Old 06-10-2012, 12:04 PM   #1
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
hindi may kukuha diyan truck namin ha ha ha
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 06-11-2012, 02:05 AM   #2
syntax
syntax's Avatar
ayun naman pala eh, eh di karga na kung ano maikkarga sa truck wehehehehe
Old 06-11-2012, 05:53 AM   #3
rickyml
rickyml's Avatar
Drives: Yaris 2008
muffler lang naman, hindi naman buong engine... hehhehe
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 06-13-2012, 02:54 AM   #4
zsazsa zaturnnah
zsazsa zaturnnah's Avatar
ay! kelan naman daw ang balik ng truck pa-khobar? pabili ako ng black side skirt (pair) diyan sa riyadh!
zsazsa zaturnnah is offline   Reply With Quote
Old 06-13-2012, 05:07 AM   #5
syntax
syntax's Avatar
mamang mas maganda ata go ka na sa riyadh para sabay ikabit na rin
Old 06-14-2012, 01:10 AM   #6
zsazsa zaturnnah
hmmm ... pwede ... kasi maglo-local vacation lang ako sa next month pag natapos ang transfer ko ng sponsor ... sana may kasabay!
Old 06-14-2012, 01:27 AM   #7
syntax
syntax's Avatar
yann... i sked na yan mga kayaris of the east... pwede rin itapat sa next month 1st friday meet....
Old 06-13-2012, 03:33 AM   #8
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
@ricky, tol tinanong ko si kuya ike about sa CF nya sa hood iba naman ang pinanglilinis nya, ang ginagamit naman daw nya is ung liquid wax ung in spray..
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 06-13-2012, 05:37 AM   #9
rickyml
rickyml's Avatar
Drives: Yaris 2008
may nabili na ako na pang-dash board/tyre spray cleaner na turtle wax (10SR). effective naman sya. inaabot ng 1week ang pagkaitim nya. thanks anyway, ano raw tatak nung ginagamit ni sir ike?
Old 06-13-2012, 10:57 AM   #10
duke_afterdeath
ah ok ganyan gamit naman ni emerson pang dash board ndi ko lang alam kung same ng brand.. itanong ko din kay kuya ike anong brand nung spray wax na gamit nya
Old 06-13-2012, 07:21 AM   #11
kaemong
Drives: yaris 2008
mga sir, konting katanungan at tulong...
ang yaris ko kasi buhat nung pinalinis ko yong throttle, lumabas na yong Malfunction Indicator lamp. Ok naman ang takbo nya walang problema sa hatak. naaburido lang talaga ako sa ilaw na yon. tapos last week, tiningnan ko yong pagkahigpit ung malapit sa throttle eh maluwang siya, so hinigpitan ko baka may singaw lang...pero ganun pa rin, di pa rin nawawala ung ilaw, 1 month na cguro na ganun. saan kaya pwedi ipaayos yon, yong di masyadong mabigat sa bulsa kasi wala pa budget...nakaka-aborido lang na may makita ako ilaw...salamat sa suggestion...
kaemong is offline   Reply With Quote
Old 06-13-2012, 09:01 AM   #12
syntax
syntax's Avatar
pre' try mo nga ireset ang ecu ng yaris, tanggalin mo ang positive at negative terminals sa battery ( konting ingat lang baka mag short) then after 5-7 minutes ibalik mo ulit check mo kung andun pa ang indicator...
Old 06-16-2012, 09:22 AM   #13
kaemong
Drives: yaris 2008
pre, ganun pa rin, tinanggal ko na overnight ung battery ko, pagkabit ko ng umaga ganun pa rin lumalabas pa rin ung malfunction indicator...ano pa kaya paraan?
Old 06-16-2012, 09:58 AM   #14
syntax
syntax's Avatar
pre both terminals ba na tinanggal mo? kung ganun pa rin baka may fault na talaga, bago mangyari un, ano ba ginawa sa sasakyan mo?
Old 06-16-2012, 10:34 AM   #15
kaemong
Drives: yaris 2008
oo pre, both terminals tinanggal ko na. pinalinis ko lang yong throttle nya, bumili ako ng AC delco na X66a. tapos napansin ko lumabas na yong Malfunction indicator lamp. ok naman hatak nya kasi isang buwan na rin na ganun. lastweek napansin ko maluwang ung lock nung hose na nakakabit sa throttle nya so hinigpitan ko, pero ganun pa rin.
balak ko na sana dalhin sa toyota kaso wala pa ako budget, bayaran ng bahay ngayon eh.
Old 08-12-2012, 02:35 AM   #16
kaemong
Drives: yaris 2008
pina computer scan ko na yaris ko para makita kung ano problema nya. lumabas na ung sensor dun both sides sa may block (di ko alam kung ano name nun - binabalance daw nun ang timing) tinanung kung ung kabayan kung magkano abutin pag ipagawa ko, kulang-kulang 500 SAR daw. waaaaaaaa...canvas muna baka may mabilhan pa na mas mura.
btw. pinagawa ko na rin pala kagabi ung water pump ko na maingay, parang sirang bearing, bumili ako ng bago (195 SAR) nawala na ung malakas na ingay pero may naririnig pa rin ako from air compressor naman. suspect ko may tama ung pinalit na air compressor. may nagrerepair ba ng air compressor bearing?
Old 06-17-2012, 01:30 PM   #17
EjDaPogi
EjDaPogi's Avatar
Drives: 2008 Yaris Fleet (SilverWings)
Commercial muna tayo...
HAPPY FATHER'S DAY SA LAHAT NG MGA GUAPONG TATAY!!!
EjDaPogi is offline   Reply With Quote
Old 06-18-2012, 07:33 AM   #18
duke_afterdeath
kasama yata ako d2, hahaha.. hapi father's day din tol!!!
