Old 06-09-2010, 09:14 PM   #1
metalshark
MetalShark
Drives: 2008 Yaris LB
Header Wrap
I did header wrap on my e-bay stainless header two years ago and cut under hood temps. Pick up stainless steel tie-wraps from Harbor Freight to hold the insulation on your header. My critics predicted I'd burn through the header by now but it hasn't happened (yet).
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 06-07-2010, 03:59 PM   #2
swidd
Drives: Yaris HB
I just did this, after finding this thread today.
$1.92 at Lowes for 6 feet of self-adhesive 3/4" Inside Diameter tube.
$3.19 at Walmart for 200F duct tape (low quality, but will probably do).
I don't have a temperature meter, but will say the effect on the a/c air was noticeable, but not extremely colder. I only covered the portions on the low pressure line (top) that were easily accessible (and straight), and will spend more time later to cover all the little spots...
Thanks for this DIY!
Old 06-07-2010, 04:00 PM   #3
swidd
Drives: Yaris HB
Also, holding my hand over the tube feeling the radiant heat from the exhaust, I don't see how it can end up burning or melting. Granted its a windy day, but immediately after shutting down from a drive, it wasn't too warm to touch.
Old 06-08-2010, 06:13 PM   #4
Echostatic
Drives: 2007 Toyota Yairs
Welp, I made the video as planned yesterday, but immediately after doing so, I figured out a much better and less butt-ugly way to wrap the pipe; I redid it after work today without the camera running. So, I'll throw up a video/pic mix instead shortly.
Echostatic is offline   Reply With Quote
Old 06-09-2010, 08:05 AM   #5
Echostatic
Other.
Old 06-09-2010, 10:07 AM   #6
That video was INTENSE!!!!
Old 06-09-2010, 12:22 PM   #7
Echostatic
*shrug* Now it's gone.
Old 06-09-2010, 12:47 PM   #8
wHy?
Old 08-11-2010, 04:27 AM   #9
birdman
Texas. That explains it.
Old 05-09-2011, 03:53 PM   #10
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Thumbs up
best DIY for summer season
ricepower is offline   Reply With Quote
Old 05-15-2011, 06:01 AM   #11
hayden
Drives: asd
I did this mod recently and I can't say I really notice a difference. It might be cooler but if someone did this mod and didn't tell me I doubt I would ever notice.
hayden is offline   Reply With Quote
Old 05-15-2011, 09:33 AM   #12
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
this will keep me busy for a bit get my mind off other upgrade...cool..i meant that literally...lol
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 05-15-2011, 10:39 AM   #13
swidd
Drives: Yaris HB
I've now had this mod for a year; a/c blows very cold, and begins blowing cold air almost instantly, much faster than without this mod. I had it on during winter, didn't run the a/c, but had no problems with air box freezing or anything like that. The tube wrapped in the heat resistant duck tape is holding up very well; no melting marks or dis-colorization.
Strong recommend!!
Old 05-15-2011, 12:55 PM   #14
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Well, since I'm off to home depot right now anyways I'm going to look at into this mod. If I do it I'll wrap the insulation in aluminum tape...
-Type 07 FFL-
My odometer 03/11
Old 05-20-2011, 03:43 PM   #15
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Just reporting that I've done this and it does make a difference. The A/C feels a lot cooler and gets cool a lot quicker than before.
My g/f doesn't like it though she gets too cold now lol.
devinlamothe is offline   Reply With Quote
Old 06-07-2011, 01:43 AM   #16
jonathankoji
jonathankoji's Avatar
Drives: 08 Yaris S Sedan
Just finished doing mine tonight actually
Got most of the line. Tried using this stuff and it was horrible
So I ended up using the 97cent foam ones + metal tape.
jonathankoji is offline   Reply With Quote
Old 06-07-2011, 09:08 PM   #17
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I just wrapped mine. What I thought was a 1 man, 5 minute job tuned into a 2 man, 15 minute job. I used 1/2 in. wrap instead, it fit nicely when it was straight, but at the bends it was a pain. Some of the bends aren't fully wrapped, I couldn't get it all the way around. C'est le vie.
EDIT: And yes, JUST in time for summer!
Old 06-19-2011, 05:57 PM   #18
p123456789
Drives: 07 lb jeep tj
Am I the only one who thinks the yaris a/c works very well even down here the florida humidity?
p123456789 is offline   Reply With Quote
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
