Old 06-21-2010, 12:26 PM   #163
ChilliwackGuy
WCOAST CANADIAN DRIVER!!!
Drives: 2010 Hatch 5DR - AUTO/AC
In Chilliwack, BC, Canada - where I bought my new 2010 Yaris Hatch 5 dr - I was told that all I had to was bring it in every 8000KM - and it'd run perfect thru to 200,000 KM's. (I was also told to budget about 1.9 cents per KM for potential maintenance.)
ChilliwackGuy is offline   Reply With Quote
Old 06-21-2010, 12:32 PM   #164
Kal-El
Kal-El's Avatar
Originally Posted by brg88tx View Post
i hate to say this, but frankly i don't believe these "yaris owners" who claim a failed water pump. my reasoning is i read all 371 reviews for the 07 yaris on edmunds and not one mentioned this. yet we have many "yaris owners" popping up out of the woodwork all claiming this all of the sudden.
one dude has over 400,000 miles on his 07 yaris on the original water pump.
I don't believe it either. Sure it's possible, but I'm certain this isn't a common issue by any means but rather a rarity. There are a number of high mileage Yaris's that have reported no issues. Mine is at 85,000 miles and shows no sign of wear and is repair free.
Old 06-21-2010, 09:10 PM   #165
Lucas13
Drives: 07 Yaris LB
I know is hard to believe that such simple part like a water pump will fail so soon, I almost don’t believe it either when this happened to my yaris, most of the cars know days can do more than 120K w/o replacing the water pump but on 1nz-fe its common, even the prius has the same problem, I was told by the mechanic at the Toyota dealer that they replace them all the time.
The yaris is not the first car I owned and surprisingly it’s been the one with more defects. When I traded my 350z for the yaris I did it for gas economy and good quality, the Z was amazing in quality but I needed a 4 seater.
Here are few pictures that show my WP leak and know my GB
Lucas13 is offline   Reply With Quote
Old 06-22-2010, 08:38 AM   #166
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
I had that same pink crust on my WP, and the typical pink marking on the underside of the hood. I believe it had only leaked for a short amount of time and stopped somehow, as it was just all crust, not wet at all, but I went ahead and replaced it anyway. I also changed out the long life coolant to regular stuff. I hope I did the right thing there, as the long life coolant seems to be the problem for these water pumps...
goliath1812 is offline   Reply With Quote
Old 06-22-2010, 10:50 AM   #167
Kal-El
Kal-El's Avatar
What is the general cost of replacing the water pump on a Yaris at a dealer or typical shop (with labor)?
Old 06-22-2010, 11:26 AM   #168
bronsin
bronsin's Avatar
I think its pretty premature to come to that conclusion. The coolant you mention doesnt appear to be affecting the wp s of other cars.
Old 06-22-2010, 01:25 PM   #169
goliath1812
If that's the case, then great. But from what I have read on here with the W/P problems, that was the main thing that seemed to be the problem. This is all second have from what I have read.
Old 06-23-2010, 01:52 AM   #170
Lucas13
Drives: 07 Yaris LB
The coolant may be a good reason for the WP to go faster, probably Toyota pink coolant doesn’t lubricate the pump the way it should, if that’s not the case the 1NZ-FE water pump is made with cheap materials and wear fast...
Old 06-23-2010, 09:59 AM   #171
bronsin
bronsin's Avatar
Its a mysterey to me why this happens. ECHOs had the same water pump/coolant and I NEVER saw a post about the wp going.
Old 06-23-2010, 11:57 AM   #172
mimelio
Drives: NONE
Exclamation
Its a mystery to me why this happens. ECHO's had the same water pump/coolant and I NEVER saw a post about the water pump going.
+1
mimelio is offline   Reply With Quote
Old 06-23-2010, 01:50 PM   #173
STC
"LibertyRides!"
STC's Avatar
Just turned over to 5,000 miles on my way to work this morning... almost six months old! Only a routine oil change so far...
*NO PROBLEMS*
Cheers!
~ Mark ~
Old 06-23-2010, 04:27 PM   #174
Vioz
Drives: 2008 Yaris Sedan
Send a message via AIM to Vioz
I'm hitting 60k miles never had a problem regular synthetic oil changes, used only premium 93 gas only since day 1. Have the NST pulley set as well on the water pump, might have to replace it soon since a nice groove is showing up on my pulley.
a.k.a. "Aothachos"
Vioz is offline   Reply With Quote
Old 06-23-2010, 05:37 PM   #175
bkrownd
bkrownd's Avatar
Drives: 2010 Yaris "5-door"
"premium" (as in price) gas in a Yaris? Why on Earth?
bkrownd is offline   Reply With Quote
Old 06-23-2010, 08:41 PM   #176
Kal-El
Kal-El's Avatar
You're just wasting money on 93. The Yaris is tuned for regular 87. Running higher may actually have a similar adverse affect as running regular in a premium car.
Old 06-23-2010, 09:48 PM   #177
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
51,500k miles/2.5yrs and going strong. Still just one repair on an axle seal @ 13k miles. Running 10k synthetic oil intervals with 5k filter intervals. Stock everything, only mods are tints, subs, and scanguage. Should be close to 60,000 miles by september. My car is about to become a work tool, so i'll probably jump from doing 20k a year to 25-30k a year.
Old 06-26-2010, 03:58 AM   #178
rslyk
Drives: 2007 YARIS 3 DR HATCHBACK
OTOWNYARIS....If you have not seen my post about the TSB EG048-07 you might consider looking at it. This TSB outline the replacement of the defective fuel tank
fillerneck cover....if the failure occurs outside your warranty period the canist/filter parts
cost is near $1000 from your pocket..... Check your VIN # and see if it applies to you...
it happened to me the FIRST time I took a 2 hour drive in a constant rain...
rslyk is offline   Reply With Quote
Old 06-26-2010, 12:15 PM   #179
mkaresh
Drives: Mazda Protege5
We have updated results for the Yaris to include owner experiences through March 31, 2010. In terms of repair trips per 100 cars per year:
2009: 20 participants, no repairs reported yet
2008: 7
2007: 20
All are very low, and much better than average.
We have two additional statistics, "Nada-odds" and "Lemon-odds," to indicate the percentage of cars with no repairs in the past year and those that required 3+ trips to the repair shop.
In the case of the Yaris, the percentage with no repairs is about 87 for the 2007 and 92 for the 2008, and the percentage of lemons is less than one for both years.
A big thank you, once again, to everyone who has been helping. We'll have further updates in August and November. With more participants, we could provide more precise information and provide all three stats for all model years. Especially need more 2009s and 2010s.
To see how competitors compare, and to sign up to help improve this information:
Toyota Yaris reliability comparisons
truedelta.com
Vehicle reliability, fuel economy, price comparisons
mkaresh is offline   Reply With Quote
Old 08-03-2010, 11:24 AM   #180
mkaresh
Updated stats in a couple of weeks.
Sample sizes are small for the 2009 and up--especially need more participants for these years.
To help provide better information on your year:
Car reliability research
truedelta.com
