Old 04-20-2010, 06:35 PM   #1
STC
"LibertyRides!"
STC's Avatar
I appreciate this Forum Thread. I’ve been using DFCO all the time since I read this thread. FE improvements have been incredible. Presently, I’m near making the 50 mpg range. This is a goal of mine to reach, before I use more advanced techniques.
I have a silly question? Does any one know?
There is a long mountain grade I drive every day. I let off the gas and use DFCO when I go down it. The long grade starts to level and my vehicle’s RPM drops down to around 1,000 – 1,100 RPM. But, then the grade steepens quickly causing my RPM to go back up to over 1,800. My MPH does drop down when I reach 1,100 RPM, but there are hardly any drivers, so I can do this...
Does DFCO kick back in automatically when the RPM goes back over 1,100? Or do you have to give it some gas (accelerator tap) over 1,100 RPM and then let the grade take over again? Is the Yaris ECU software designed to do this automatically? When the RPM gets just below 1,100 RPM and then climbs up again, I do nothing... just coast in the gear till I have to slow down and come to a stop at the bottom of the mountain.
Cheers...
~ Mark ~
Old 06-29-2010, 08:28 AM   #2
micahsyl
Drives: 2010 yaris 2 dr hb
Send a message via AIM to micahsyl Send a message via Yahoo to micahsyl
um,,, i think this is called "coasting" people have been doing it for decades lol i like the special name for it now... DFCO great marketing ploy!
micahsyl is offline   Reply With Quote
Old 06-29-2010, 10:24 AM   #3
BailOut
Steals terrorist's lunch
BailOut's Avatar
For decades, every time you took your foot off of the accelerator fuel still trickled into the carburetor or sprayed through the injectors at least at an idle-level flow. What has changed over the last decade is that carburetors have gone away and some car's computers are smart enough to turn off the injectors completely when you're in a "coasting" state.
That's DFCO - no fuel flowing at all when you coast in gear. In 65,000 miles I have never lost a fuel bar in the downhill segments of my commute (2,500 feet of elevation drop on the way to work and 4,500 feet of drop on the way home).
- Brian
Share the Road
Old 06-29-2010, 11:04 AM   #4
STC
"LibertyRides!"
STC's Avatar
Engine braking "coasting" (Deceleration Fuel Cutoff - DFCO) or neutral "coasting"? Two different coasting arenas. With the former you coast with the car in gear while the latter you manually throw the car into neutral and coast.
Today with engine braking coasting the ECU turns off the fuel injectors... the axles turn the tranny... the crankshaft turns ... the pistons then turn. Nothing new... most cars with a computer are capable of this.
Yes... neutral coasting has been done for many decades, since the advent of disc brakes some 40+ years ago. Could not do that with an old Model T...
Cheers!
~ Mark ~
Old 07-07-2010, 12:13 AM   #5
advocate
Drives: car
If the injectors are off then the car isn't burning any fuel, I get that.
But the car seems to still make a lot of noise. This is amplified by my tanabe exhaust I'm sure but my point is it sounds like the engine is still running even when coasting in what I believe to be DFCO.
'07 5 speed btw. Any ideas?
Old 07-07-2010, 02:58 AM   #6
BailOut
BailOut's Avatar
While no fuel is moving air certainly still is, meaning that in the DFCO state the engine is a compressor rather than a combustor.
- Brian
Share the Road
Old 07-07-2010, 03:30 AM   #7
advocate
Drives: car
do the spark plugs still fire as well?
Old 07-07-2010, 09:16 AM   #8
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Yes.
Old 07-12-2010, 01:40 PM   #9
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
I've been doing the rollercoaster ride where you go slower up the hill and go faster down the hill while trying to maintain the same pressure on the gas pedal. Is it more fuel efficient to go down a steep grade using DFCO? This is where a ScanGauge would probably come in handy.
KrazyDawg is offline   Reply With Quote
Old 07-12-2010, 02:11 PM   #10
Yaris Hilton
Smile
That's what the hypermilers call "Driving With Load." Yes, if you're going down a steep hill you'll back off of the gas and it will go into DFCO.
