![]() ![]() ![]() Drives: 2007 and 2008 MM Yari LBs Join Date: Aug 2006
looks like spectre from pepboys...
i did the same with the plastic pieces for the wifes, but after about ten miles the maf lit the cel. the tubing is too big for the little throttle body. the diagram further back that explains air flow explains it too well. as for chinos im hoping he is designing something in lines of this so that the engine always graps from a larger pocket of air. if not patiance is fine and if i come to not like yours chino, sorry but weapon-r has a affordable reasonable short ram.
Two Yari on home! ![]() |
![]() ![]() ![]() Drives: 2007 White Toyota Yaris Type S Join Date: Dec 2006
what do you mean the tubing is too big for the throttle body?? It looks to me that the stock tubing is 2.5" in diameter, the same as the piping im usuing....
Any more luck on your intake?, I'm working on a homebrew myself and wanted to know how your progress was.
日本人&
I'm wondering where you got all your piping from and how much it cost. I tried running over to Pepboys today to see what piping they had for intakes. They had a good selection, but I had the slightest clue as to what angle I should have the elbox at.
"One seldom recognizes the devil when he is putting his hand on your shoulder." Albert Speer |
| WR Secret Weapon Intake Dyno Tested.. | WRLEO | Performance Modifications | 70 | 05-17-2007 03:00 PM |
| Intake VS modified filter housing | Spades | Performance Modifications | 19 | 03-30-2007 12:30 AM |
| WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! | WRLEO | Sponsors Classifieds Area | 0 | 02-22-2007 10:14 AM |
| Cold Air Intake vs. Short Ram Intake | nevermorez | Performance Modifications | 1 | 01-24-2007 04:25 PM |
