Old 11-20-2011, 10:17 AM   #1945
sickpuppy1
Drives: 2010 Yaris Sedan
I got a new set of Hanook H727, finally got rid of the Goodyear LS factory clunkers, and thought,I just filled up about 30 miles ago, so let me see how they do with standard 32 psi vs my normal 40 psi. So I did 38.8 mpg and thought, not bad! I got home after fill up and decided to go back to my 40psi to see what happens. Pulled out the trusty tire gauge and I'll be danged if they weren't all at 25 psi! I was ticked! Used both of my tire gauges to verify. Stupid installer! But it made me more impressed with the tires. Also explains part of why they rode so much smoother too,lol
Old 11-20-2011, 07:31 PM   #1946
digitalrain
Drives: 2011 yaris rs
How many miles did you wring out of the Goodyears? Pretty amazing MPGs for 25psi!
digitalrain is offline   Reply With Quote
Old 11-20-2011, 08:32 PM   #1947
Hershey
Good timing catching that bar in between blinks,lol
Here's the no bar and bar . As for tire pressure , always check the pressure after getting new tires or exchange of seasonal tires . Also , make sure the wheel covers are on correctly and snug . Usually do these right at the dealer lot . One time the salesman seen me checking tire pressure and says in a nasty tone " what do you think you're doing " . I replied , " checking the tire pressure " . Like I don't have a right to do so . Next time will check these things a block away so not to pee off anyone .
Old 11-20-2011, 10:50 PM   #1948
sickpuppy1
Only about 33000. Which is more than some, less than others. And realistically, with another rotation, they were good for 3-5000 more. But winter is right around the corner and I didnt want to chance it. If ya wait till it snow you wait forever. November around here you dont know what to expect.
Old 12-04-2011, 11:14 PM   #1949
Hershey
'08 base model Yaris sedan w/ 4 speed auto :
Eco-Meter : 40 m.p.g. overall ( set @ 95 )
Calculator : 39.82 ( 391.6 mis. / 9.834 gals. @ 1 click )
Fill of Valero 87 w/E10 . Previous fill was GULF 93 w/E10 . Just had 4 BLIZZAK WS 70s put on this weekend . Set @ 36 p.s.i.. Using SHELL full synthetic 5w-20 (SN) with TOYO oil filter .
Old 12-16-2011, 12:17 AM   #1950
Hershey
'08 sedan w/ 4 speed auto : 39.53 m.p.g. using SUNOCO 87 w/E10 with 2 bars left
Eco-Meter : 39.6 ( set @ 95 )
Calculated : 39.53 ( 372.9 mis. / 9.431 gals. @ 1 click )
Refilled with BJs Wholesale 87 w/E10 . Reset E.M. to 96 , that way it'll hopefully read a little lower than the actual gas mileage . Tires are Blizzak WS 70s set at 36 p.s.i..
Old 12-24-2011, 09:33 PM   #1951
Hershey
'08 sedan w/ 4 speed auto : 38.82 m.p.g. with BJs 87 w/E10
Eco: 39.3 ( set @ 96 )
Cal : 38.82 ( 376.2 mis. / 9.69 gals. )
Refill of Mobil 89 w/E10 at 1 click . 1 blinking bar just before the fill . Plan to reset E.M. to 95 at next fill and leave it at that . Tired of f*rting around with it .
Old 12-29-2011, 12:49 AM   #1952
NZ-FE Vios
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re
5speed, Sedan
Last tank was near all city, 336miles on 10.3gallons which is 32.62mpg.
NZ-FE Vios is offline   Reply With Quote
Old 12-29-2011, 01:17 AM   #1953
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
with HKS filter,Injen intake,DC header,Nitto midpipe and GReddy can,automatic with 15"proxeys still gettign 35-37.....only one tank have I broke 40 and that was durning summer before all the mods and mainly highway
Old 01-01-2012, 07:56 PM   #1954
Hershey
'08 base model Yaris sedan with 4 speed auto : 37.627 m.p.g. with MOBIL 89 w/E10
Eco-Meter : 38.2 ( reset to 96 )
Calculated : 37.627 ( 351.7 mis. / 9.347 gals. )
Yesterday did fill of Valero 87 /E10 at 1 click .
