You are probably correct. They look fairly inexpensive, but would necessitate another discharge, vacuum and recharge. I think I'll do this in the spring/summer. I'll probably replace the schrader valves too as well as the o-ring at the firewall (expansion valve?).
Just ordered a Denso on eBay for ~$11.00. Do you happen to know, WeeYari, if the schrader valves are just standard R134 valves and if they are both the same size? Also, I think I'll need a special tool. I have one for tire schrader valves, but it may be different.
Good price on the sensor. New? You wouldn't believe the cost of one through Toyota Canada. North of $600. Why is their price so high? Only available as part of a tubing replacement bundle believe it or not.
As for your Schrader valves, I can't imagine any reason for replacement. They sit there for life under their little protective caps. Sent from my EML-L09 using Tapatalk
#4 | |
https://www.ebay.com/itm/For-A-C-Pre...72.m2749.l2649 I think it was mainly leaking around the base of the fitting that holds the schrader valve (turning the manifold gauge dials may have loosened it), though I thought I saw a little bubbling inside the valve toward the base. I gave it a little tap on the top of the schrader valve and it seemed to seat and there were no more bubbles. They may be fine, but I thought since I have to discharge the system again to replace the sensor, I figured I'd do the schrader valves at the same time.
I went with a somewhat more expensive listing. Can't remember why but I suspect it was because shipping on the cheaper ones was stupid high.
often find valve cores loose in schrader stems
Thanks. I am going to pick up an A/C schrader valve tool as well. May try just snugging them up a bit.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 12-27-2018 at 10:49 PM. |
Our local APM auto parts store actually had an A/C schrader valve tool - and this after calling half a dozen shops in the city 80 kms away and no one having one. $6.00 + tax out the door. I'm heading across the border tomorrow to pick up my Denso sensor, 2 cans R134 and the schrader kit.
Current plan is to wait for a warmish day, get my garage up to 65 - 70F, aim my big fan at the condensor and try again. I'll evacuate, replace the o-ring at the expansion valve, the schrader valves and pressure sensor. Then, a lengthy vacuum test. Finally a recharge quantity of R134 (~ 13 oz) and pressure tests based on ambient temps. From both what Trevor said and what I've read, this is work best not done in winter. I wonder if my vacuum tube would have iced up so badly in warmer weather.
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| A/C Clutch Compressor question | tmontague | DIY / Maintenance / Service | 3 | 05-11-2014 07:57 AM |
| A/C Broken On My 2010 5 DR HB | ChilliwackGuy | DIY / Maintenance / Service | 15 | 07-14-2010 04:33 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
