Old 11-14-2009, 08:18 PM   #1
Kiwi Mike
Kiwi Mike's Avatar
Drives: '01 Yaris RS 1.3 hatch
ladies and gentlemen, for your viewing pleasure...
my first gen RS 1.3 ex-Japan, now dubbed "The Mushroom"by my 10-year olds. It had 16" Artecs +35 offset, which looked ok but rubbed badly. I hunted around and found these Mak Rave 16x7s, +39, 2nd-hand, for not too much. Tyres are Hankook Ventus 205/40. Suspension is lowered but I have no idea how much by. Still rubs a little so will need front guards rolled. Hope you like it! Mike
Kiwi Mike is offline   Reply With Quote
Old 11-14-2009, 09:37 PM   #2
SLIK4
Michael
SLIK4's Avatar
Drives: 07 Silver Yaris Sedan
not my car cuz mine doesnt have aftermarket rims yet but this is what i hope it to look like in the future...with a drop also.
http://www.tirerack.com/wheels/MiniW...d=true&sw=1280
SLIK4 is offline   Reply With Quote
Old 11-15-2009, 01:08 PM   #3
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Some nice wheels!
Blah, Blah, Blah, Blah
Saggio is offline   Reply With Quote
Old 11-15-2009, 01:44 PM   #4
chongopants
Drives: 2007 Yaris Hatchback
Send a message via AIM to chongopants Send a message via MSN to chongopants
anyone know some light and cheap rims? or a good place to get tires?
chongopants is offline   Reply With Quote
Old 11-15-2009, 03:24 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
define cheap? but there was a link to a miata store that sold a bunch of them somehwere. our cars can fit their wheels. Konig Helium's are a very popular choice for light wheels. Anywhere that sells tires is a decent place. I got mine at the dealership, but any decent size chain or mechanic you trust will work.
Colin Chapman disciple
Old 11-19-2009, 10:12 PM   #6
MR. CANTON
Drives: Yaris Sedan
I have TRD SPORTIVO shock and spring and well the rim is 17" x 8" wide with 235/40/17 Sumitomo HTRZ tyres
& a pimped out PUP
MR. CANTON is offline   Reply With Quote
Old 12-10-2009, 01:23 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
& a pimped out PUP
man those rims look badass on your yaris. What brand are those
Old 12-12-2009, 01:23 PM   #8
yaris07hb
PnutKar
Drives: 2011 Liftback w/manual box
Before and after shots of PnutKar. Wheels are from a Mini Cooper, 42mm offset using Gorilla E/T Conical lug nuts (BMW uses studs on the Cooper). Removed the Mini logo from the center caps with a heat gun. The Toyota logo from the hubcaps would not fit within the center caps so I left them blank. Tires are Michelin Harmony, stock 185/60R15. Contemplated 195 and 205 but cost, wear, and warranty are an issue. It is my humble opinion that these wheels look very good on the car - they complement the "roundy" look nicely. Now it needs some "squat".
yaris07hb is offline   Reply With Quote
Old 12-12-2009, 02:57 PM   #9
ddongbap
You mean, they use bolts. We use studs. They use bolts.
Old 12-12-2009, 05:17 PM   #10
yaris07hb
PnutKar
Oops - yes. They bolts, we studs.
Old 12-12-2009, 11:31 PM   #11
I run a set of the same Mini rims as my Winter rims. Their lug bolts are larger diameter than our studs and the hub is 2mm wider. If you aren't running hubcentric rings (I couldn't find ones to fit), you should use lug nuts that make the wheels lugcentric. I am using lugcentric bulge conical lug nuts that I found at Jegs that have the correct taper and have a part below the taper that fills the space between our studs and the wheel:
http://www.jegs.com/i/Detroit+Wheels...395-5/10002/-1
Old 12-15-2009, 10:27 PM   #12
yaris07hb
PnutKar
Yes, we don't want wobbly wheels do we? I used these lug nuts from Gorilla. They look similar to the Jegs nuts, but not as "bulgey". I like the Jegs better. I'll have to get some.
Old 12-28-2009, 11:34 PM   #13
MR. CANTON
Drives: Yaris Sedan
they are SPORT MAX With Sumitomo HTRZ 235 40 17
Old 12-24-2009, 05:51 PM   #14
Kal-El
Kal-El's Avatar
& a pimped out PUP
Wow, nice setup. Tell us what rims those are!
Old 12-28-2009, 11:36 PM   #15
MR. CANTON
Drives: Yaris Sedan
SPORT MAX RIMS
SUMITOMO 235 40 17
Old 12-29-2009, 06:17 AM   #16
Kal-El
Kal-El's Avatar
SPORT MAX RIMS
SUMITOMO 235 40 17
Thanks
Old 12-29-2009, 11:00 PM   #17
Kal-El
Kal-El's Avatar
SPORT MAX RIMS
SUMITOMO 235 40 17
So wait a second, you have 235 wide tires?? Don't you get serious rubbing?
I don't recall ever seeing anyone with that width.
Old 11-23-2009, 04:47 PM   #18
07blackvitz
07 Liftback
07blackvitz's Avatar
Drives: 2007 Yaris liftback black
http://c1.ac-images.myspacecdn.com/i...372a2dbed0.jpg
Here are my wheels 15x8 +15.....
07blackvitz is offline   Reply With Quote
