Old 11-03-2009, 10:01 PM   #1
Originally Posted by SEALL View Post
My yaris's engine is 4ZRFE,1600cc,Super ECT 4-speed AT,ABS yes,VSC no,maybe only have the 1600cc engines of the Chinese market.
I think you are correct. Are you able to see the part number label on your ECM?
Old 11-04-2009, 08:49 AM   #2
SEALL
Drives: 08’Yaris
I don't know what's the part number,I saw the lable on my ECM,there are some number on it:89661-0DA20 ; TD275100-9872 ; C90.
SEALL is offline   Reply With Quote
Old 11-04-2009, 10:18 AM   #3
89661-0DA20 is the part number. It looks like it is a China specific ECM.
Old 11-03-2009, 10:06 PM   #4
rtom
Drives: 2010 Yaris 3-door liftback MT
Anybody know about relevant wiring in 2010 liftbacks?
I'd like to try this on a 2010 2-door base liftback purchased in the US!
rtom is offline   Reply With Quote
Old 11-03-2009, 10:13 PM   #5
2010 is identical to 2009 for the DIY cruise mod.
Old 11-05-2009, 12:17 AM   #6
SEALL
Drives: 08’Yaris
It seems useless to put on a USDM ECM.
Old 11-05-2009, 07:03 AM   #7
Agreed. I don't think it would be compatible with your engine.
Old 11-05-2009, 08:58 AM   #8
SEALL
Drives: 08’Yaris
Although there is no success, but very grateful to you for your help,And your very pleasant exchanges.
Old 05-29-2010, 12:09 AM   #9
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
I'm going to try the 4 button set up and plan on getting it installed this weekend. I decided to put all the resistors in their own enclosure and attach the buttons with butt connectors. I can tuck the module up under the dash and if a button ever goes bad (read as: When I spill my drink into one), I can simply unplug the switch and replace it without any soldering. I have some buttons but I'm going to see if I can find something better.
I'll take more pics as I progress.
I couldn't find the right resistors so I had to stack them to get the right Ohm requirements.
I've got about $24 dollars into it so far.
Added more pics. I haven't settled on where I want the buttons or what type I want so I installed the cheap ones I had next to the Aux Port for now
I mounted the CC module on the cross bar under the steering wheel. The box has to lay on its bottom, not on its side as shown in the first picture of it. The steering column cover wont fit if it mounted on its side.
It works! CTScott, and everyone else that contributed, thank you for all the great info.
Last edited by Stove; 05-29-2010 at 06:53 PM. Reason: Updated and added more photos
Stove is offline   Reply With Quote
Old 07-06-2010, 03:32 PM   #10
drunix
Drives: 2010 Yaris 3D LB
How does that little panel pull out? (The "push button start cover".) Is there a trick to it? Thanks. I pulled it part way out and it seems to not want to part company with the panel on the right side.
drunix is offline   Reply With Quote
Old 08-11-2010, 09:38 AM   #11
You have to remove the vertical trim to the right of it first (which you can just pull off with your fingers as well).
Old 09-16-2010, 08:47 PM   #12
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
So in a sedan yaris 2009 you just have to do the switch mount and connect the red wire to the blue one and the black wire(ground) to the brown one of the d3 connector ? Am I right ?
Old 09-17-2010, 07:55 AM   #13
It depends on when in 09 the sedan was built. Some people with 09 sedans have found that the blue wire from the ECM to the steering column is not present. If it is, then the answer to your question is "Yes".
Old 09-17-2010, 11:23 PM   #14
packetrace
packetrace's Avatar
thank you Scott it worked perfectly :D It'S amazingg !!
Old 08-11-2010, 03:59 AM   #15
birdman
Ingenious!
Old 03-25-2011, 03:55 PM   #16
Chuck
Drives: 2009 Yaris LB
Awesome! Just got mine done. $25.48 total. All parts from Radio Shack except for the splice/tap connectors. I forgot to get them while I was there, but grabbed them at advance auto parts for a little over a dollar. They are included in the price though. I got the red and black buttons (which came in one package), three pack of wiring: red, green, and black 20ga, 470ohm and 100ohm 1/4w resistors, 2 18-22ga splice/tap connectors (red), and the soldering iron kit. Thank you so much to those that put in the time to figure this out for the rest of us! :)
Chuck is offline   Reply With Quote
Old 04-01-2011, 05:28 PM   #17
mjmuck
Drives: 2008 1.5 L Yaris
I followed the instructions with the 4 switch method (minus installing the clutch switch) and even got a connector for the ecm to make sure it connects. I am still not getting this to work. I connected the ground to the metal bar underneath the steering wheel. I believe I made a good jump on the clutch connecter.
What problems have people had with this and the solutions? Maybe I'm just missing something silly. I'm trying to drive from KC to Chicago in a week and would really prefer this to work.
mjmuck is offline   Reply With Quote
Old 04-01-2011, 09:41 PM   #18
The biggest problems are typically bad connections or the ECM pin not being fully inserted. If you have a multimeter, with the ignition in the on position, measure the voltage at your switches where the ECM wire connects. It should read 12 V and then if you press and hold the on/off switch it should drop to 0 V.
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
