Old 12-14-2011, 08:30 AM   #1
syntax
syntax's Avatar
Originally Posted by zsazsa zaturnnah View Post
after almost 1.5 years of driving Kermit, ngayon ko lang nalaman na aside from tilt eh telescopic nga ang steering churva ng Yaris YX! sa tangkad kasi ng lola nyo eh sagad na yong upuan ko at feeling malayo ang manibela; accidentally, nagaadjust ako ng tilt ng steering ng mahugot ko sya towards me .. kala ko nasira ... yun pala ang telescopic eklat nya! then i went to search for it sa youtube watching toyota prius ... yun pala yun!
heheheheh parang ung the great debate ng octane 95 or octane 91 wehehehehe
Old 12-14-2011, 10:10 AM   #2
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
ang fleet ba meron nyan
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 12-14-2011, 02:54 PM   #3
marble_bearing
marble_bearing's Avatar
Drives: 2008 yaris y silver
yx and sportivo only po? kaya sorry na lang tayo mga fleet at y...
marble_bearing is offline   Reply With Quote
Old 12-15-2011, 12:58 AM   #4
syntax
syntax's Avatar
waahhhh..... kaya pa kahit anong hatak ang gawin ko dati hindi nahahatak.. buti na lang hindi ko na pwersa nyahahahaha
Old 03-25-2012, 07:54 AM   #5
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Yung sa akin nahahatak, nababaluktot, at paikot ikot....diba ganun ang manibela he he he jookeee!!!
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 02-15-2012, 05:33 AM   #6
rickyml
rickyml's Avatar
Drives: Yaris 2008
advisable ba na painitin muna ang makina bago itakbo? may nakikita tayo sa dushboard na "COOL" diba... hinihintay ko muna mawala yon bago ko patakbuhin... dapat ba ganon? or okay lang pagka-start takbo na?
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 02-15-2012, 05:39 AM   #7
duke_afterdeath
for me tol pag start takbo na pero hidi harurot, alalay lang din hanggang mawala ung sign na "cool" pwede daw ito ayon sa nabasa ko before sa isang thread, na ang mga bagong modelo nga daw ay ganun..
Old 02-15-2012, 07:01 AM   #8
syntax
syntax's Avatar
@ duke and insan,
for me inaantay ko lang bumaba ng less 1K ung rpm then saka takbo, pero alalay pa rin hanggang mawala ung "cool" sign.
Old 03-25-2012, 02:02 AM   #9
rickyml
rickyml's Avatar
Drives: Yaris 2008
standard ba ang bulb ng fog light natin or iba2 rin ng part no.? napundi na kasi yung isang fog light ko at balak kong palitan.
Old 03-25-2012, 03:24 AM   #10
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
@ricky, H11 ang bulbs ng fog lights natin.(Stock [OEM] or Xenon light).
jonimac is offline   Reply With Quote
Old 03-26-2012, 03:07 PM   #11
gwafu187
Drives: Yaris Y 2007, Blue
Not using A/C for 3 days now may napapansin akong kakaibang amoy (something like nasusunog na goma), pag naka-on ang A/C walang kakaibang amoy, i guess this kind of smell is coming from clutch lining? coz for some delay of releasing the clutch then merong konting sticky upon releasing the feet from the clutch pad, for changing the gear smooth naman siya at wala namang sabit, i guess some of you guys ay may idea sa ganitong problema. is it normal or need ko ng dalhin sa shop? input pls...
gwafu187 is offline   Reply With Quote
Old 03-27-2012, 12:36 AM   #12
charlieXX
Corporate Slave
charlieXX's Avatar
First question: Are you a clutch driver? do you hang on to the clutch longer than usual or full release agad?
It could also be electrical wiring burning may aftermarket mods ka na ba? sound or lights?
Monitor mo muna tol ako dati may naamoy ding ganyan I just pushed in all the fuses and checked the connections under the dash nawala naman
Old 03-27-2012, 03:56 AM   #13
gwafu187
Many thanks sa mga inputs po ninyo, @charlie im not hanging on longer than usual, as soon as changed into next gear, unti unti then release...good idea to check 1st other causes...baka nga may mga nakasabit lang...ty po sa mga info.
Old 03-27-2012, 01:52 AM   #14
syntax
syntax's Avatar
pre did you checked under the car? baka may nadikit na plastic sa may exhaust muffler or sa mga tubo nun? kaya parang may naamoy ka na nasusunog na plastic or goma?
Old 03-27-2012, 01:59 AM   #15
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
ganyan din nangyari sa akin, amoy nasusunog, dinala ko sa toyota, normal naman daw, buti at nasabi ata ni duke sa akin na tingnan sa ilalim, yun pala dumikit yung plastic sa exhaust...hehehe
Ciao !!!
xtremist is offline   Reply With Quote
Old 03-27-2012, 02:12 PM   #16
gwafu187
Natumbok mo @syntax...right after ofis hour sinilip ko sa ilalim...bingo!! may naka dikit nga na piraso ng plastik sa pipe na malapit sa muffler, masyado ng dikit ang hirap kunin...dapat siguro painitin ang makina para lumambot...ito ang maganda sa thread madaling naso solve mga mumunting problema...whew!!! nakaligtas ako sa labor cost ng ALJ..guys, salamat sa mga inputs nyo....
Old 03-27-2012, 04:15 PM   #17
charlieXX
Corporate Slave
charlieXX's Avatar
Ayos tumatanggap naman si Syntax ng prof fee in the form of puto pao or shrimps
Old 03-28-2012, 01:07 AM   #18
syntax
syntax's Avatar
nyahahahahahha ung puto pao ok un, ung shrimps para kay duke un wahahahaha
