Old 08-04-2012, 10:08 AM   #1
Cutie Pie #2
Drives: 2014 Honda CR-V LX
Just turned 65000, 2008, Yaris LB, blazing blue, all required services done to this point, no problems it's been a good car but I do still have a rattling hood release that drives you crazy sometimes that has to be tightened but overall I'm happy with the car!!
Cutie Pie #2 is offline   Reply With Quote
Old 08-16-2012, 02:03 AM   #2
nookandcrannycar
223,021 miles -- 1,028 miles since last post -- no new problems -- I'm probably going to get new tires within the next week. I'm going to go with the same Firestone FR710 set of 4 I have on the car now. I've got 82,478 miles on the current set. Same size 185/60-15. The price is 25 cents cheaper than the cheapest 185/60-15 on TireRack.com. Among all the choices in the marketplace, I also have the most confidence in the Firestone store warranty re the stores existing 'almost no matter what' and getting better service than Wal-Mart. I'm also probably going to replace my battery on 9-9-12 (which If I remember correctly it will hit 3 years of use). I currently have 84,976 miles on the battery. I'm probably going to get a Wal-Mart battery that is the Wal-Mart equivalent of the current Sears battery I have, but it is the same price as the Sears battery was 3 years ago, not the higher price (up,up,up) that the same Sears battery is now.
Old 08-17-2012, 02:38 AM   #3
edmscan
edmscan's Avatar
Drives: 2020 Corolla
4372.7 KM logged so far (now at 166,000 KM on my Yaris). Just got it in May of this year.
Replaced 4 tires .. just cause I didn't like the tread left on the tires that came with the car. About 700$ ... yes I live in Canada where things are way more expensive. Expect these tires to last me well in excess of 5 years. So not a bad investment, and gives me some peace of mind.
That's it .. regular maintenance sort of stuff.
edmscan is offline   Reply With Quote
Old 08-18-2012, 09:51 PM   #4
Francos Yaris
Drives: 08 Yaris sedan
2008 sedan
83,000 miles
Normal maintenance done: oil changes every 5000 miles (synthetic), fresh set of tires at 60,000 miles, new brake pads at 80,000 miles. Only major problem so far was my passenger rear wheel bearing seized on me at 70,000 miles
ShamWow. You'll be saying Wow everytime!
Francos Yaris is offline   Reply With Quote
Old 08-18-2012, 10:54 PM   #5
12 yaris
Drives: '12 Yaris LE Lagoon Blue Mica
9400 mi. 0 issues...
12 yaris is offline   Reply With Quote
Old 09-09-2012, 10:14 PM   #6
harda toenail
Drives: Want a yaris
Airbag light came on and around the same time I noticed coolant sprayed on the hood.
87k miles. Needed water pump and coil spring in the steering wheel replaced. Also replaced serpentine belt at this time.
08 hatchback 1.5l
harda toenail is offline   Reply With Quote
Old 09-16-2012, 11:17 AM   #7
12 yaris
11000 mi.,5 oil changes,1 air filter,1 cabin air filter....
Old 09-17-2012, 10:16 AM   #8
david_827
Drives: 07 Yaris Sedan
5 oil changes in 11K miles??????????? isnt that a bit excessive?
david_827 is offline   Reply With Quote
Old 09-17-2012, 01:41 PM   #9
Kal-El
Kal-El's Avatar
^^^ Yeah, that's flushing money down the toilet.
Should be just past 2 oil changes.
Old 09-19-2012, 05:18 AM   #10
shastaylb
Drives: 07 Yaris Liftback
110,000 miles, no problems.
I have a 2007 silver 3 door hatchback. I change the oil when the light comes on, keep the tires rotated and that's it. I just bought my third set of tires. The Goodyear Eagles that it came with only lasted 30,000 miles. I replaced them with Toyos that lasted 70,000 miles. I just put on a set of Hankooks. My battery went out at 70,000 miles, which I thought was premature (my original Nissan pickup battery lasted 11 years and 210,000 miles). Pretty trouble-free car. My long term opinion of this car is pretty positive. My only gripes are the funky fuel gauge, the auto-dimmer (if you drive with the lights on in the day, you can't read the clock and the speedometer is dim) and the fact that with all the compartments, there really isn't a good place to keep cds. A few rattles come and go, it is a little spooky in a side wind and it is a little noisy (the new tires help a lot). I really love the driver's side glove box and the high central speedometer. Sad to see them go in the new model. I love that 4 big people fit comfortably or 2 people and a whole lot of camping gear. This is a roomy, comfortable little car and I am 6'2''. Oddly, people keep asking me if it's a Smart Car. I will update at 200,000 miles.
shastaylb is offline   Reply With Quote
Old 09-16-2012, 05:58 PM   #11
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
112,300km (70,000mi)
caineroad is offline   Reply With Quote
Old 09-16-2012, 06:23 PM   #12
mryaris
Drives: 2010 Carmine Red hatchback
Just turned 60,000 miles and still trouble free.
mryaris is offline   Reply With Quote
Old 09-28-2012, 09:47 AM   #13
NancyMac
2008 YARIS SEDAN
33,000 MILES
Black
Need two new tires, but that's my fault for not rotating like I should. Otherwise, no problems!
NancyMac is offline   Reply With Quote
Old 10-12-2012, 10:46 PM   #14
jfgentner678
2008 Yaris Sedan
88k Miles
Transmission went out at 61k miles, but replaced.
Did coolant flush today (88,012 miles)
Oil every 5k miles
This was the wifes car, but it's all mine now :) 90 mile round trip commutes here I come!!
jfgentner678 is offline   Reply With Quote
Old 10-12-2012, 11:03 PM   #15
nookandcrannycar
Originally Posted by jfgentner678 View Post
2008 Yaris Sedan
88k Miles
Oil every 5k miles
Automatic transmission I presume?
Old 10-12-2012, 11:01 PM   #16
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
40k on my 2010 sedan...no problems other then a small rattle or buzz in the dash ever since ive bought the car (new) and the a/c smell these suffer from
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 10-14-2012, 09:10 AM   #17
bankrobber
Drives: 2007 Yaris Hatchback
Folks the auto dimmer for the dash lights can be brightened durring the day by pushing the dimmer control switch up.
Old 10-14-2012, 09:12 AM   #18
bankrobber
2007 White 3 door HB
Manual
156k miles. No repairs yet
Only PM services.
One belt, spark plugs
excessive sulfur odor on 2007 model year Yaris tomjasz General Yaris / Vitz Discussion 121 03-13-2010 07:49 PM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 02:11 AM
