Old 02-01-2010, 12:56 PM   #1
DOMAV
Drives: Yaris 09 T-spirit 1.33
hi can but what is the recall for exactly?? for the gas pedal?
what happen it sticks? thanks i tried to search but couldn't find my answer
DOMAV is offline   Reply With Quote
Old 02-01-2010, 01:16 PM   #2
MadMax
MadMax's Avatar
Yes, the gas pedal. Even though our Yarii don't fall under the recall, I still think it is a great excuse if you get caught speeding!
"Sorry officer, but you know how the gas pedal sticks on these Toyotas!"
Your car is equipped with a unique stopping system called THE BRAKES! When your desire to keep moving ends, employ them to stop/counter that action. Works most every time!
Cheers! M2
Old 02-01-2010, 02:03 PM   #3
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
Cheers! M2
LOL! I'll use this excuse if I have too!
Old 02-01-2010, 02:47 PM   #4
Kongo-Otto
Drives: '09 Yaris & '10 Auris
He is from Malta so his Yaris should came from TMMF and this means RECALL.
Old 02-01-2010, 02:54 PM   #5
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
How can you speed on Malta? It's a small island... there isn't enough runway to get to such high speeds
No offense, just trying to be funny here
5% Tint Rear | Micro Image LED Ignition Light Kit
Old 02-01-2010, 04:38 PM   #6
DOMAV
yes is very small but very nice
thanks all for the replies
What does it mean it come form TMMF?
Old 02-01-2010, 01:05 PM   #7
eric81
eric81's Avatar
Drives: Toyota Salesman
The gas pedals, after extreme wear, usually in high heat or high humidity areas, sometimes start to feel sticky (reacting slow and a little harder to push down). Here's how to tell if your car MIGHT have an issue...
1. Get into drivers seat.
2. Without putting the key in the ignition, simply put the gas pesdal all the way down.
3. Release gas pedal as fast as you can, and see if it comes back slower than you are comfortable with. It should take less than 1 second to go back to original position.
If it is sticky or slow, you may have a vehicle that needs this fix.
Pass this on to ALL car owners, as the company that makes those parts for the Toyota's also makes parts for almost all other manufacturers. Toyota is fixing a problem before it becomes a problem. Technically, the part is mostly wearing in cars AFTER they run out of their initial warranty, so they don't HAVE to fix anything. They are just doing the right and moral thing by fixing them. Not to mention they have less problems with their cars than any other manufacturer out there. "There is no best, only better."
eric81 is offline   Reply With Quote
Old 02-01-2010, 10:39 PM   #8
frownonfun
frownonfun's Avatar
lol a coworker asked me if that's gonna be kyle busch's excuse when he wrecks this year. i was amused by the comment.
I crush you like tiny clown car, because you are clown, yes?
Old 02-01-2010, 10:45 PM   #9
goku87
goku87's Avatar
Drives: Black HB
I'm still not understanding how it's the pedal. My money is that it's the ECU.
Old 02-01-2010, 11:48 PM   #10
127.0.0.1
its not the ECU, they actually explained it. its the spring that helps return the pedal, apparently it gets used up and looses its tension so they are going to insert a shim to compensate and replace the spring
no that is not how it works. it has nothing to do with the spring
the hall effect sensor rubs the magnet (and it really shouldn't... or just barely touch) and when there is the slightest
bit of wear in the pivot the friction increases as the parts slide past each other.
the dealer-added shim maintains the fulcrum point (by wedging against the pedal arm) so the friction in the
sensor is reduced or eliminated throughout the life of the pedal
Old 02-02-2010, 12:25 AM   #11
goku87
goku87's Avatar
Drives: Black HB
That and the pedal has two springs anyway.
Old 02-01-2010, 10:51 PM   #12
frownonfun
frownonfun's Avatar
so now it's got nothing to do with floor mats?
Old 02-01-2010, 10:57 PM   #13
frownonfun
frownonfun's Avatar
but don't all vehicles' pedals use springs? and so wouldn't every vehicle be prone to having a spring lose tension over time? isn't that the nature of things... they wear out?
Old 02-01-2010, 11:39 PM   #14
yaris2010RS
yaris2010RS's Avatar
okay, when reading all this i thought the ppl who post now after the recall came out saying their yaris is acting messy (but never said anything before) i figured u guys are crazy!! bot has anyone found on the yaris the clutch sticks??it happened twice on my way home from work tonight. not exactly what the issue is, i believe it may be the carpet but tomorrow morning further investigation will be conducted. i do have an extra all season mat that came with the car ontop of the floor mats and wasn't installed correctly. i removed the floor mat and put the all season mat in and tied it down to factory hooks. if its the floor mat toyota should not give them away in the car!! if i install it myself i assume all risks. dont get me wrong i noticed a few times before it would kinda get stuck a bit but pop right back up. today gettign on the highway shifting from 2nd to 3rd was scarry.....
Old 02-02-2010, 12:54 AM   #15
yaris2010RS
ever thought the news give any simple excuse as to not complicate things? just a thought and my 2 cents....
Old 02-02-2010, 12:36 PM   #16
eric81
eric81's Avatar
yeah... couldn't figure that one out even if it was the answer to Clue. Man, some people are just overly stupid... when you buy a vehicle, there is a thing called a Lemon Law, which tells the customer how long of a period they have to return a vehicle. Some states, such as Colorado, have a Now You Are An Owner policy. Once you drive it off the lot, it is yours forever. And it's not like Toota isn't tring to help customers out through this thing, they are doing everything they can as fast as the can. Hence they offered this customer a loaner car until his truck was fixed. The dealership should simply have him pay for damages, and nothing else. Obviously his truck, but he owned it, so I hope he has GAP insurance, or he's screwed.
