Old 08-22-2009, 11:05 AM   #1
mrbond
mrbond's Avatar
Just got an Ecometer yesterday from Garm, and I have to say this is probably one of the best things I've bought for the Yaris, right up there with the Fujitsubo. I drove the car the way I normally do, and I'm getting about 36.6 mpg average. It's great to be able to have a tangible way of monitoring the effect your driving style has on mpg. Can't wait till the next tank, so I can experiment with different ways of driving. Greatest $70 so far.
- A Toyota Yaris
- A whut Yaris?
Old 08-23-2009, 03:27 PM   #2
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
The ecometer does not display or erase trouble codes. If you want that capability and extra engine info the SG II is the way to go. If you only need instant mpg, avg mpg and tach than the ecometer is a less expensive way to get there.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 08-24-2009, 12:14 PM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
R2
Code reading/erasing is awesome... I've already used it on 2 peoples cars.. the GF's and a co-workers... both cars are 00 or newer too
Old 08-24-2009, 04:59 PM   #4
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Yep a code reader is handy alright! I went with the ecometer though because I already had an Innova scan tool and all I really needed was the tach and instant mpg. Both units have their place depending on what you need and how much one wants to spend.
R2
-The Fitful One
Old 08-24-2009, 11:30 AM   #5
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
engine codes would complete the perfectness of the ecometer.
Check out my Build thread:
Old 09-02-2009, 05:56 PM   #6
ezhacker1
ezhacker1's Avatar
iv noticed that using neutral a lot compared to DFCO produces near perfect readings at the pump. DFCO seems to result in readings ~7% higher than actual. anyone else?
Old 09-02-2009, 06:42 PM   #7
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
I used to use neutral to coast a lot a long time ago, one day I just switched over to never using neutral. I went from consistently getting 36MPG to 39MPG.
Old 09-02-2009, 11:47 PM   #8
Sandwash
Drives: 2009 Yaris w/man.trans.
Yes, but...
I believe your results per calcs - but it defies common sense considering total disengagement that is 'neutral.' Even with engine cut-off, you wouldn't expect these results. Will be getting ecometer soon and will let all know of change of habits and mpg upon monitoring.
Sandwash is offline   Reply With Quote
Old 09-09-2009, 09:03 AM   #9
09box
Drives: 09 grey Yaris hatch
I know it has probably been all spelled out but what exactly is involved in the install of this?
09box is offline   Reply With Quote
Old 09-09-2009, 12:54 PM   #10
DevilGirl
Drives: 09 3dr LB MT
I have my Ecometer sittin on my dash to the left of the gauge cluster (double-sided tape), with the wire running across the dash under my TomTom mount, and down the a-pillar to the OBDII port. (I'll try to post a pic later today if I remember.)
Really, all you need to do is plug it into the OBDII, run your wire how you want it, and mount it where you want it. That's all.
Old 09-09-2009, 01:57 PM   #11
R2D2
Crazy Oil Sniffer
R2D2's Avatar
DevilGirl,
So you bought the ecometer-how do you like it so far?
R2
-The Fitful One
Old 09-09-2009, 07:27 PM   #12
DevilGirl
DevilGirl,
R2
It's good. I use it for the tach and the MPG's. I'm still working on evening out my acceleration techniques (darn manual tranny ), but I think once I get that worked out, it will become even more useful than it is.
I also have the TomTom Go 740 Live which alerts me when I go above a set speed (72 for me), so I have that as a backup to help keep my speeding under control. Came in handy today. There was a cop sitting with a radar detector on the way home today.
Old 09-10-2009, 03:26 PM   #13
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Good glad it's working out. Most people seem to be very happy with them.
R2
-The Fitful One
Old 09-10-2009, 07:32 PM   #14
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
I want to get one of these, how hard is it to hook up? I know nothing about cars or mechanical issues with cars..so will i have a hard time hooking it up? And does it calculate when your sitting there idle?
Twistoffate0817 is offline   Reply With Quote
Old 09-10-2009, 09:26 PM   #15
rihdrkc
Blazing Blue Yaris
rihdrkc's Avatar
Drives: 2009 Yaris 3 door Liftback
Simple plug and play. Just stick it where you think it looks best.
rihdrkc is offline   Reply With Quote
Old 01-29-2010, 06:34 PM   #16
Twistoffate0817
Is this still worth it to everyone? I just want something where i can keep it plugged in, and whenever iturn the car on and go it will show me my instant MPG. Do i need to reset this or anything? When i get gas do i need to reset it?
Old 02-23-2010, 04:32 PM   #17
Twistoffate0817
Hello all, I have recieved my eco meter today!
I just got back from testing it, and am afraid to say that im dissapointed in the product.
Maybe the thing needs some settings adjusted in order to work better:
I followed the instructions to get to the EEF i think it said, and it says to adjust it from 60-140 if its calculating too high. My eco meter was all over the place every second. going from 11 to 140 within one second. (mpg that is)
So i set the EEF at 61.
What is everyone elses set at?
My other problem is: Whenever i have my foot on accel pedal the MPG seems fine. whenever i take it off it quickly zooms to 100+ and when i put my foot back on it takes my mpg up to 55-65. This seems very off.
Also when I come to a complete stop the eco meter goes to 0 and stays there. This is wrong too from what I have been reading.
What am i supposed to be setting this thing at?
Is there something I am doing wrong?
Old 09-11-2009, 12:10 AM   #18
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Easy as pie
Yep it really is just a plug and play. Plug into the obd II port, route the wire out of the way and mount in an easy to see location. The A pillar, steering column (just mount far enough forward to allow clearance for driver side glove box to open) and near the center gauge cluster seem to be popular choices. The enclosed 3M temporary industrial fastener works quite well, as does 3m double sided trim tape available at auto parts stores. There is no permanent alteration to the vehicle required.
The ecometer calculates mpg anytime the engine is running, including while idling. You can watch your avg mpg drop as you idle. It is very accurate-mine has always been within .7 mpg or so of calculating by the "pump method" at fill up.
This is a long thread, but there are quite a few good points and mounting ideas mentioned here if you can work through it. Most everyone seems to be very satisfied with their ecometer.
Hope this helps!
R2
-The Fitful One
