#1 |
My R1 eats my Vitz!!
Drives: '07 Vitz Lifty, Stick Shift Join Date: May 2007
Thank you so much, I have about 3 hours before the sun light is bye bye. It wasn't too hard to remove the top. Couple scratches and bruises on my hands, but now that I know how, of course, I can do it a lot quicker next time.
My Car Rules! |
I'm not the best at reading wiring diagrams, but from what I can see my car doesn't even have this "ad4 plug" see picture...
![]() And I can't find a plug hanging down that would plug into the Clutch Switch for Cruise Control. I can see where the switch mounts to the Clutch Pedal Mount...but no plug. Please help me :(
My Car Rules! Last edited by nickhjort; 05-02-2009 at 06:36 PM. |
#3 |
Also if this is the case, does that mean my ECU doesn't even have the Cruise control programmed into it, so I can't tap a wire right from the ECU itself? I hope I can do this...seeing as I already drilled my holes and put switches :) (kicks self for not getting priorities straightened out before starting project...1. Check to see if this will work...2. Then cut $hit up HAHAHA!! Not the other way around...)
My Car Rules! |
#4 |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
I think you're right, especially since the factory diagram has a note saying "gray" on the picture of the AD4 plug.
#5 |
It is definitely the grey next to the yellow. Pin 1 is orange, 10 is yellow, and 5 in pink, and I see those clearly.
In the pics I don't see the right angle to tell if the Pin 6 blue wire (CCS) is there. It should go 5-pink, 6-blue, and 7-brown. |
#6 |
As for the clutch switch wiring. At the ECM it is pin 56 of Connector C20. From there is connects through pin 14 of CA1 (the right rear connector in the under hood fuse box). It is a blue wire - shown below (For AT, two wires come into the one pin). For your test, you can jumper it to the white wire, two pins to the right of it.
Clutch Switch Wire.jpg |
#7 | |
My Car Rules! |
#8 | |
The black wire is just a +12V source that flows through the clutch switch to the ECM input. The A25 connector is a nighmare to get at, so the white wire, I said to jump the blue to, is a much easier to get at alternative to the black wire in A25. |
#9 |
How you guys can read that diagram...I don't know, but thank god you can :) Thanks so much! You guys are awesome! I lost the last of my light though, so tomorrow I'm gunna finish this up and we'll see how it works. I'll take some more pictures as I splice and dice, just to kinda help with someone's DIY (I'm not gunna write one up...not a very good public speaker).
My Car Rules! |
#10 |
Well I just checked and I have no blue wire in slot 6...I have a blue wire in slot 15 though. That's on the top part, and on the bottom, I can't see under it right now to look for a wire, but when I unplug it and look in at the metal pins, there isn't one where that blue wire in slot 15 should be and there isn't one in slot 6. I hope I'm explaining this ok for now, until I can take more pics tomorrow. Is it possible there is a wire going into the harness, but there's no metal pin for the plug part? I dunno I'll check tomorrow when I don't have to use a flashlight :)
My Car Rules! |
#11 | |
#12 |
So that means I can't do this huh?
My Car Rules! |
#13 |
#14 |
I'm guessing there's a pin in the ECM at slot 40 for the cruise, but no wire on the plastic connector part. I wonder how hard it would be to just insert a wire on the connector. I'll have to see how the wires are in there and if you can get one of those little metal pins and attatch a wire to it.
My Car Rules! |
#15 |
Is your 07 the same PK198105? I wonder if you have the wiring under the dash unlike mine. If not, what would you do? Say oh well, hang up the towel? I really want this cruise cause I drive to work back and forth about 45 mins each way. It would be really helpful. I mean I'm pretty confident in my wiring abilities. Solder, heat shrink, etc. But of course I don't wanna fuck anything up so bad my dash is gunna end up like that guys in Australia I saw on here today.
My Car Rules! |
#16 |
Cool. Well we'll see tomorrow then.
My Car Rules! |
#17 |
I see, I see. One other quick question. If I don't have all the wiring for this from the ECM, do you think I will have to do anything to get the brake switch to work, or will it already be programmed to turn off the cruise control when I hit the break? And I didn't see the plug for the clutch switch near where the switch goes...will I have to wire that once I buy the actual switch and take the jumper out?
My Car Rules! Last edited by nickhjort; 05-03-2009 at 02:28 PM. |
#18 | |
For the clutch switch, if this works, then you'll have to snake a wire from the under hood fuse box to the clutch switch and wire it yourself. |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
