10-10-2021, 05:20 PM | #1 |
Drives: yaris 2002 t sport Join Date: Oct 2021
exhaust drone
Recently joined the forum - really good site and loads of great info!
Bought t-sport 2002 recently and have been working my way through rectifying niggles etc. One such annoyance is the droning from the exhaust from around 2500 to about 3200 rpm. Really very intrusive in the cabin. It looks like the rear heat shield may not be there as the boot carpet and floor area get quite warm too - i've just added a few layers of Damplifier there as the floor is really thin! Just wondering if the two are related? Anyone else had that drone and if so, what did you do to reduce it? Thanks |
10-25-2021, 02:10 PM | #2 |
Drives: Yaris T sport TRD turbo Join Date: Aug 2017
They are high revving tin cans at the end of the day. But as you already said sound deadening mats make a huge difference.
2004 Yaris T-Sport 1NZ-FE with TRD Turbo |
12-04-2021, 02:06 PM | #3 |
Haha good description! Just changed the backbox which has reduced the drone but at 2500 to about 3000 its quite prominent. My old 1.3 cdx never had this and as they're practically identical (2nz and 1nz) i assumed it would be the same here?
Does adding weights to the exhaust do anything? |
01-18-2023, 06:49 AM | #4 |
@pump_upp - best crypto pumps on telegram !
https://t.me/pump_upp - best crypto pumps on telegram
Make 1000% and more within 1 day, join channel @pump_upp ! |
03-08-2023, 04:12 PM | #5 |
Drives: 2008 Toyota Yaris Hatchback Join Date: Mar 2023
Hi, I was wonder what the difference between a 2008 Yaris Hatchback and a Sedan Exhaust.
03-08-2023, 04:19 PM | #6 |
Since the distance between the rear axle and the bumper on the sedan is significantly greater than the hatch, the sedan muffler assembly is much longer.
03-08-2023, 04:20 PM | #7 |
Is there a difference between a 2008 yaris Hatchback and a Sedan Exhaust? I can't find a answer. Thanks
03-08-2023, 04:24 PM | #8 |
Someone stold my exhaust and I bought a new one. I needed a Hatchback and they sent a sedan, I think. I cut it down to fit but for some reason it is hitting against the floor when you put it in gear?
03-08-2023, 04:29 PM | #9 |
03-08-2023, 04:30 PM | #10 |
12-21-2023, 11:15 PM | #11 |
Drives: 2009 Toyota Corolla Join Date: Dec 2023
Good work figuring it out! Steering wheel control wiring can definitely be tricky. I'm always impressed by people who take the time to DIY install their own stereos - saves a bundle over paying a shop to do it.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
Enkei's and Dunlops + Medalion Touring Exhaust | 2manywheels | Items for Sale by private party | 40 | 04-04-2011 05:01 PM |
does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
