Old 03-02-2011, 06:28 AM   #163
bB2NER
My Box and Her Egg
bB2NER's Avatar
Drives: 05' Scion xB / 08' Yaris 3dr
I just put a piece of black tape over the light when I changed the rims. Didn't feel like cutting wires.
bB2NER is offline   Reply With Quote
Old 03-02-2011, 06:43 AM   #164
Originally Posted by Midnight Drifter View Post
So just... find the brown wire, cut it, splice the side going OUT from the plug unto the white wire and leave the brown wire going INTO the plug capped?
Correct.
Old 03-02-2011, 06:55 AM   #165
mario98c
mario98c's Avatar
Old 05-16-2011, 09:52 PM   #166
auxmike
auxmike's Avatar
Originally Posted by mario98c View Post
CT Scott, is this this the way it's done in an easy to understand pic?
Old 05-16-2011, 09:58 PM   #167
Yes.
Old 05-16-2011, 10:37 PM   #168
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
mmm I should get this done! too much time playing with sound system!
D.
CLA 250, 4MATIC
Old 05-16-2011, 10:40 PM   #169
auxmike
auxmike's Avatar
Yes.
OK then.
SO, this method does NOT require the the light to be off pre procedure OR that the wheels/sensors to be mounted on or near the car before starting, right? Even if you start out with the light on, it does'nt matter this way.
Is this all true?
Thanks!
Old 05-17-2011, 06:36 AM   #170
Originally Posted by auxmike View Post
OK then.
Is this all true?
Thanks!
That is correct. This mod actually just disables the warning light, which is why the initial state before doing the mod does not matter.
The TPWS is completely independent of all other systems on the car. It actually uses legacy ISO-9141 comm, rather than CAN bus, so the ECM doesn't even have the ability to talk to it.
Old 05-17-2011, 07:40 AM   #171
hackenfort
Drives: 10 yaris
CTScott,
Just wanted to say THANK YOU!
This is the first thing I did when I bought my new Yaris a few months back.
Sure beats taking the inst cluster out and covering the led for the light!
so THANKS AGAIN!
Kevin
hackenfort is offline   Reply With Quote
Old 07-31-2011, 06:38 PM   #172
zelig
Drives: as if running for his life.
So the light is the only onboard indicator of TPMS state? Is there a service tool to interface with the TPMS and read/report status? I suppose I'm basically wondering if there's any advantage to tricking the system into seeing a "good" state vs just disabling the warning light.
Also, is there any identifier such as a part number on the TPWS ECU?
I'm really excited to try this!
zelig is offline   Reply With Quote
Old 07-31-2011, 07:04 PM   #173
The TPMS is completely independent of the ECM, but the Toyota Techstream tool can communicate with it via the ODB port. The TPMS is the only system on the Yaris that does not communicate over CAN BUS, but rather just communicates via the older ISO-9141 spec. So, there really isn't any advantage to tricking the system instead.
Old 08-16-2011, 01:29 PM   #174
A-Dingo-Ate-My-Baby
Drives: yaris
info
I did this mod by opening up the tmps module, pulling
the pcb, soldering in 3 wires, cutting one, and using a switch
screwed into the face, as in the pics a few posts earlier
One note:
you can easily pull the tpms pcb by using a small flat blade screwdriver on the
small plastic tabs on the gray tpms cover....
there is no need for any tools other than that. the tpms cover pops right
off and the pcb slides right out. super easy.
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 09-12-2011, 08:13 PM   #175
2mtech
2mtech's Avatar
Drives: 2011 Yaris S 3dr Bayou Blue
Thank you, Scott! Did the no switch option mod tonight; bye-bye light that irritated me all weekend driving through VA
2mtech is offline   Reply With Quote
Old 10-09-2011, 09:00 PM   #176
hwnstyle21
Drives: White Hatch
Thank you for this DIY.
hwnstyle21 is offline   Reply With Quote
Old 10-25-2011, 10:02 AM   #177
keona
Drives: 2008 2 door hatchback
Thank you Scott!!!
keona is offline   Reply With Quote
Old 01-31-2012, 09:21 PM   #178
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Thanks to them, I was able to make mine with a switch.
I'm putting winters on this week, just did the mod yesterday. I still can't find my digital camera, but the pics/schematics shown are plenty to get it done.
Old 04-14-2012, 01:10 PM   #179
auxmike
auxmike's Avatar
I just did this in about ten minutes. You don't need remove the whole black box, remove the connector plug with the wires in it and then carefully pry the clips up on the cover surrounding the connector and remove it. After that the board slides straight out. I just cut one pin lead and soldered it to the one next to it as pictured above. Lights out now! I've been living with that for over four years......
PS It appears the top of the green PC board is conformal coated to protect against moisture and dust. It looks like it's UR vs. the Humiseal acrylic and it's handbrushed on..
Old 08-09-2012, 03:17 PM   #180
CodyTheBody
Drives: 2009 Toyota Yaris 4D
Here's an even easier method that I figured out one day. I just haven't gotten around to writing up a DIY on it:
So this method replaces the very first post of this entire thread? I'd like the ability to switch back and forth between wheels. Put some different rims/tires and had the TPMS light come on and stay on.
CodyTheBody is offline   Reply With Quote
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 05:53 PM
