Old 07-23-2007, 01:13 PM   #181
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
i'd like to do this mod, but i'd like to know if there are any cons to this type of mod. does anything get worn out from changing pulleys? changing pulleys changes the cam timing right? how hard is the install? i know theres a diy guide for iton here somewhere i jus want a straight answer from someone who has done it.
Old 07-23-2007, 01:22 PM   #182
whooppee777
so i read every lil facet about pulleys on nst's website and these lite pulleys are the same diameter as the oem pulleys so they dont change timing in any way, right? its because they dont weigh as much as the oem pulley that makes better use of the engines output. am i right?
Old 07-23-2007, 01:28 PM   #183
Black Yaris
der Zeck
Black Yaris's Avatar
size size just lighter, so less rotational mass = better MPG and more HP transfered to the ground because less is being waisted trying to sping the hevier pulley
Old 07-23-2007, 07:44 PM   #184
NonStopTuning
Crank Pulleys and accessory pulleys have nothing to do with cam timing, whether they be underdrive, overdrive, or simply light weight variants. The concept is in regards to the rotating assembly and the transfer of horsepower between the crank shaft and the accessories which translate this horsepower into the services they provide. ie the alternator, a/c, etc.
Adjustable Cam Gears, also called cam pulleys by some, are directly attached to the camshafts and allow the individual tuner to change the timing of the camshafts, thereby changing the powerband of the engine. Adjustable cam gears are usually used in conjunction with aggressive aftermarket camshafts and wouldn't do much for mildly modified engines.
Feel free to look for me on AOL Instant Messenger at the screen name NSTonAIM should you wish to chat about any of our products in further detail. I would be happy to be at your service.
NST FTW FE&EMFs
MIKE @ NST
www.NonStopTuning.com
Old 07-23-2007, 10:09 PM   #185
whooppee777
my problem is i have a dumb ass friend who works on cars, who has an accord with a turbo h22 engine, that thinks he knows everything about cars. and my dumb ass listens to what he says sometime and he told me it will change the timing. this coming from some one who works at a local monroe shop, and works on peoples cars while stoned.
Old 07-26-2007, 11:05 AM   #186
Dezod
The Scion Guru
Dezod's Avatar
Drives: Scions
NST rocks!
We are a proud NST distributor and have MORE stock coming in!
Dezod Motorsports Inc-'We ARE performance."
P: 716-681-6666
E: sales@dezod.com
W: www.dezod.com
Your leading source for all of your performance needs! From turbos and components, to brakes and suspension, Dezod has you covered.
Dezod is offline   Reply With Quote
Old 07-26-2007, 01:38 PM   #187
I got my pulley on today, and there is a nice bump in low-to-midrange. Can't feel much when winding it up, but that's fine.
My only tiny gripe about this pulley is the timing notch is too small, barely there really. Won't matter much until smog time, though, since the car tunes itself. Overall, VERY nice product.
Old 07-26-2007, 01:38 PM   #188
are the other two pulleys available yet?
Old 07-26-2007, 01:39 PM   #189
ChinoCharles
Drives: LB
They are being researched as we speak. Look for the GB coming soon!
Old 07-27-2007, 03:27 PM   #190
RUBBERDIPSTICK
Drives: Toyota Yaris Base Sedan
I'm onboard with the other pullys...lets do this
RUBBERDIPSTICK is offline   Reply With Quote
Old 07-27-2007, 04:22 PM   #191
Jerkratt
Jerkratt's Avatar
im on ti waiting for the GB lol
"It hurts more when its wet"
Old 07-27-2007, 08:18 PM   #192
NonStopTuning
Start looking under your couch cushions, in your ashtrays, and old jean pockets boys and girls. New pulleys are a comin!
MIKE @ NST
Old 07-27-2007, 09:05 PM   #193
Shijima
Drives: 07 HB
I found $135.00 in Change in my room today, its going to be the start of my pulley fund.
Shijima is offline   Reply With Quote
Old 07-28-2007, 12:36 AM   #194
I've been stealing from my son every time I do the laundry.... that's my pulley money.
Old 07-28-2007, 03:51 AM   #195
jdium
Mr Attitude
jdium's Avatar
Drives: Blazing Blue 5 Spd
I understand that it might not be a good thing for vendors or NST to post a dyno chart of before/after, unless the results are premium, but I'd love to see what the real world results of this are...hopefully somebody has access to a dyno for after the GB...gotta see if this is just doing a mod to do a mod...
It's scary to think that half the people surrounding you are below average...
jdium is offline   Reply With Quote
Old 07-28-2007, 03:57 AM   #196
ChinoCharles
Drives: LB
http://yarisworld.com/forums/showthread.php?t=3239
Scroll down on the first page and you'll see dyno sheets from an Acura TSX and Lotus Elise. If NST can make power on a Lotus, you think they can handle your Yaris?
Old 07-28-2007, 04:27 AM   #197
jdium
Mr Attitude
jdium's Avatar
That's what I want to see 1st. The Lotus graph looks terrible, what happened at 6k? As for handling my Yaris, I'm sure it's worth a little hp, but I wanna see the curve. I'm also sure that Toyota wouldn't leave more than a couple hp on the table in a market that is so closely matched.
Old 07-28-2007, 12:19 PM   #198
whooppee777
is he serious?