Old 02-02-2010, 12:44 PM   #17
MadMax
MadMax's Avatar
Unfortunately, there are way too many idiots in the world! I hope his insurance denies his claim because it was deliberately crashed. It would serve this moron right to have to pay for all the damages out of pocket!
This small problem does by no means make Toyotas "lemons." If that logic were true, then basically every car ever built qualifies as most have had a recall for some reason or another.
I found this article interesting, it only shows that no matter what the issue, it is the perception that matters...
Toyota's other pedal problem: Lawsuits
NEW YORK (Reuters) - Toyota Motor Corp is facing a growing number lawsuits from consumers who complain their vehicles suddenly accelerate or may do so, and want the world's largest automaker to pay for it.
U.S.
Last week, Toyota stopped selling eight models in the United States and Canada, including its popular Camry and Corolla, because of possible unintended acceleration.
Some 8 million vehicles are up for repair worldwide over problems including alleged faulty accelerator pedals made by the supplier CTS Corp, and the possibility that floor mats could jam the accelerator pedal.
Other recalled Toyota vehicles are the Avalon, Highlander, Matrix, RAV4, Sequoia and Tundra.
The problems have tarnished Toyota's reputation for making some of the most reliable vehicles on the road. It is the most prominent auto safety issue since reports surfaced in 2000 that many Firestone tires mounted on Ford Explorers failed.
"Liability for Toyota could run in the billions of dollars, because of the number of vehicles involved and the fact there are serious injury and death claims," said Gary Robb, a partner at Robb & Robb LLC in Kansas City, Missouri. He said his firm has fielded inquiries from consumers and may sue Toyota.
The U.S. National Highway Traffic Safety Administration says it has no proof that anyone was injured by a stuck pedal. It said it has confirmed to its satisfaction that five people have died as a result of floor mat entrapment.
Since November, at least 10 lawsuits seeking class-action status have been filed against Toyota in U.S. courts and in the Ontario Superior Court of Justice in Canada.
It is possible that some U.S. litigation could be combined because the claims are similar and it would be too unwieldy to try cases one owner at a time.
Toyota on Monday had no immediate comment on the lawsuits.
NEW LAWSUITS
Legal experts said drivers might have more difficulty recovering if they cannot show their cars actually experienced sudden acceleration. Fear that it could happen may not be enough.
"In a significant majority of states, there is no remedy for mental upset and fright, absent a consequential injury to people or property caused by the defect," said James Henderson, a Cornell Law School professor and product liability expert.
David Owen, a law professor at the University of South Carolina and director of its Office of Tort Law Studies, said Toyota might be more at risk in U.S. states that impose on manufacturers of a "duty to warn" consumers about a defect.
"The grounds to sue are that there was a design defect, regardless of what Toyota may do to mop up the consequences, and the possibility that a post-sale warning was delayed too long," he said.
"If it turned out that Toyota delayed the recall beyond the point when a reasonable manufacturer would have done so, then punitive damages in substantial amounts might be available to whoever was physically injured," Owen added.
Some plaintiffs are expected to seek recovery for an expected loss of resale value tied to the stigma from the recalls, though Owen said courts are generally "unresponsive" to such claims, including in Firestone tire lawsuits.
Others may seek to recover for expenses tied to the recall, including lost work hours and the cost of finding alternative transportation while their vehicles are being fixed.
POSSIBLE STIGMA
Four of the most recent lawsuits were filed on Friday.
In a federal lawsuit filed in Corpus Christi, Texas, the plaintiffs Albert and Sylvia Pena alleged that their 2008 Toyota Avalon unexpectedly accelerated at least twice, and on January 14 caused a collision at a stop sign.
"Toyota has long known about the defect with their throttle control, and has done too little, too late to correct it," said Robert Hilliard, a lawyer representing the Penas.
Three other federal lawsuits were filed in New Orleans on behalf of Avalon and Camry owners. These plaintiffs' lawyers were unavailable to comment.
Robb said Toyota might learn from Johnson & Johnson's 1982 withdrawal of Tylenol from stores, after seven people died from ingesting medicine spiked with cyanide.
The crime was never solved, but the company's response, including the introduction of tamper-resistant packaging, is considered to be a textbook example of how to handle recalls.
"They saved not only their public image, but that brand," Robb said. "There are real doubts as to whether Toyota's brand, from a PR standpoint, can survive this (recall) intact. This has dragged on too long and there have been too many excuses."
Note the paragraph I highlighted...the U.S. National Highway Traffic Safety Administration says it has no proof that anyone was injured by a stuck pedal!
Yes, a sticking gas pedal can be a problem and Toyota has a fix for it before it happens; but to listen to the press you would think cars are crashing left and right and people are burning to death in the aftermath!
But I am a daredevil...I used to drive a Pinto!
Cheers! M2
Old 02-02-2010, 10:14 PM   #18
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
According to this article: http://money.cnn.com/2010/02/02/news...dex.htm?hpt=T2 The NHTSA is looking into a hypothesis that electromagnetic interference may somehow be causing the ECU to malfunction causing uncontrolled acceleration.
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Toyota Temporarily Suspends Sales of Selected Vehicles redglare45 Off-topic / Other Cars / Everything else Discussions 0 01-26-2010 06:33 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
Toyota recalls vehicles over faulty engine Lizardboy General Yaris / Vitz Discussion 1 07-18-2006 07:07 PM
