OHH I'm so happy! the rubbing it's gone! I installed my new O.Z. Ultraleggera 16x7, 37mm offset, with 195/50/16 rubber! they are awesome, and about 7 pounds lighter than the OEM with snow tires I use. I also added a 10mm spacer in the back. BUT... I was having rubbing issues on the rear axis. And thanks to people here in Yaris Wold, I got many possible solutions: 1. Take out 10mm spacers (for some reason there are stuck) and I really didn't want to do this. 2. Roll the fenders 3. Add a Camber Kit 4. Add a RING-TYPE COIL SPRING STABILIZER So I started with number (4)- Spring Stabilizers, I installed them last night, put one OZ and went for a ride! NO RUBBING, ok I went back home and put the other OZ and test them this morning on my way to work. NO RUBBING!!! The rear suspension got a little harder (not as soft) but feels really good! Lift UP the rear about 1/2 inch bringing the car to almost level with the front suspension the NF210s really make the car look like if I had something very heavy in my trunk, and now my car handles so much BETTER! like Loren told me about the Spring Stabilizers: "Just jack up the car and squeeze on in on each rear spring. Will raise the ride height a little, and by removing an active coil from the spring, also raise the spring rate." I'm still going to do the Camber Kit (there is no rubbing with full tank and my self but I bet once I add weight the tires will hit the fenders again) so this may help, I'm going to load my car and test it before adding camber. Roll the fenders as well! and if everything works well under LOAD I'm going to try to keep the spacer because looks so GOOD. ![]() ![]() ![]() Derick.
. CLA 250, 4MATIC Last edited by derickveliz2; 05-12-2010 at 05:33 PM. |
08' Sedan S, 5 spd w/ 205/50/16 Yoko S.Drive on 16" Drag DR9s w/ 40 offst. Clearance on full turns were tight but no rubbing on full loads and over humps. GPS reading same as speedo or no noticeable difference. Stock 15s weighs 31.8 lbs (w/ 38k miles), new wheel/tire w/o TPMS weighs 41.2 lbs. Rides nice, awesome grip. Did a 40 on a 20 turn like nothin! A 1" drop will complete this project.
black shark
Drives: black toyota yaris t3 sprit Join Date: May 2010
got a 17" bersaglio covered with 205/40/zr17 firenza
www.justbabynappies.co.za |
3,300+ at one point.. >:(
Drives: 2010 Hatchback RS Join Date: Aug 2007
Hey StragglerX, love those rims. I've always been a fan of the black rim with the red stripe!
thanx landrym28, had a hard time deciding between high gloss finish and flat black. picked the flat coz i thought glossy is a bit too flashy like chromes. flat shows dirt easily though and harder to clean. what do u think of my clearance? should i just leave it alone or drop? what lowering spring should i get if i decide to drop? i'm thinkin a 1" to 1 1/2" drop should even it all around.
http://www.viosgen2.com
18x7.5 Sato5 Wheels +40 offset
215/35/18 Firenza ST-08 Tein S.Tech with Spring Cushions on the rear Just recently removed 5mm spacer on the rears now I have no rubbing what so ever. I do have some occasional rubbing when making turns on high speeds, very minimal though ![]()
A there is a site for Vios, Belta and Yaris Sedan owners! DIY Articles Etc. ![]() http://www.viosunderground.com Wheelsearch Classifieds (Beta, need help guys!) http://www.wheelsearcher.com |
Michael
Drives: 07 Silver Yaris Sedan Join Date: May 2007
^very nice. goin for the VIP style?
#8 | |
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
Finally after waiting 6 weeks for wheels. Konig Lightspeed 15x6.5 +38 10.8 lbs. Falken ZE-502 205/50/15 lowered on Tigertecs. no rubbing at all.
DSCI0199.jpg [ATTACH]33956[/ATTACH DSCI0203.jpg |
Shut your fricken suck!!!
Nice wheels! Are those tires rubbing in the front?
Thanks. No rubbing. The tires are new and only had 10 miles on them when I took the pictures.
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
Konig Heliums 15x6.5 195/55/15 and 2 inch drop.
![]() ![]() Drives: 2008 yaris sedan Join Date: Jan 2010
@mario98c: what springs are you using? or are you on coilovers?
The car have Ag kit lowering Springs.
Very nice! I really like the "Lip" effect.
. CLA 250, 4MATIC |
#16 | |
PWN'ING NOOBS SINCE PONG
Drives: Yaris Join Date: Mar 2010
DAT'S RIGHT I GOTz 2
RAZE R24 17x7 +40 GOLD NEXEN N5000 205/40r17
![]() ![]() Drives: 08' Yaris Join Date: May 2010
My Little Egg'ie.
Just installed the wing, and the new wheels. Wheels are XXR 006, 17x7 Falken 912 tires, 205/40/17 ![]() ![]()
| Post pics of cylinder head (engine) covers here | joelitton | Cosmetic Modifications (Exterior/Interior) | 157 | 08-02-2017 11:36 AM |
| My new 09 yaris! (post bath) | tristan | Photo-Video-Media Gallery | 10 | 10-21-2008 01:23 PM |
