Old 07-10-2019, 11:35 PM   #1
toyotavios_11
Drives: Toyota Vios
is your a/c refrigerant at optimal quantity. please send for pressure check. i doubt your a/c is having low refrigerant.
toyotavios_11 is offline   Reply With Quote
Old 07-11-2019, 02:46 AM   #2
bronsin
bronsin's Avatar
Car goes to shop friday
Old 08-09-2020, 06:13 AM   #3
rayfloyd170
Drives: Yaris 2016 1.3 Manual
Hi @bronsin Di you solve your rad fan issue running slow? Or you changed with new motor?
Mine has the opposite it always run high speed no matter what and lost the low speed.
I got the gen 3 yaris. I tested the fan relay no.1 and found okay, even swapped it with horn relay which is exact same part number.
I tested fan relay no.2 and found okay too.
I removed the resistor and tested it and got 1.3ohms which is what the spec should be...
I was left with the Pressure Switch but when i tested it also found it to work fine.
Then i remembered, i did an evaporator change about 6 months ago and the mechanic added some oil too during R134a recharge. I was thinking the mechanic may have overfilled my AC system with some refrigerant and ND-8 oil, he didn't use a weighing scale but only had the gauge manifold and touching of the LP pipe.
This led me to vent a little of the refrigerant containing lots of oils (not allowed in U.S.) and there goes my Low Speed Fan kicking and when my engine is hot it uses the High Speed.
rayfloyd170 is offline   Reply With Quote
Hubcap question 2009 Yaris Sedan- URGENT mrs_yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-13-2016 02:21 PM
License Plate question awebb005 Cosmetic Modifications (Exterior/Interior) 5 11-11-2014 08:28 AM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
