Old 09-03-2010, 09:33 PM   #1
sleey0
Drives: 2008 Yaris LB
Kimona!!
You are like the tire God around here. lol :D
Thanks, bro and I will def post some pics when my setup is complete.
sleey0 is offline   Reply With Quote
Old 09-04-2010, 10:51 PM   #2
sleey0
One more for you kimona:
17x7 +38mm ET enkei ev5's.
Recommend the OEM 205/45 or 205/40 (or anything else)? I was told the 205/40's should be fine on less than 2" drop.
THANKS!
Old 09-04-2010, 11:27 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
THANKS!
With 7's, ET38, I generally prefer 195mm rubber, but with 17's you don't have much choice but to run 205's.
I would prefer 205/45's with your 1.5" drop; however, with ET38-40, I'd probably run 205/40's... a tyre size I really don't like too much.
If at all possible, choose 7's with ET42 or greater; they just work better up front for a simple bolt and go application.
Old 09-04-2010, 11:40 PM   #4
sleey0
Yeah, I know. The only reason I am even thinking about the 38ET's is because of price.
Can get an entire set of wheels for $300 and they are in excellent condition with minimal pitting.
As opposed to the RP03's that will run at least $1k without tires. lol
Old 09-05-2010, 06:12 AM   #5
kimona
kimona's Avatar
Yeah, but the dual-drilled Enkei EV5's are rather unsightly IMHO.
Old 09-05-2010, 06:31 PM   #6
sleey0
I thought they look pretty nice. Guess to each his own.
Old 09-05-2010, 07:34 PM   #7
kimona
kimona's Avatar
I'm just not a fan of any dual-drilled road wheels.
Old 09-06-2010, 10:18 AM   #8
sleey0
So the holes bother, not the design of the wheel.
Old 09-22-2010, 01:06 PM   #9
nickstamat
Yaris Lunatic!
Drives: Yaris 1.33L (1NR-FE) 3dr 6MT
Hello guys, I need a little help here, because I did not come with an answer while searching.
Reference wheel fitment is this one (offered by TTE, so it is a perfect fit for the Yaris): Picture
Specs for the above pictured wheel are: 16x7" and ET45.
So, having in mind that tire size will definitely be 195/50/R16, which is the lowest offset that the wheel should have?
For example, the Work CR-Kai is 16x7" with ET44, which would fit perfectly, but the O.Z. Ultraleggera has ET37. Would ET37 be OK with the specified tire size?
The car is currently not lowered, but it might be lowered (no more than 1.2") in the future.
Thanks in advance!
nickstamat is offline   Reply With Quote
Old 09-22-2010, 02:46 PM   #10
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thanks in advance!
No problems after I took the 10 mm spacers !
O.Z. Ultraleggera - 195/50/R16 - ET37
CLA 250, 4MATIC
Old 09-22-2010, 03:28 PM   #11
nickstamat
Yaris Lunatic!
derickveliz2, you have a very nice sedan
With ET37 wheels and 10mm spacers you actually got an effective ET27 (if I am not mistaken) and you had no problem with that? Sounds weird!
Old 09-22-2010, 03:46 PM   #12
derickveliz2
I did have rubbing issues with 10mm spacers. without them no more rubbing.
I'm sorry I should have been more specific!
NO spacers = NO rubbing
D.
CLA 250, 4MATIC
Old 09-22-2010, 04:02 PM   #13
nickstamat
Yaris Lunatic!
D.
Ok, now I get it!
I also hope that the hatchback (which is what I have) has the same space under the fenders as the sedan!
Thanks for helping!
Old 09-22-2010, 05:13 PM   #14
kimona
kimona's Avatar
16x7, ET37, 195/50/16 will be a good fit. ET37 is the lowest offset I would trecommend with 195's.
Old 09-23-2010, 11:36 AM   #15
derickveliz2
kimona is right on the dime! also if you consider lowering your car, the front wheels get very close to the fenders. If you are planing to lower your car by a lot, be aware of the limits with ET37
2 cts.
CLA 250, 4MATIC
Old 05-22-2012, 11:53 PM   #16
CueBall
Ruler of the free world
Drives: 09 Yaris 2D HB
I just got some 15x6.5, ET37 wheels.. Want to put 205/55R15's on them.. Will this be ok? What about a 205/50R15?
CueBall is offline   Reply With Quote
Old 05-23-2012, 01:12 PM   #17
33OH
Drives: '08 Yaris
Either tire will work well.
The 205/55/15 will have a more cushy sidewall, better ride, etc.
The 205/50/15 is closer to stock height, and will handle better.
Depends on what you're looking for.
Old 09-23-2010, 08:29 AM   #18
nickstamat
Yaris Lunatic!
Thanks kimona! This will help me end up somewhere...
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
