#1 |
Roadrunner Jr.
They're at the same height but no, they're aimed about 15 degrees up from horizontal. This aiming gives me rock solid imaging and height. The tweeters in the pillars are good for width, height and worrying less about crossover points. The "blend" will be easier than with the tweeters separated as they were this year. I could have it sounding off tonight if I pleased but...I want absolute control before info this again...and with the P-01 acting all bejiggity, I'd rather not risk it.
I also put a couple layers of high build primer on the pillars as well. Lots of work gets done when I don't have a wife hanging around. The "to do" list becomes very basic and simple. Edit: I got my paws on the service manual for the P-99RS...anyone who started this post that needs one in the future knows now where to get it and give it to a repair center if needed. My P-01 is going out the Pyramid Audio tomorrow morning. Within the month, I'll be back up working again.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine Last edited by sqcomp; 10-01-2012 at 10:09 PM. |
#2 | |
D.
. CLA 250, 4MATIC |
#3 |
I just order another port system for my experiment with 2 i6SW's!
![]() D.
. CLA 250, 4MATIC |
#4 |
Roadrunner Jr.
Yes, I misspoke, the sail panels, not the pillars.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#5 |
Some Left and Right EQ...
![]() ![]() More tuning soon... D.
. CLA 250, 4MATIC |
#6 |
Roadrunner Jr.
![]() I know this exercise...We don't center match in the mid and sub bass regions simply because at 175 Hz and below, the bass isn't localizing for the most part. I'd imagine this is going to change drastically when the mids are back on top. I have to make a mic jig and find a 3055 I can play with locally... The sub however is down 9 dB You can also see I had to pump up the output. My gains are pretty much off...I suppose I could change that though.
#7 |
I enjoy doing several passes at different conditions for example....
parked with engine off, parked with engine in idle and then driving at about 70 mph. ![]() T/A ![]() X-over Points
. CLA 250, 4MATIC |
#8 |
Where's my crown?
Drives: 07 self proclaimed TRD Sedan Join Date: Sep 2012
So heres the thing. 2 -400w amps pushing 2- 12" Terminator subs each independent of one another. My trunk rattles... my gas door rattles... looking through my rearview is like having michael j fox holding it. So what do I do to eliminate the vibration? without compromising sound quality? 2-subs-4-mids-4 voice....
I am the obvious resolve to the age old question, "What happens when an unstoppable force meets an immovable object?"
#9 | |
Then last resource is... turn down the gains to mach your other speakers. D.
. CLA 250, 4MATIC |
#10 |
Roadrunner Jr.
D,
throw this T/A in and give it a try just for the hell of it (I think this is CM not IN IIRC)...and actually you can reduce the sub too I think. I was just playing with that part:
#11 | |
Inside the Pioneer world 155.39" (max number in TA) means (0) zero delay, and what I do is to delay the closest speakers to my left ear to get the signal rich both ears at the same time. That is why you see my right Mid at 155.39" and every thing goes from there. If I had the sub in the trunk that would be the furthest speaker and will get 0 (zero) delay AKA 155.39" 0" (zero) would be like to delay at maximum the left side Mid and Mid/Bass ![]() D.
. CLA 250, 4MATIC |
#12 |
These may not mean a lot to YarisWorld, but to my ears it's like GOLD!
![]() Right side: ![]() Left side: ![]() D.
. CLA 250, 4MATIC |
#13 |
Roadrunner Jr.
I'm more interested in the equalization more than the time alignment anyway. There was a huge difference between your system and mine, seeing as mine had that processor on it. The messed up thing is that every brand does their time alignment different it seems. You'll see where I go when I get the P01 repaired... And what ever processor I put in there.
I just had an offer from one of the Arc dealers and I'm still comparing with the Zapco dealer as well on the processors. We just have to see what happens after the P01 gets back from repair.
#14 | |
Yes, equalization had a much bigger impact than Time alignment for the... WOW Factor! Yes every brand does it different, took me a while to understand each method and assuming milliseconds against inches, but at some point TA had to be the same function. How come I never get offers? I should market more aggressive LOL D.
. CLA 250, 4MATIC |
#15 |
Roadrunner Jr.
Mmm...there are probably several reasons why no offers.
They aren't because you're not a nice guy. The biggest reason is that these manufacturers have seen my face at CES for several years now. I suppose you could say I'm known in the industry. All of this is based on my appearances at CES really. Networking man, networking! Heck, You know that Arc audio piece the PS8? I have that in my hands last year. I saw how it worked in the demo vehicle. I saw its physical size without it's "big shroud" and yeah... I mean I had the attention of one of the players at Arc audio even though I'm not running any Arc audio gear. All of this just by attending CES and spending a few minutes talking to people and the little fact that I can cook and I was able to give people food when they were really hungry. Time and place mang...time and place. Not only the CES factor but those people know me and they see how I support the brick-and-mortar stores. I've also been responsible for making IASCA a factor here in the Northwest again. It's terrible but it seems like I'm playing my own trumpet here but really I'm not. It's just several factors I mentioned plus there some other factors aside from what I mentioned before. The thing is Derick, you could do the same thing. All it is is simply time invested into the industry & face time with networking. It all started 12 years ago when I decided to work for a few months at a high end stereo shop. That's where I met Jim before he owned his first shop. That snowballed into appearances at CES and INAC finals.
#16 |
Yes I know what you mean, before rediscovering my passion for car audio, and been single I was in the R/C airplane world. And I got to know lots of people and companies giving me all kind of goodies for the hobby.
D.
. CLA 250, 4MATIC |
#17 |
Roadrunner Jr.
Interesting development...
I'm working on a deal for a Whiteline adjustable rear sway bar. That should go nicely with the pro kit drop... D, do you have sway bars on yours? If so, what is your impression?
#18 | |
100% HAPPY!!! No sway bar?... It's like a SQ system without Time/Alignment, Improves: -Cornering like crazy, -Highway stability x 10 -Cross winds not an issue any more at highway speeds D.
. CLA 250, 4MATIC |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