Old 07-12-2010, 05:38 PM   #11
ChilliwackGuy
WCOAST CANADIAN DRIVER!!!
Drives: 2010 Hatch 5DR - AUTO/AC
I've been "coasting" or using "DFCO" techniques throughout my 13 years of driving - and mostly on 6 days a week commuting - 250KM daily totals!
The key for me has always been to minimize brake usage - and instead - focus on lifing and pressing my foot on the gas pedal. (I make it a game to coast to a red light!) Yeah - my passengers get annoyed but I have saved SO MUCH gas.
ChilliwackGuy is offline   Reply With Quote
Old 07-31-2010, 11:59 PM   #12
imjustagirl8_05
Drives: 2007 Toyota Yaris AT
Let me get this straight.
So I just found this site and it's really cool. I am learning a lot about my Yaris! I bought my car in Jan 2007, I had no idea there were earlier models! I'm not sure if my car is 4 speed, but I think it is, since it's AT. Does this mean I have the DFCO? I haven't tested it out the way you described yet, but I definitely will! I just wanted to ask, is the ignition only to be turned off to test whether I have it? If I do have it, I would just have to lower a gear (like to 3) to get into DFCO mode, and it would stop using gas while slowing my car? Sorry, I'm slow, I had to read this post three times and search some terms to get it, but please let me know if I've understood correctly. Thanks!
imjustagirl8_05 is offline   Reply With Quote
Old 08-01-2010, 12:59 AM   #13
Maxh91
Maxh91's Avatar
Drives: Red 3 Dr HB 2008 Auto.
-Yes you yaris have DFCO
-As your yaris is a 2007, you need to be in 3th or lower to activate the DFCO.
The 2008 and newer can do DFCO in every gear.
-You car need to be in gear (L,2,3) to activate the DFCO AND you need to be above 1100RPM
Maxh91 is offline   Reply With Quote
Old 08-01-2010, 01:00 AM   #14
Yaris Hilton
Smile
Sometime in the mid-2007 model year they changed so the DFCO works in Drive. About the time yours was made, IIRC. The 2007 I originally bought for my wife has DFCO in Drive. No need to downshift. Don't switch off the key. While cruising along, let off the gas. .5-.7 second later, you'll feel a gentle deceleration as the fuel cuts off.
Old 08-01-2010, 01:05 AM   #15
Maxh91
Maxh91's Avatar
I did not know about the mid-2007!
@imjustagirl8_05 I feel the DFCO after 1 or 2 second(AT). Just need to look at your RPM and you will see it slowing.
Old 08-11-2010, 09:56 PM   #16
imjustagirl8_05
I don't have an RPM gauge.. at what speeds will it be wise to use DFCO? I have been using it, but I'm not sure if it's pointless after I've already slowed.. what speeds are typically above 1100 rpm?
Old 08-01-2010, 07:54 AM   #17
sickpuppy1
Drives: 2010 Yaris Sedan
I have a 2010 sedan w/AT and as much as I try to feel anything, I cant notice a thing when say I'm cruising to an exit ramp on the highway. I try to let off and notice DFCO but don't notice a thing. I'm curious, because if I keep it in gear, I can let off gas a little more than a quarter mile before the ramp and coast to the light at exit. If I just put it in neutral, I can coast at least a 1/2 mile or more and still have to use the brakes to stop. I never notice it kicking in and it seems I possibly would save more fuel by just coasting. Am I wrong here?
Old 08-01-2010, 07:57 AM   #18
sickpuppy1
That being said, I don't know why, but I always wonder if putting it in neutral and coasting is bad on the tranny, any thoughts, remember its an AT
low gas mileage? yrsdrgn General Yaris / Vitz Discussion 30 01-17-2019 03:26 AM
Synthetic oil MPG boost since change Yaris Dick General Yaris / Vitz Discussion 29 09-15-2007 08:15 PM
Increased MPG or HP anyone???? slvryaris Performance Modifications 55 05-27-2007 10:49 AM
MPG trackers acrbill General Yaris / Vitz Discussion 11 01-01-2007 07:34 PM
