Old 05-30-2010, 11:49 AM   #163
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by Alien Mantis View Post
And why would you want to force the tweets to play lower?
Wouldn't you just let the midrange drivers handle those freqs?
I might know a little about how "audio" works, but I am obviously not experienced with tuning a high-end competition system.
So I ask these questions just to build on my own limited knowledge.
well, there are a ton of variables...
If it was possible to make a perfect sq system. you would only have 1 speaker per channel (ie, left speaker, right speaker) and it would be able to play from about 15hz up to 25khz. Problem is that it is VERY difficult to make full range speakers. There are 10 octaves of sound in the 20hz-20khz range. the best "full range" speakers on the market currently are 3"-5" units and they are only capable of playing 7-8 octaves. Most struggle to play above 10khz, and most can't play well below 80hz.
The reason why a single speaker is awesome is because all the sound comes from one point, which means when you do your imaging/staging/aiming portion of your install, you'll have a much easier time. You don't have to worry about weird rainbow effects (highs sound like they are up high like head level, but mids sound like they are at your feet).
Going with less speakers also reduces the amount of crossovers you need. Having good crossover(s) makes for about 60% of the total install quality in my opinion. Even more important than enclosures designs, quality drivers, and sound deadening.
So, if you can limit how many speakers you run, you make your install easier. The simplest answer possible is always the most reliable one, and usually the best overall.
Because of the current limitations of speakers, there are some problems introduced however.
The higher the frequency a speaker plays, the more directional it becomes. Being very directional isn't a problem, UNLESS your speakers aren't aimed at your head. If they are aimed some other place, then you will have dips in your frequency response
Another issue with having speakers play most of the frequencies is that it requires a voice coil with a very low LE (which is hard to do and still have good power handling).
Another is that it requires more linear movement (x-max) from the driver. Without a linear motor, a speaker will start to distort very quickly. Multiple linear motor technologies have been around in subs for over 10years, in fact there are a few that have been around a very long time. However, they usually jack up the price of the speaker and thus aren't widespread. There are also some technologies that only work for subs, whereas there are some that have even been used in mids & tweets. The more frequencies you require a speaker to play, the harder it has to work... Linear motors allow speakers to play more frequencies at once before distortion sets in.
So, why would you want your tweets to play low.... well, SQcomp I believe is trying to stay away from that. "Low" for a tweet would be playing anything below 5khz. Normal crossover points for a 6.5" component set would be 2khz-5khz (usually in the 2.5-3khz area tho).
In some installs however, if you can get your tweet to play low enough you can limit how many speakers you have, and still be able to have a very good frequency response in a system that is able to get loud before distorting.
Take a look at HLCD's or compression drivers.... there are the tweets used in club speakers. There are a few of them used in car audio. They are generally able to play around 800hz up to about 16khz... All you really need is a mid with a fairly strong midbass, and a sub, a band of eq around 18-20khz and you are set.
It all comes down to getting the fequency response desired, and the staging/imagine you want. And limiting the amount & complexity of your crossover(s) has a huge impact on how hard of a job you'll have.
Old 05-30-2010, 12:09 PM   #164
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 05-31-2010, 11:31 AM   #165
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
I though I knew it all! LOL
(o:
CLA 250, 4MATIC
Old 05-31-2010, 04:28 PM   #166
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 05-31-2010, 04:38 PM   #167
derickveliz2
Derick,To answer your first question about trial and error, the answer is "sometimes". It depends on what we're doing. I know what has worked in the past for me, I know the general fundamentals. This is where my need for more experience leads me to try other things and lean on the experience of the shop owners who have been doing this since I started in the early 90's.
Thanks, spcomp!
I've been reading the owners manual for the DEX-P99RS, I think it's going to be a "RELIGIOUS EXPERIENCE" for me, I can't wait.
D.
CLA 250, 4MATIC
Old 06-01-2010, 02:31 AM   #168
goku87
goku87's Avatar
Drives: Black HB
You're killing me with the lack of pictures...
Old 06-01-2010, 12:54 PM   #169
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-01-2010, 05:53 PM   #170
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Seriously though, I have a lot of pictures. All three amps are up, by the end of today they should be powered. I'm waiting on the quote for the Audison Thesis Violino tweeters (yes, I gave it away), and my flippin' mix on the fleece was to cold. It's still kicking 12 hours later.
Realistically today, there will be power to all the amps, and answer for the replacement tweeters, the kicks should be ready to be started, and the backup sensors *should* be done.
Edit:
The ground point for the 4.5 "stripped out" when I attached all three grounds. In the pictures I'll put on tonight you'll notice that I made a new ground bolt from the outside in...like we did at Freightliner oh so long ago.
I never trusted self tapping screws, I always did the nut/bolt routine for grounds. Are you going to mix up some more resin nice and hot and lay it over the top of your cold mix to heat it up?. Nothing worse than cold resin.
Old 06-01-2010, 07:23 PM   #171
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-01-2010, 10:20 PM   #172
goku87
goku87's Avatar
Drives: Black HB
Mwahahahaha, excellent stuff. It's coming together really really well.
Old 06-02-2010, 03:33 AM   #173
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-02-2010, 03:36 AM   #174
derickveliz2
Lets see!!!!
CLA 250, 4MATIC
Old 06-02-2010, 04:53 AM   #175
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-02-2010, 04:58 AM   #176
derickveliz2
Thumbs up
W O W . . .
If I could just do something like that
CLA 250, 4MATIC
Old 06-02-2010, 05:28 AM   #177
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-02-2010, 07:34 PM   #178
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
so whats your style for doing glass work on that sub box...
So far you've done skeleton, then fleece & resin... are you going to then do mat on the inside or outside of the fleece, or do you do something else?
I've done a few glass projects myself, but it is always nice to see how other people do their projects.
Old 06-02-2010, 07:54 PM   #179
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-04-2010, 10:55 AM   #180
goku87
goku87's Avatar
Drives: Black HB
audiogasm
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
Micro Image underpanel install DIY cali yaris DIY / Maintenance / Service 27 08-29-2009 09:48 PM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
where can i install these power locks? songa New England 1 12-04-2008 12:41 PM
