09-10-2016, 01:49 PM | #37 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Here we have both shafts and all of the case components installed, time to seal it up.
09-17-2016, 02:40 PM | #38 |
Data doesn't lie
The main case is sealed, and 5th gear assembly installed
09-17-2016, 02:45 PM | #39 |
Data doesn't lie
Slide the shifter assy in just to verity you can shift to all 6 gears, if so you can seal the end case
09-17-2016, 02:52 PM | #40 |
Data doesn't lie
Now you can install the shifter assy and all brackets/switches. Now you're ready to install the transmission
07-09-2020, 05:13 AM | #41 |
Drives: 07 Sedan (AT) Join Date: Jun 2020
Thanks @ArmstrongRacing for taking the time to put this together! You rock man!
I know this is an old thread and all, but does anyone know if you'll lose your current odometer reading when swapping ECM? Can't seem to find a definitive answer in my searches. |
07-09-2020, 07:34 AM | #42 |
07-10-2020, 07:28 AM | #43 |
10-23-2022, 03:33 PM | #44 |
Drives: Toyota yaris Join Date: Oct 2022
Can u tell as abt the throtel wiring ? Tnx
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Effects of too much trans fluid in the case? (auto trans) | detroiter | General Yaris / Vitz Discussion | 5 | 02-24-2009 11:08 PM |
Manual To Auto | bronsin | General Yaris / Vitz Discussion | 10 | 12-22-2008 10:32 PM |
What RPM's are you americans getting on Auto trans? | BMGYaris | General Yaris / Vitz Discussion | 12 | 11-02-2006 02:43 AM |
Manual vs. Auto | littlecarlove | General Yaris / Vitz Discussion | 25 | 10-25-2006 08:45 PM |
Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 10:57 PM |
