Old 05-08-2009, 10:41 AM   #1
hatchbackkid82
Drives: .
So judging by the 186 post, no one has figured this out yet. I had this on my car and could not figure out how to turn the CEL off. I just came to the conclusion that just b/c a part fits on my car doesn't mean it belongs on there. I think there are only a handful of members that have done this mod sucessfully(i.e. No oscillation, no CEL)
Old 05-08-2009, 06:07 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
hey guys would the 1zz-fe from toyota matrix works as well???
Old 05-08-2009, 06:10 PM   #3
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^ same one as the corolla
Old 05-09-2009, 02:37 PM   #4
jkuchta
Drives: 2007 Yaris hatch (red)
Kustom...what is the CEL code?
jkuchta is offline   Reply With Quote
Old 05-09-2009, 05:46 PM   #5
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I am still getting oscillation like a motherfucker (1-4k RPM) but no CEL. Hey kustom I'll trade you my oscillation for your CEL. I pulled up next to a STI yesterday and looked like some faggot ricer revving my engine. I am debating just throwing my stock exhaust back on so it isn't as obvious that my engine is revving.
Old 05-10-2009, 10:21 AM   #6
marcus
toyota
marcus's Avatar
lolz.. this thing can get you in trouble..imagine lining up with a copper on a stop light...
Old 05-10-2009, 05:06 PM   #7
PHXDEMON
PHXDEMON's Avatar
I started killing my engine at stop lights I bled the coolant today and it didn't make a difference. It seriously seems like the oscillating is getting worse and it is pissing me off. I am going to make one final attempt to reseal/remount the TB and let it set for 24 hours while the battery is disconnected and if it is still giving me crap after a couple days I'm just pulling this fucker off. Also I tried the whole rev the engine up to 5k for 3 minutes thing but after 2 minutes my engine started backfiring so I stopped.
Old 05-10-2009, 07:50 PM   #8
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Maybe you have a bad TB or the idle screw was messed with too much? (I didn't bother touching mine.)
I never did the chip swap on mine (too lazy). Coolant bypass (didn't bother to bleed it) and only have high idle when cold and of course my CEL is always on. (For about 700 miles now)
Mine does stick a bit it seems, RPMs hang for a few when slowing quickly to a stop (usually to go over speedbumps).
No oscillation, except when I first installed it. That was fun trying to avoid looking like a douchebag revving at every light. (For the 100 miles I had that issue I would just put the car into gear quickly to bring the car's RPMs down to normal and then release.)
Old 05-10-2009, 10:24 PM   #9
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Yup I get the stuck throttle at times as well. Cold idle too, but no CEL yet.
Old 05-11-2009, 12:03 AM   #10
PHXDEMON
PHXDEMON's Avatar
I bought the TB off of m911gt who was selling it because of the same issue. I did the chip swap on it so that rules out a bad chip. Fucking with the idle screw is the only thing I have yet to do because I don't see why that would cause anything other than a too high/too low idle. Plus after I installed it I drove to work and back (50 mile round trip) and it ran flawlessly other than hanging to RPMs a little bit but it sure as hell wasnt oscillating. Also this entire time I have yet to actually get a check engine light You would tend to think with the motor ranging from 1-3/4k rpm it would throw a code. I think my ECU is just being a stuck up whore
Old 05-11-2009, 12:05 AM   #11
PHXDEMON
PHXDEMON's Avatar
Also Gideon did yours oscillate right off the start? Did it come and go? Or was it just oscillation constant for first 100 miles and then it went away? How hard did you drive it for thos efirst 100?
Old 05-11-2009, 12:29 AM   #12
Gideon
★weeaboo★
Gideon's Avatar
Yeah, it oscillated every time I let the engine go back to idle initially and it was for only 20 miles or so. In that 20 miles I ran it to redline every chance I could. (After the engine was properly warmed up of course)
Old 05-11-2009, 12:36 AM   #13
PHXDEMON
PHXDEMON's Avatar
So I need to start driving like a ricer Also was it really jerky every time you applied/let off the gas? Like on the freeway I hit the gas but it steadily accelerates so I have to let off and every time I take my foot off/put it back on the gass it jerks like a motherfucker.
Old 05-11-2009, 12:56 AM   #14
Gideon
★weeaboo★
Gideon's Avatar
Yeah it was pretty jerky initially.
It still is really jerky if the engine is cold, but once it warms up it ceases.
Old 05-11-2009, 02:29 AM   #15
PHXDEMON
PHXDEMON's Avatar
Mine keeps getting worse and worse. Jerky as fuck even when the sngine is warm and the oscillation is progressively getting worse.
Old 05-11-2009, 12:07 AM   #16
PHXDEMON
PHXDEMON's Avatar
Possibly you guys running with CELs are in open loop vs closed loop and that's why you aren't getting oscillation
Old 05-11-2009, 04:53 PM   #17
PHXDEMON
PHXDEMON's Avatar
okay so the idle screw was all the way in and I backed it up as far as I could. Let the car idle for about 10 minutes and slowly the idle smoothed out completely While driving I am still getting some jerkyness and moderate oscillation (1-2k) at stop lights but nowhere near as bad as it was. It seems the ECU is actually trying to learn the new throttle body now instead of just being a whore about it. Hopefully it will smoothe itself out some more as I drive it more.
Old 05-11-2009, 05:59 PM   #18
marcus
toyota
marcus's Avatar
hope that fixes ur issue..
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
