Old 04-15-2009, 06:58 PM   #181
at3GG
at3GG's Avatar
Drives: 07 metmet LB
Let off the clutch fast enough to gain good traction off the line without spinning the tires. Tire spin is BAD.
thats what i was thinking just never actually heard a name for it
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 04-15-2009, 06:59 PM   #182
at3GG
at3GG's Avatar
What... intake, full exhaust, pulleys, short shifter... what else is there?
flux capacitor
Tanabe Df210's
Old 04-15-2009, 07:39 PM   #183
Micro Image stickers?
Old 04-15-2009, 07:43 PM   #184
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Charles, how is your idling and low rpm engine response?
Old 04-15-2009, 08:02 PM   #185
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
flux capacitor
1.21 JIGGAWATTS!!!!!!
Old 04-15-2009, 08:10 PM   #186
at3GG
at3GG's Avatar
Tanabe Df210's
Old 04-15-2009, 08:53 PM   #187
ChinoCharles
Drives: LB
Long, idling is as good as stock. Idles a little high when it is cold (1100-ish RPM) but once it warms up it goes back to the 750 RPM or so it was before the kit.
Under about 2 grand the engine feels exactly the same as it did before. From 2,000 to 3,200 RPM you can feel a little kick and hear the turbo spool a bit. From 3,200 on its a frickin' rocket. The turbo sounds like 20 vacuum cleaners under my feet.
Garm, I would be honored to send you the Chinotake.
Old 04-15-2009, 08:57 PM   #188
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
I believe 750 is above stock idle at a warm idle.
Old 04-15-2009, 09:00 PM   #189
ChinoCharles
Drives: LB
Only a hair if at all. Stock was what, 700?
Old 04-15-2009, 09:01 PM   #190
PETERPOOP
PETERPOOP's Avatar
idk, I remember reading somewhere it's 550-650 or something like that (no a/c). Don't quote me on that.
Old 04-15-2009, 09:02 PM   #191
ChinoCharles
Drives: LB
I'm going by what I saw on my tach. Can someone else confirm or deny?
Old 04-15-2009, 09:05 PM   #192
LtNoogie
LtNoogie's Avatar
It's different for the MT and AT. It's listed in the service manual.
Old 04-15-2009, 09:09 PM   #193
ChinoCharles
Drives: LB
Good deal, I'll have to check later. I'm curious now.
Old 04-15-2009, 09:10 PM   #194
LtNoogie
LtNoogie's Avatar
This is all I found so far for the automatic.
Engine idle speed, (A/C OFF) N position, 650 to 750 rpm
Old 04-15-2009, 09:23 PM   #195
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
warmed up (mind you this is no boost at all) my mostly stock 07 MT LB idles between 500 and 650
Old 04-15-2009, 09:24 PM   #196
ChinoCharles
Drives: LB
OK, so I'm a little high. Makes sense when you consider the larger injectors and colder plugs, no?
By the way, second tank was 34.1 MPG on Shell 93.
Old 04-15-2009, 09:30 PM   #197
LtNoogie
LtNoogie's Avatar
From the Engine Mechanical section of the 2007 repair manual
(5) Inspect the engine idling speed.
Idling speed:
550 to 650 rpm for manual transaxle
650 to 750 rpm for automatic transaxle
NOTICE:
• Turn all the electrical systems and the A/C off.
• Inspect the idling speed with the cooling fan off.
• When checking the idling speed, shift the transmission to either the neutral
position or the parking position.
Old 04-15-2009, 09:34 PM   #198
ChinoCharles
Drives: LB
OK, I'll get an exact reading on idle on my way home from the game.
Whats needed to turbo charge the yaris? Arkhangel Forced Induction Forum 44 03-02-2009 10:08 PM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-26-2007 11:18 PM
NCP 91 RS 1500 TRD Turbo ????? ramishrrr General Yaris / Vitz Discussion 3 01-15-2007 04:51 PM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
