Old 11-17-2020, 06:02 PM   #1
bronsin
bronsin's Avatar
Band type. I think the filter was over tightened I couldn’t budget. But then again, I am weak from the Parkinson’s
Old 11-17-2020, 07:05 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yeah, some places/people overtighten them. I guess they feel that hand tight isn't enough.
Old 11-17-2020, 08:36 PM   #3
bronsin
bronsin's Avatar
If you were a professional mechanic you wouldn’t want one of the filter to leak. That would ruin your reputation!
I think only the general public would hand tighten it so it comes off easily.
Old 11-17-2020, 10:02 PM   #4
06YarisRS
True. I guess many of them subscribe to the same philosophy when it comes to the drain plug. Lol.
Old 04-12-2021, 06:41 PM   #5
bronsin
bronsin's Avatar
Wife use the pick up truck F150 to pick up our new lawnmower. It’s a Toro electric motor with a 60 amp hour battery. It’s self-propelled. Now I don’t have to change the oil or buy gas for it. Still have to sharpen the blade every year though.
Old 11-22-2020, 10:04 AM   #6
bronsin
bronsin's Avatar
The new oil filter didn’t stop the coldstart rattle, but it seems less. Further research indicates some Engines do this since new. That’s what I’m going with for now!
Now I’m going to concentrate on getting the bed cover removed or at least tied up at the front of the bed.
Old 11-23-2020, 12:36 PM   #7
bronsin
bronsin's Avatar
Drove the truck this morning and there was no coldstart rattle at all! I’ll be driving down to my daughters house 50 miles down I-95 for Thanksgiving. Hopefully that will reset the computer that was re-programmed to put the ABS module in.f
Old 11-26-2020, 08:59 PM   #8
bronsin
bronsin's Avatar
The blue driver indicates the truck passes the smog Test after driving the 50 miles down I 95 and back. So all the tests have now been run in the truck will pass inspection.
Old 11-29-2020, 12:59 AM   #9
bronsin
bronsin's Avatar
Here is the F1 50.
File Type: jpg 5EF536FD-EC43-4039-ADCF-EC2CB9CD4F7C.jpg (254.5 KB, 88 views)
Old 11-29-2020, 03:11 PM   #10
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
Mmmmm, base model regular cabs are the best trucks.
Not a fan of white on a pickup but it looks like a nice honest workhorse.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
Old 11-29-2020, 04:06 PM   #11
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
I keep thinking Marvel Mystery Oil to temporarily solve high mileage noisy engine problems.
Old 11-29-2020, 06:46 PM   #12
bronsin
bronsin's Avatar
Not this time. It’s a hydraulic cam tensioner that bleeds out overnight and the chain rattles until it pumps up in the morning.
$1700 to fix it it according to Ford.
People say on YouTube it’ll do it for 100,000 miles. That’s what I’m going to believe!
Let that be a lesson to you. By Toyota!
Old 12-11-2020, 02:59 PM   #13
bronsin
bronsin's Avatar
The F1 50 update.
I’m waiting to get the registration title and plates from the used car dealer I bought the truck from. It’s been a month and a temporary registration runs out Saturday. I called the salesman he said it might take 60 days but with the way Cove it has affected the DMV.
In the meantime I’m trying to figure out how I will check the oil. I can’t reach the dipstick no way. I tried buying an 11 inch high folding stool from Amazon to stand on but that didn’t work. I guess I’ll have to have them check the oil at the gas station.
I am ready to put the plates on when they come. I bought an electric screwdriver from Harbor freight which works great. With the Parkinson’s I don’t have enough dexterity in my hands to use a screwdriver to attach the plates.
Old 01-04-2021, 12:34 PM   #14
bronsin
bronsin's Avatar
F 150 update
I bought the truck November 13 and still don’t have the title registration and plates. The dealer I bought the truck from handled all that.
DMV New Jersey seriously affected by the coronavirus!
Wow adding Dooley wheel Quite a modification!
Old 01-15-2021, 02:58 PM   #15
bronsin
bronsin's Avatar
I took the F1 50 in to get two new front tires and the coolant changed. When they change the coolant they found it look like someone had put stop leak in it. They flushed it all out twice and now I wonder if it will leak.
We shall see!
Old 01-15-2021, 08:32 PM   #16
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Ouch. Stop Leak is never a good sign.
2014 NCP131 5 Speed
Old 01-17-2021, 10:02 AM   #17
bronsin
bronsin's Avatar
Drove the truck this morning on the highway for the first time. The new tires make it go straight down the road, the old worn out ones cause the truck to wander from side to side.
Old 03-05-2021, 06:30 PM   #18
bronsin
bronsin's Avatar
The plates, title, and registration finally came from New Jersey DMV for the truck. I purchased it November 13 so the DMV took nearly 4 months!
