#1 |
![]() Drives: yaris diesel 2012 Join Date: Jan 2016
ok i will search for pin 40 and if is not pluged anything what shall i plug on it???and second
can i reprogramm my ecm (not me offcourse)or something is missing from ecm? |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
Big thanks to CTSCOTT for letting us know this was possible. I have just fitted cruise control to my 2012 Austrailan 1.3L yaris. I only bought the Yaris recently as a second car, and was nearly put off the purchasr because of the lack of cruise control. I found a switch on eBay for AU$17 delivered for whatwas a $650 option in 2012.
For the 2012 model with steering wheel audio controls you don't need to disconnect the battery or airbag, but it's a good idea to remove the horn fuse from the fuse box next to the battery when you go to push the central airbag and horn button back on to the wheel. If you don't the horn will sound when you push the airbag unit back on to the montings.
#3 |
![]() Drives: MY63 Toyota Yaris 1.33SRManual Join Date: Oct 2013
OK I finally done mine! I am from the UK, I ordered the cover part from toyota (part# 45186-0d030-C0 (C0 = black) and cost me £5.60 inc VAT.
I ordered a non OEM stalk off ebay for cheap but hopefully will last and looks/works/feels OEM. So disconnected the battery, removed airbag, put it all in, put all back together.. DONE! How long did it take... 10min? 15min? 20min? 30min?... nope! 1 whole hour!!!!! thats start to finish. 45min of that was battling the airbag clips! My car is a 2013 (MY63) Yaris SR 1.33 Manual 5door. It already had the secondary clutch switch etc so literally was plug and play. When connected battery, only thing that rest was the clock, the touch&go even resumed my song so dont worry about having to set everything again, just the clock! The first clip of the airbag was easy, small screw driver and push and it pops out. The other two... well lets just say I couldnt pull the clips down, they are tougher than I thought! How I got it out eventually was by pushing down in the plastic clips of the airbag which some how released both but this is easier said then done! I was violent so dont be scared, nothing will break as long as you know what you're jabbing. To help me get more access I also removed the steering wheel buttons trim by un doing two screws (1 is oposite the other and are obvious). It wouldnt come off as the airbag was still clipped in but I could pull it off enough to get more access. Thats my tip! |
#4 |
![]() Drives: 2014 Yaris lb 1.33L Join Date: Apr 2011
Hello
I have a yaris European model, engine 1nr-fe. CTScott, do u still have the kit for cruise control? Thx |
#5 |
![]() Drives: 2014 Yaris L Join Date: Apr 2016
Got the stalk from Scott for $50 and the trim piece for $5-he was very fast with shipping and easy to communicate with. I have the base US model with no buttons on the steering wheel, and installation was a breeze. Park with the steering wheel upside down to make it a little easier to get to the pins that release the airbag and steering wheel cover. The photos were really helpful to know what the release pins for the steering wheel look like/where they were so it only took a minute to take it off. I disconnected the battery and let it sit for half an hour just to be safe, but once I got the airbag off I just held/balanced it on the wheel while I installed the stalk, didn't bother doing anything to disconnect it completely. With the airbag off there was just one 4-pin connection and a horn wire to connect, would have been almost impossible to mess up. This saved me so much $$, and probably only took 15 minutes in total.
#6 |
![]() ![]() Drives: Yaris 2014, Y. HSD 2013 Join Date: Feb 2013
Hello Everyone,
Since I've installed an used switch cruise control on my second Yaris 2013. Led cruise control cluster blinking (https://youtu.be/055DBpCVR6A ) . Does I need change stalk cruise crontol ? Or does exist something to fix it ? Thanks for your help. |
#7 | |
#8 |
Hello Mr Scott,
Thanks for your prompt reply. Hum I believe that's it. It's a manual 99 horses power vvti. I put on a Verso-s (Ractis, NSP120 100VVTI same engine and manual transmission) switch cruise control find on car's mum to new yaris. Light blinking. Verso-s is little more largest car based on yaris chassis. Some pieces can be able the Yaris 2012 that's dealer have said. A second try with switch cruise control on my first yaris 2013 D4d and light blinking yet. Does the problem come from the multiplex whose doesn't support additional plugging? Or any stalk cruise control can be fix this problem? |
#9 | |
#10 |
![]() Drives: yaris 2016 Join Date: Apr 2016
![]() Everything perfect and for me.special thanks to Gagi Sent from my iPad using Tapatalk |
#11 |
the hybrid yaris has built for cruise control?
Sent from my iPhone using Tapatalk |
#12 | |
Yes. The hybrid does have cruise control built in.
#13 |
![]() Drives: yaris Join Date: Sep 2016
Hello CTScott, i own a 2012 yaris with 1nr-fe engine and 6-speed manual transmission. My steering wheel has both audio and bluetooth buttons and today i installed the cruise control stalk with no success. i plugged the 4-pin connector in the empty slot next to the 10-pin connector but the light does not come on when i press the on- off button. The only difference i noticed from the previously posted photos is that the airbag has only one orange connector, not two. Everything else looks the same. Any idea?
#14 | |
#15 |
![]() Drives: Yaris 2012 Join Date: Feb 2013
My CC-light to not working, but otherwise CC works flawless :) You must test on the road.
#16 |
Thank you for your fast replies but my engine IS the 1,33 L variant- 1329 cc to be exact. This is why I am confused. I did not know that this could be the case meaning the cruise control can work at the same time the light remains unlit. Has anyone else experience the same situation?
#17 |
![]() Drives: Yaris 1.3 2012 Join Date: Jul 2016
hey everyone!
I am from greece, i have a french made yaris 2012, 1.3. I installed ebay oem cruise control stalk , the clutch switch is already in place. But it does not work :( . No light comes on when pressing the on/off , nothing happens if i try to test it while driving.Is there any fuse i should check? i have read the entire thread ,but i did not find anything usefull. Any help is appreciated! |
#18 | |
| Tags |
| cruise control. 2012 |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
