Old 10-06-2009, 09:36 PM   #1
127.0.0.1
2010 US Yaris 5doorHB, confirmed
I just did post 1 to my 2010 yaris and it works perfectly. I made my own switchbox and will mount near the handbrake.
edit: I just found my new permanent switch. I will get this in the mail, then
cut off the control box I have now, and mount this in the empty switch slot
next to my stereo AUX input.
super sano install for the Yaris. keyboard sized 2-axis momentary joystick
http://www.alliedelec.com/search/pro...px?SKU=9485541
Old 10-16-2009, 06:38 PM   #2
ditso
Drives: still shopping
Noise Reduction Headphone Jack
I really enjoyed CTScott's instructions on how to add cruise control. I haven't purchased a Yaris yet but I'm planning to do so this spring. Since CTScott obviously is a very smart individual, I was wondering whether he could provide instructions on how to add a headphone jack in approximately the same location as the two cruise control switches. The jack would not necessarily need to shut off the speakers in the car--just tap into the sound system. Before someone goes ballistic on how "unsafe" this is, I would like to point out that my drive is very early in the morning on an interstate with very little traffic. I would take the headphones off when driving in serious traffic. Thanks.
ditso is offline   Reply With Quote
Old 10-19-2009, 06:42 PM   #3
127.0.0.1
2010 Yaris 5door Auto, DIY cruisecontrol switch installed. pardon the red sharpie treatment, it needs another coat.
it's teh bomb. the switch action feels like toyota engineered this thing, it really does. easy to hang yer arm off the
armrest and + or - ...and it is precise.
Old 10-19-2009, 07:22 PM   #4
Very cool!
Old 10-19-2009, 09:02 PM   #5
POORSHA
POORSHA's Avatar
Drives: 2008 LB
good stuff!
POORSHA is offline   Reply With Quote
Old 10-25-2009, 11:03 PM   #6
SEALL
Drives: 08’Yaris
hi guys,I'm from China with 08'Yaris 1.6AT 5doors liftback,i have done the CC work just like Vince87'job,but the CC don't work,is it haven't programs in my ECM/ECU? somebody help me~~~~
SEALL is offline   Reply With Quote
Old 10-26-2009, 07:10 AM   #7
Can you track down the electrical wiring diagrams for the Chinese market Yaris? Someone from Europe tried the CC mod and it didn't work. Once I got a copy of the EWD for their market, I found that the CC pin on the ECM wasn't actually used for their market.
Old 10-27-2009, 12:06 AM   #8
SEALL
Drives: 08’Yaris
OK,thanks for all,and do you know how much volts on pin 40?
Old 10-27-2009, 06:21 AM   #9
Pin 40 measures 12 volts with nothing connected to it.
Old 10-27-2009, 10:53 PM   #10
SEALL
Drives: 08’Yaris
thanks! i will check it out,one more question:the Resistors should be 240 ohms/390 ohms/910 ohms and 1/8W or 1/4W? or whether it should be with limits?
Old 10-28-2009, 06:17 AM   #11
Correct for the values. Either 1/8W or 1/4W is fine.
Old 10-28-2009, 09:31 PM   #12
SEALL
Drives: 08’Yaris
Thanks for all,i checked the PIN 40 on the ECM yesterday,but it was no volts on it,so i can confirm that the CC pin on the ECM wasn't actually used for Chinese market.
thank you for all the help.
Old 10-28-2009, 10:59 PM   #13
Maybe you should buy a USDM ECM off ebay. Then, you'll have the only Yaris in China with cruise control.
Old 11-03-2009, 07:45 AM   #14
SEALL
Drives: 08’Yaris
hahahaha~~~good idea!but how much the USDM ECM? and I need to change the ECU or ECM's Program? or install it directly into the in-situ and do not change anything?
Old 11-03-2009, 07:51 AM   #15
I'm not sure about the compatibility, but USDM ECMs can often be purchased for under $100 off ebay. The engine type, transmission type, ABS yes/no, and VSC yes/no are important to match when swapping ECMs. Our USDM ECMs are for 1NZFE and 2NZFE engines. I haven't noticed which engine you get over there.
Old 11-01-2009, 03:09 AM   #16
sabya78
Dear Scott,
Thanks for the update .. I dont think the Yaris in the UAE is European.. I checked up the VIN and it states my car is made in Japan and is ment for the GCC market. I was really looking forward to install the CC ,, is there any other way to do it or any how can I check if the ECU is having the CC function?
sabya78 is offline   Reply With Quote
Old 11-01-2009, 07:52 AM   #17
Originally Posted by sabya78 View Post
Dear Scott,
First, make sure that you are really in pin 40 of the ECM.
Second, what is the part number on the label of your ECM?
Old 11-03-2009, 09:18 PM   #18
SEALL
Drives: 08’Yaris
My yaris's engine is 4ZRFE,1600cc,Super ECT 4-speed AT,ABS yes,VSC no,maybe only have the 1600cc engines of the Chinese market.
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
