Old 12-18-2011, 07:04 PM   #1
Strider199
Strider199's Avatar
Drives: Black 2012 Yaris 3door 5speed
Ok I think it's time those with a 2012 yaris without a tach start posting their installs.
I cant believe my 5 speed manual doesn't come with a tach. I'm looking for a good spot to mount a tach which is close to the connections needed. Air bags in the a-pillar make me nervous.
Who's first?
New to the Toyota World, be nice.
Strider199 is offline   Reply With Quote
Old 12-18-2011, 08:04 PM   #2
Who's first?
For the 2012, the Tach signal is still on pin 9 (light green wire for 2012) of the OBD connector.
The pink wire on the key switch is still ignition switched power for the 2012.
Old 12-28-2011, 02:50 PM   #3
Strider199
Strider199's Avatar
Thanks for the info CTScott.
I went out today to a few stores looking for a tach I like. Did not find one. I bought a new horn which I will install when it warms up this weekend but I'm still looking for a decent tach. Auto Zone and Canadian Tire just don't have the selection. On-line they have a ton of gauges but I hate the extra duty I have to pay being in Canada. Any stores around the Hamilton - GTA area which have a decent selection?
Old 02-11-2012, 09:52 AM   #4
avlisk
Drives: 2002 Rio Cinco
What about a Toyota tach from the SE model? I'm considering buying a Yaris LE automatic, but I want a tach, too. So, would an SE replacement tach be an easy installation? And fit right in the dash where there's a big, round space for one? Thanks in advance for your opinions.
Ken S.
avlisk is offline   Reply With Quote
Old 02-11-2012, 10:21 AM   #5
Ken S.
Yes it will work, but finding one will be very difficult until the 2012 has been out long enough for some to make it to junkyards. Per your other thread about buying one from the dealer; You may have a hard time getting the dealer to order a cluster for you, as they often will not let you order a cluster that doesn't match your VIN configuration. If you are buying a 2012, you can try to make your sale dependent on them ordering the cluster (just make sure you get it in writing on the contract).
Old 02-11-2012, 01:09 PM   #6
RedRide
RedRide's Avatar
On the '09, it the light brown wire for the tach signal.
The brown wire is in the exact same position as the blue wire.
It had me stumped for short while when installing my tack as I also have an '09.
Old 07-31-2012, 07:17 PM   #7
ijose 845
ijose 845's Avatar
Drives: 07 Toyota Yaris
hey im having problems with the greenish blue wire for the rpm read outs. do i stick the wire in the same slot as the greenish blue one? or do i splice the green and the greenish wire together?
Angry Bird Crew #1
ijose 845 is offline   Reply With Quote
Old 07-31-2012, 07:40 PM   #8
Always make a good connection with wiring. Either use a tap splice connecter (that crimps onto the two wires cutting through the insulation to make contact with both wires) or solder and heat shrink the connections.
Old 07-31-2012, 09:56 PM   #9
ijose 845
ijose 845's Avatar
oh okay i got it thanks! and as for the light wire is it okay if i put it on the ingition fuse?? it works pretty well for me now! will it hurt anything?
Angry Bird Crew #1
Old 07-31-2012, 10:40 PM   #10
That's fine if you do it with an add-a-fuse or tap the pink ignition wire on the ignition switch connector. Shoving the fuse in with the wire under it is not a good way to do things.
Old 07-31-2012, 10:50 PM   #11
ijose 845
ijose 845's Avatar
ahh thats what i did....but its in their really snugg. im just afriad to cut any of the factory wires cause i dont want to cut too much or mess up and ruin the car completely :/
Angry Bird Crew #1
Old 11-26-2012, 10:25 PM   #12
guy2can
guy2can
Drives: 2012 Yaris SE
2004 Echo RS Tach
2004 Echo RS H/B: Installed an Equus Tach from Canadian Tire, picked up power via add fuse (7.5a)at the "ACC" fuse, and also spliced it for he display power. The tach wire on this card on the OBD2 plug was black with a silver band.
guy2can is offline   Reply With Quote
Old 11-27-2012, 06:43 PM   #13
cdilmore
Drives: 2010
Sharrrp!
cdilmore is offline   Reply With Quote
Old 08-29-2013, 11:19 PM   #14
YarisAddict
Drives: 09 Yaris 3drHatch
No Tach reading
I Spliced the green wire into an orange wire that is on the far bottom left on the ecu port. I've read online that that was where I'm supposed to do it since I have tire pressure monitor. The orange wire is in replace of the greenish blue wire your talking about in cars with tire pressure monitor. It has been driving me crazy that it wont read rpms. Lights work and it has power, also I put my ground exactly where you have yours. Any Ideas?
Thx
09 Yaris3drhatch
YarisAddict is offline   Reply With Quote
Old 08-29-2013, 11:22 PM   #15
Thx
09 Yaris3drhatch
The orange wire is the correct one for your car. Double check your splice, particularly if you used a tap splice, as that wire is only about 24 AWG, so the tap splice needs to be a tiny one to make a proper connection.
Old 08-30-2013, 12:45 AM   #16
YarisAddict
I used the one that came with the kit. Is there any other way to splice the wires together? I'm just afraid now that the orange wire is basically in half once I remove that little plastic connector. Sorry I'm a noob when it comes to the wiring side of things.
Old 08-30-2013, 06:53 AM   #17
The best method is to strip insulation off both wires and solder them together and then tape or heat shrink. But, crimp on splices are fine as long as they are the correct size for the wires. If you remove yours and find it did cut the wire, it is actually not a big deal, since the tach signal to the OBD connector is really not used by anything.
Old 03-07-2015, 11:59 PM   #18
jesus43block
Drives: yaris 2007
de donde sacastes la seņal del rpm ? la puse en el cable azul y no me llega completa
jesus43block is offline   Reply With Quote
Liftback Spoiler Installation Toddhata Cosmetic Modifications (Exterior/Interior) 25 08-09-2009 01:26 AM
