| View Poll Results: Would you buy one? | |||
| No |
5 | 5.10% |
| Yes (for $75) |
46 | 46.94% |
| Yes (but it would have to be less than $75) |
7 | 7.14% |
| Yes (but I still want it to also display the time) |
40 | 40.82% |
| Voters: 98. You may not vote on this poll | |||
Thread Tools | Display Modes |
#1 |
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
This is so awesome Scott you have covered everything needed and a lot more. You really went the extra mile by adding cruise control indicator, and all the other new things.
I like the new screen better. Can't wait!!! Can't wait!!! |
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
is fuel system status like how many gallons left?
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
#3 |
Our off road vehicle
Drives: 2009 Yaris 3dr Join Date: Apr 2009
A related issue to the Yargauge- In trying out the OZ cluster I ham fistedly broke the tabs on the front of the bezel trim and need a new one to make my dash look 100%. First off I want to warn Yargauge buyers to be VERY VERY careful removing the bezel as the front tabs are extremely fragile. If they break off on removal the dash loses the tight shuntline right in the front where it's most noticeable when you reinstall the bezel- so be careful guys. Secondly I wanted to ask if anyone knows if the bezel trim is the same on the sedan and hatch. There are always these parts available on eBay but most seem to be from sedans. Thanks for the help fellow Yargauge enthusiasts!
#4 | |
The sedan and LB ones are different. When removing the cluster trim, the key to not breaking the tabs is to pull the cluster trim with the radio surround. They separate much easier when off then when on the car, because of the angle required to gently pull the cluster's tabs out of the top of the radio trim. (I didn't figure that out until about to 10th time I had my dash apart). |
#5 |
Thanks Scott- I envisioned a run on bezels when the YarGauge hit the streets.
#6 |
Around when can we expect this to be done?
#7 |
#8 |
![]() ![]() ![]() ![]() ![]() Drives: '09 Yaris carmine red 2d HB Join Date: Jun 2009
Excellent !
#9 |
![]() Drives: Yaris 2008 Sedan Join Date: Jan 2010
Any ideas for applying the Yargauge to the sedan versions? I'm still trying to think of an external location that would be effective.
#10 | |
The two will be: 1. A panel which replaces the left center vent grill. 2. A single DIN plate (for those who have replaced their OEM radio with a single DIN radio). |
#11 | |
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
#12 |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
My money is ready to leave my pockets.
#13 |
![]() ![]() ![]() Drives: 2011 VW Golf TDI Join Date: Oct 2009
Hi Scott,
For the mi/km to empty feature, I think the cars that have this built in average this. Most times when the mpg feature is installed in the car, it has two screens instantaneous and average. I think the mi/empty is based on the rolling average so the value doesn't increase based on acceleration/cruise/coast/idle, etc. I'm not sure if it's possible in the controller you are using, but if so, can it be based on an average? Doesn't matter... I'm still gunna buy it and I can ignore the value while accelerating. |
#14 | |
I was working on the interface to the fuel level wire last night. and was thinking about that. I agree that the data needs to be averaged, otherwise the miles until empty would bounce all over (from 80 miles with a full tank while goosing it, to infinity when in DFCO). |
#15 |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
great video of the first steps needed on removing the front plastics
to get to the gauge cluster. http://www.youtube.com/watch?v=nBTIJLk-EZo |
#16 |
Just lookin for an update.
#17 |
#18 |
with all the revisions will this unit be able to do my daughters math homework ?
| in dash clock as tach? | Cosmonaut | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 07-12-2010 11:27 AM |
| digital tach, 52mm, preferably blue leds | severous01 | Cosmetic Modifications (Exterior/Interior) | 5 | 05-15-2009 10:58 AM |
| Digital Tach | nqd | Performance Modifications | 4 | 05-17-2007 12:04 PM |
