#199 |
![]() Drives: 2014 Yaris L Join Date: Apr 2016
Got the stalk from Scott for $50 and the trim piece for $5-he was very fast with shipping and easy to communicate with. I have the base US model with no buttons on the steering wheel, and installation was a breeze. Park with the steering wheel upside down to make it a little easier to get to the pins that release the airbag and steering wheel cover. The photos were really helpful to know what the release pins for the steering wheel look like/where they were so it only took a minute to take it off. I disconnected the battery and let it sit for half an hour just to be safe, but once I got the airbag off I just held/balanced it on the wheel while I installed the stalk, didn't bother doing anything to disconnect it completely. With the airbag off there was just one 4-pin connection and a horn wire to connect, would have been almost impossible to mess up. This saved me so much $$, and probably only took 15 minutes in total.
#200 |
![]() ![]() Drives: Yaris 2014, Y. HSD 2013 Join Date: Feb 2013
Hello Everyone,
Since I've installed an used switch cruise control on my second Yaris 2013. Led cruise control cluster blinking (https://youtu.be/055DBpCVR6A ) . Does I need change stalk cruise crontol ? Or does exist something to fix it ? Thanks for your help. |
#201 | |
#202 |
Hello Mr Scott,
Thanks for your prompt reply. Hum I believe that's it. It's a manual 99 horses power vvti. I put on a Verso-s (Ractis, NSP120 100VVTI same engine and manual transmission) switch cruise control find on car's mum to new yaris. Light blinking. Verso-s is little more largest car based on yaris chassis. Some pieces can be able the Yaris 2012 that's dealer have said. A second try with switch cruise control on my first yaris 2013 D4d and light blinking yet. Does the problem come from the multiplex whose doesn't support additional plugging? Or any stalk cruise control can be fix this problem? |
#203 | |
#204 |
![]() Drives: yaris 2016 Join Date: Apr 2016
![]() Everything perfect and for me.special thanks to Gagi Sent from my iPad using Tapatalk |
#205 |
Drives: Yaris 2012 Join Date: Sep 2016
2012 1.0 yaris TR VVT-i manual cruise control
hi guys,
my first post ever on a car forum. purchased my first ever yaris which I'm so pleased with. desperate to have the cruise control on the car so i purchased it from eBay for like £19. its arrived, i removed the air bag, connected the stalk and the connector into the unused four pin slot on the right of the ten pin connector. set everything back up, and the cruise light won't come on. I'm so upset. please tell me what it could be! my engine code is 1KFR. its a 1litre petrol manual 2012 plate has the touch and go system with the bluetooth call buttons on the right of the steering wheel aswell. awaiting your expert advice! thanks |
#206 | |
Only the 1.33L European Yaris have cruise control built into the ECM. Your car does not, so the kit will not work. You would need a complete aftermarket solution to have cruise control on your car.
#207 |
the hybrid yaris has built for cruise control?
Sent from my iPhone using Tapatalk |
#208 | |
Yes. The hybrid does have cruise control built in.
#209 |
![]() Drives: yaris Join Date: Sep 2016
Hello CTScott, i own a 2012 yaris with 1nr-fe engine and 6-speed manual transmission. My steering wheel has both audio and bluetooth buttons and today i installed the cruise control stalk with no success. i plugged the 4-pin connector in the empty slot next to the 10-pin connector but the light does not come on when i press the on- off button. The only difference i noticed from the previously posted photos is that the airbag has only one orange connector, not two. Everything else looks the same. Any idea?
#210 | |
#211 |
![]() Drives: Yaris 2012 Join Date: Feb 2013
My CC-light to not working, but otherwise CC works flawless :) You must test on the road.
#212 |
Thank you for your fast replies but my engine IS the 1,33 L variant- 1329 cc to be exact. This is why I am confused. I did not know that this could be the case meaning the cruise control can work at the same time the light remains unlit. Has anyone else experience the same situation?
#213 |
![]() Drives: Yaris 1.3 2012 Join Date: Jul 2016
hey everyone!
I am from greece, i have a french made yaris 2012, 1.3. I installed ebay oem cruise control stalk , the clutch switch is already in place. But it does not work :( . No light comes on when pressing the on/off , nothing happens if i try to test it while driving.Is there any fuse i should check? i have read the entire thread ,but i did not find anything usefull. Any help is appreciated! |
#214 | |
#215 | |
#update just came back from my night shift and i had the chance to try it again in open road. Cruise control works fine , i made mistake with on/off and clicking the set button the fist time yesterday. the cc light does not work though. i guess there is no way of fixing it, right? |
#216 |
![]() Drives: 2014 yaris l, magnetic gray Join Date: May 2016
hello ctscott, i would like to add cruise control to my u.s. spec, french made, 2014 yaris L, 1.5 engine, auto trans, that is my southwest snowbird car. i tried to pm you and also went to your f.b. page, both didnt go thru. can you advise how to order your kit? i will ask a local japanese specialty mechanic to do it for me. thanks!
| Tags |
| cruise control. 2012 |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
