07-06-2022, 02:24 AM | #1 |
2NZ Echo kids comp hack
Drives: 2003 Toyota Echo comp hack Join Date: Jul 2020
(NCP10/13) Air Flow Meter - Any option to increase size with standard ECU
Using the rough formula of needing 1mm/Hp/cylinder inlet pipe diameter for power, the standard AFM at 55.5mm (2ish inches) would max out at barely a couple of percent above standard.
e.g. 120Hp = 30Hp/Cylinder, requires the equivalent of 4 x 30mm Diameter inlet size. to get to a modest 20% increase - 130Hp (through other mods) would require the AFM to be 65.5mm diameter to supply enough air. 10mm increase over the standard size. Just increasing the inlet pipe size would make the AFM signal the ECU that it was receiving 45% less air that it really was, running ultra lean and boooom!!! Is there a way to swap or modify the AFM so that the ECU supplies the correct amount of fuel for actual airflow as performance mods allow? Maybe adding a resistor in the circuit, but I fear this would destroy idle. I am looking to add a quad throttle body system, but continue to use the standard ECU. I understand sacrifices would be made. |
07-06-2022, 02:58 PM | #2 |
Drives: Yaris T sport TRD turbo Join Date: Aug 2017
No, the stock ecu cannot be fouled
Car won't run right with a bigger inlet pipe ITB's on stock ecu ain't going to happen either.
2004 Yaris T-Sport 1NZ-FE with TRD Turbo |
07-07-2022, 07:46 AM | #3 |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
Not happening with a Toyota ECU.
If you want to be able to mess with ECU tuning, invest in a good standalone or piggyback.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's |
07-22-2022, 10:10 PM | #4 |
Drives: |Mr2 Join Date: Feb 2018
While it may be similar, on the mr2 groups they do what is called the MAF mod. On the 1zz (which uses almost the exact same system as the 1nz) they space the MAF a 1/4" higher to trick the engine to readjust ignition timing and fuel. That was on a slightly larger intake pipe, but I imagine you could experiment with it ... Ps, I'm not responsible
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
Toyota Yaris part# 21-573 | yarispro | Central and South America | 40 | 08-15-2007 02:51 PM |
Exhaust Pipe Size (Tamaņo del tubo de escape) | carlosh | Central and South America | 11 | 08-02-2007 04:15 PM |
