Old 05-10-2011, 11:35 AM   #1819
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
thats pretty badass
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 05-10-2011, 11:26 PM   #1820
Hershey
The ECO is about 1 m.p.g. less than the calculated gas mileage , could very well be 42 m.p.g.. Set at 94 , have to reset to 95 . Mostly 2 people , tires at 35 p.s.i. , VALERO 87 w/ 10% ethanol , and average speed of 50 . Not bad , so far . This is the '08 auto sedan .
Old 05-13-2011, 01:49 PM   #1821
bkrownd
bkrownd's Avatar
Drives: 2010 Yaris "5-door"
getting to go downhill for long stretches helps gas mileage immensely.
those are the ideal conditions I'm referring to. :) I usually drive up the mountainside in the morning and coast downhill in the evening.
bkrownd is offline   Reply With Quote
Old 05-13-2011, 11:29 PM   #1822
Hershey
Same here , about 2 mile climb up a very steep hill 5 or somtimes 6 days out of the week .
Old 05-14-2011, 09:51 PM   #1823
Hershey
The car got 40.77 m.p.g. calculated , while the ECO read 40.6 . Going to leave the ECO at 94 . That way it's actually doing better than the ECO overall m.p.g. display . It took 8.621 gallons of SUNOCO 87 w/ 10% ethanol at 1 click . The trip A was 351.5 miles . New Continental Pro Contact Eco Plus tires set at 35 p.s.i. . Rides , handles much better and a bit quieter with these tires . Gas mileage seems to be the same as witht the Potenza RE 92 .
Old 05-15-2011, 11:13 PM   #1824
STC
"LibertyRides!"
STC's Avatar
Filled up Friday the 13th! Pleased that I was able to break 50 MPG the first time with ethanol gas. I had a 300 + mile trip on this tank!
Gas Tank mile increments (ethanol gas used):
1st Bar drop (8/8) > 120 mi (120)
2nd Bar drop (7/8) > 60 mi (180)
3rd Bar drop (3/4) > 60 mi (240)
4th Bar drop (5/8) > 60 mi (300)
5th Bar drop (1/2) > 65 mi (365)
6th Bar drop (3/8) > 50 mi (415)
7th Bar drop (1/4) > 70 mi (485)
8th Bar drop (1/8) > 0 mi (485)
Tank total : 485 miles
Fuel used: 9.195 gallons
MPG: 52.746
Cheers!
~ Mark ~
Old 05-17-2011, 07:50 AM   #1825
malibuguy
Obsessed with 1.5L
got 51.98mpg last tank...i kinda killed some of it on my last commute home, i kinda had to rush to catch a store before it closed & i got out of work late...but this proves the car prefers the stock exhaust for best fuel economy
-96 Tercel 4dr
Old 05-18-2011, 12:36 AM   #1826
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Compared to what? I can pretty much guarantee there are exhausts out there that will get better gas mileage. And then there is always Unobtanium.
Colin Chapman disciple
Old 05-18-2011, 08:20 AM   #1827
STC
"LibertyRides!"
STC's Avatar
Very nice, malibuguy!
I took a 300+ trip on that gas fill (52.746 MPG) and drove 45-50 MPH on rural highways and some open interstates. I was suprised that I was able to get over 50 MPG on the tank using ethanol now. With all my other + 50's I was using non-ethanol. I changed my driving technique a bit to compensate for the loss of energy using ethanol gas. I also use a stabilizer for the ethanol...1/2 to 1 oz. You get around 1-3 MPG less using ethanol blend than RBOB gas. On this present tank I'm taking another shorter trip this week. So far my first 'bar' I got 120 mi and the second was 70 mi! Better than last fill-up. We will see if I can get two in a row...
Cheers!
~ Mark ~
Old 05-18-2011, 08:48 AM   #1828
malibuguy
Obsessed with 1.5L
compared to the 49 & 50mpg i was getting in better conditions with my custom full exhaust...when your barely using any throttle & staying below 2700rpm...your not pushing that much airflow
i thought i was going to pick up mainly from running a 100cell race cat versus the 2 400cell cats our cars get...i guess i was wrong
that being said...the car was definetly faster on the top end the few times i did floor it with my custom exhaust...but i didn't buy this car to race it
-96 Tercel 4dr
Old 05-18-2011, 12:29 PM   #1829
why?
why?'s Avatar
Drives: Yaris LB
Ah, that is not surprising then. Most exhausts around are meant for the high end, just like most other go fast goodies. Finding parts that will help the low end for a car like ours isn't easy.
Old 05-19-2011, 07:59 AM   #1830
malibuguy
Obsessed with 1.5L
i was thinking about switching out my main muffler for a DynoMax VT valved muffler...but fuck it, i'm just going to keep the car stock
-96 Tercel 4dr
Old 05-19-2011, 08:32 AM   #1831
Idahotom
Drives: 2008 5 sp. LB
Also same here. I routinely can drive into Inkom and get 70+ mpg, it's 1,000' below. It's that long pull back up to get home that gets less then 20 mpg. Still, when I get home, it's in the 40's.
Idahotom is offline   Reply With Quote
Old 05-19-2011, 12:26 PM   #1832
NZ-FE Vios
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re
Owned the car for less than two weeks, I had a small opportunity to test out nearly all Highway mpg, I tried to stay below 2500rpm and managed
119.7miles at 2.366gallons = 50.59mpg
NZ-FE Vios is offline   Reply With Quote
Old 05-20-2011, 12:58 AM   #1833
why?
why?'s Avatar
Drives: Yaris LB
odds are everything in the market is going to hurt the bottom end. I think there was an intake that actually added to the bottom end, but that's it. Odds are everything else is going to hurt gas mileage without thousands of hours of research and development.
Old 05-21-2011, 08:03 AM   #1834
tire
Drives: 2007 Yaris Sedan, 4-spd auto
2007 Yaris Sedan (base) auto (gross) 55k mi
37.34 mpg 30% street, 70% highway
tire is offline   Reply With Quote
Old 05-21-2011, 08:54 AM   #1835
malibuguy
Obsessed with 1.5L
your telling me stuff i already know, i do this for a living
-96 Tercel 4dr
Old 05-21-2011, 02:47 PM   #1836
sickpuppy1
Drives: 2010 Yaris Sedan
Woohoo, a new best for me. I try a little, but not too much and got 43.88 last tank. Way to Ruby!!( Cars name....Mediterranean Mica red, in Kansas..kinda looks like ruby slipper.....)
