to your negative side on the battery and/or not.using your yaris ground cables. Either way you need to test your trans case for ground.
#9 | |
It worked Trevor! I now have a grounded trans case and max charging! I still have the P2770 but I will fix that tomorrow, hopefully.
No codes after 10 minutes of running!!!
Remaining jobs: - A/C compressor, o-ring replacement and recharge - Axle back exhaust - solder wiring connections - secure coolant filler neck with bolts
Data doesn't lie
Sweet baby Jesus.....we finally got it.
Trevor I think you have a good idea regarding the electrical, clear pictures and instructions on that is definitely needed |
Yes! It is running strong, free of MILS. The idea to create an electrical thread is a great one. I know that it will help others in the future. I have hundreds of pictures, so, Trevor, if you need any in particular, I'd be happy to provide any needed. It's the least I could do to contribute.
#14 |
Haha, thanks Adam. Given the support/time investment that you guys generously provided me, I think a little smack down is a minor price to pay. Lol. Oh yeah, and a person has to have pride in the first place to really take offense.
![]() Got hockey practice today, a few other family commitments, and a few odds and ends to tie up on the car, so first drive looks like tomorrow. Thanks again for all your help, Adam. It has been an experience.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-03-2018 at 08:42 AM. |
#15 |
I plan on making a new 2zr swap thread with just the specific info regarding electrical hook up and what to do with the xd vs yaris harness and grounds.
I will keep it just to those specifics and avoid the stuff about how to pull an engine as that is on all the other swap threads. This was probably the one part I wasnt sure about as it isn't in one section of the swap threads and until I had my harness to look at it was a big question mark for me
#16 |
Data doesn't lie
We also need a moderator to remove the wrong wiring picture in brushforhires thread...
I was caught sleeping by that one |
#17 |
Apparently not out of the woods yet.
On my latest start up, I ran the car for about 1/2 an hour to check my plumbing for leaks. Everything was good. I went back out and started the car and my P2770 is back. I cleared the codes and it returns with each startup. The car has started and run at least 3-4 times without displaying any codes. I am going to recheck all of my connections, but I soldered and heat shrinked all of them with pin 9 grounded. I have full charging and my transmission is grounded - 12.6V at terminals and 12.6V from trans case to positive. This is very strange as I've had several startups and no codes. It must be a bad connection. I'll sand down the contact point on the transmission case where the ground attaches. Will report back after I recheck everything. Tests completed: 1) have continuity on the blue wire as I repaired it (ECM Pin 78 to C29 pin 10), so my blue wire is good. 2) have continuity from ring terminal on brown wire to female pin 9 in connector C29, so my ground is good. I removed the ring terminal from the block for this test. 3) sanded and tested the ground on the trans case 12.6v tested at the battery and 12.6v using positive battery post and ground. Observations: If I disconnect the battery terminal for a few minutes, then come back and start the car, it does not light up the MIL, but Torque registers a pending code of P2770. On the second start, the MIL comes on and Torque shows a current fault P2770. ![]() Looking at the diagram for the xD, is it possible that brushforhire was right and it is the blue wire that needs grounding? I didn't have trans ground when I tried the blue wire. Pin 10 in the pic below looks like to goes to ground but I'm still in the learning phase about wiring diagrams. EDIT: Blue wire grounded gives the same code.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-03-2018 at 07:50 PM. |
#18 |
Data doesn't lie
This is confusing because My harness is the same as yours.
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 11-03-2018 at 09:57 PM. |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