Old 01-01-2012, 08:12 PM   #1955
Hershey
'08 Yaris sedan w/ 4 speed auto : 42.916 using Valero 87 w/E10
Eco-Meter : 43 ( set @ 96 )
Calculated : 42.916 ( 164.2 mis. / 3.826 gals. )
Refill of Valero 87 w/E10 at 1 click . 2 people for whole tank . Temp of 42+ and winds of 15+ m.p.h.. Many hills as well . 4 Bridgestone Blizzak WS 70s' at 35.5 p.s.i. and using Shell synthetic 5w-20 ( SN ) . Was getting 45.3 when arrived at pet store . So , likely 44.7 or so since the calculated milage is usually less .
Pics of Eco at pet store and during the fill before going home :
Old 01-01-2012, 10:11 PM   #1956
Nanook
Drives: 2011 3dr hatch
2011 3dr 5spd (stock), 13,000+ miles
Best 41.02mpg
Avg 37.63mpg
Worst 35.12mpg
I have only reached over 40mpg's twice. My best tank was this last tank. Two tanks ago, halfway through I decided to try and get over 40mpg's. I did! The next tank (second to last measured tank) I tried to get over 40mpg's over the whole tank, I fell short 39.something. So this last tank I decided that coasting, slowly starting (rpm's under 2,500), and utilizing the DFCO function was too boring. So more than a few times I went through first and second gear just shy of 6,000 rpms (it is just more fun). I was just hoping to get above 35mpg's and wouldn't you know it, I got my best mpg's to date. I did drive conservatively occasionally during this tank, so it wasn't like I was always zipping around.
Mark
2011 Silver 3dr
Nanook is offline   Reply With Quote
Old 01-05-2012, 06:25 PM   #1957
KentSzabo
KentSzabo's Avatar
Drives: 2012 Toyota Yaris L, 5 speed
Two fill ups ago I had the first oil change and had them put synthetic 0-20 in my 2012 Yaris 5 speed. Since then on the past two tankfuls I got 43.4 and 43.2 MPG.
In addition to synthetic oil I run 40 lbs of pressure in the tires.
2000 VW Golf TDI, 5 Speed, 48 MPG
2000 Cadillac Eldorado ETC, Auto, 23 MPG
2004 Dodge 3500 Auto, Dually, 6" Lift, 36" Tires, 4" Dual Stacks, Predator, 20 MPG
2012 Toyota Yaris L, 5 Speed Manual, 46.4 MPG
KentSzabo is offline   Reply With Quote
Old 01-05-2012, 10:43 PM   #1958
Hershey
Nice . What brand oil is it ? How about an used oil analysis of the 0w-20 and post it .
Old 01-16-2012, 11:11 PM   #1959
Hershey
'08 base sedan w/ 4 speed auto : 35.75
Eco-Meter : 37 ( set @ 96 )
Calculated : 35.75 ( 272.2 mis. / 7.613 gals. )
Refill of Sunoco 87 e10 @ 1 click of nozzle . Temps have dropped into the teens and single digits .
Old 01-20-2012, 11:51 PM   #1960
Hershey
'08 base model sedan w/ 4 speed auto : 33.60 m.p.g. w/ Sunoco 87 ( e10 )
Eco-Meter : 34.5
Calculated : 33.60 ( 197.6 mis. / 5.88 gals. )
4th bar lost not long before fill . Average temp of 20 . Lot more cold idling thanks to heavy frost and single digits .
Old 01-30-2012, 09:01 PM   #1961
Spidermandud
Spidermandud's Avatar
Drives: Black '08 Yaris Hatch S
Over Winter break I found that the best way to get incredible gas mileage in a yaris is to go to florida, haha. I was doing high 40's or so mpg. The ultralight wheels garm sold me help; but I guess just getting out of tennessee and driving like a granny helps. Anyone wanna volunteer to go to florida and see?
-Will-
Spidermandud is offline   Reply With Quote
Old 05-05-2012, 10:21 PM   #1962
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I got 38 or so mpg when I lived in florida.
Colin Chapman disciple
