Old 06-29-2007, 08:46 PM   #199
Jerkratt
Jerkratt's Avatar
ok there is stuff higher then 93 in north america its ether 94 or 95 from shell or sunoco
"It hurts more when its wet"
Jerkratt is offline
Old 06-30-2007, 01:01 AM   #200
wow, i can't stand to read this thread anymore, and it's my own thread. lol...
Kaotic Lazagna is offline
Old 06-30-2007, 03:18 AM   #201
davembfan
I usually get 87, but i got 89 once and it was about the same with mpg. since I have had my car i've always used shell gas, don't plan on using another brand. I've always been weird with gas and my cars, always fill up the same place, usually the same pump. Unless of course im on a trip, but then ill still use shell.
davembfan is offline
Old 06-30-2007, 05:03 AM   #202
Edd
Drives: None
Using higher octane than recommended will NOT make the engine knock*. It will make it less likely to knock. Higher octane = more stable and less likely to prematurely combust.
Members in this thread are correct in saying that you will most likely have no benefit from increasing the octane rating on the fuel (unless your car knocks at the recommended amount).
The top fuels (98 RON) are there to replace leaded petrol. Back in the day, lead was THE way to boost octane. Now we can achieve higher octane ratings without it, there is no need to burn lead in old cars.
*Heh, I just read the last couple of pages and I don't think anyone said it would. Nevermind then.
Edd is offline
Old 06-30-2007, 11:45 PM   #203
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
Thumbs up
+1 ...last post from me for this thread... i promise...
fu_im_from_texas is offline
Old 08-15-2007, 12:58 PM   #204
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
so whats the verdict on this topic?? is premium 89 octane gives out better mileage or is it regular gas 87 octane.. what is it??
marcus is offline
Old 08-15-2007, 01:40 PM   #205
Pavel Olavich
Drives: 2007 Yaris LB
Edd, you make very good points. I just want to add that high octane is not just for old engines that required lead. In fact there are many very old cars that didn't need high octane, yet they did require lead. Even some 2008 models require high octane, for it's slower combustion properties; often these engines are large in displacement, and/or provide very high compression, and/or they utilize a turbo that requires a delayed burn inside the cylinder.
Reality Check Folks: Our small 1.5L low compression, non-turbo, low, low performance Yaris cars are the LAST car to get any benefit from high octane gas.
Lets get real here folks....most of the "benefits" many think they get is all in their heads....anyone hear of the Placebo effect?
Funny how age comes into play on this issue. My two teenaged daughters, both drivers, have several male friends in their age group, that all drive late model Japanese cars that DON'T require high octane, yet they ALL only use high octane gas, as they all have this dillusion of premium giving more "power" and more "speed".
Teenagers! Youth! LOL
Save your money, and be happy.
Pavel Olavich is offline
Old 08-15-2007, 01:47 PM   #206
Pavel Olavich
Originally Posted by hystria View Post
TRUE. As per Yaris manual, it recommends 87 or higher. Why "or higher" ? Ever wonder why Toyota recommends wasting your money ? With NO REASON ? Is Toyota in business with Shell ? Well, if not, there should be a reason, unless there are places on Earth that sell only 89 or higher octane gasoline... don't think so...
Engines are optimized to run with a precise level of octane. If an engine requires 87 and the owner put 89 or higher, there will be absolutely no benefit for the engine. On the other hand, if and engine is optimized to run with 89 and the owner uses 87, the engine will not run at 100% performance. It will knock more or little because the mixture ignites before the optimum moment during compression, thus leading to hot points on the piston/ring surface. Because the mixture ignites before the moment when the engine compression is optimal, it produces less overall performance. But not by much, one will not be able to feel any difference.
To resume... if using 87 the engine starts knocking, try changing the brand... the Yaris engine should not be knocking to an audible/damageable level while using good quality 87 octane gasoline.
The "or higher" phrase only means that if 87 is not available, then using a higher octane is not going to damage your engine.
Don't be so quick to read more into the words, then what is literally meant.
Also, to suggest as a remedy, to use higher octane than called for in the manual, a way to remove knocking is plain wrong. It would be far better to take the car in and determine why it is knocking at the required octane, and to remedy the problem. Going up in octane is a band-aide that only masks a real problem.
Old 08-15-2007, 01:52 PM   #207
Since this topic is back alive, I should mention that I tried a higher octane in my last two tanks, with no noticeable increase in mileage and/or performance. Mind you, it was an ethanol mix, so it may have had a part to play. You won't blow up your engine with higher octane, but whatever benefits probably do not outweigh the extra cost.
eTiMaGo is offline
Old 08-15-2007, 01:52 PM   #208
Pavel Olavich
i find the yaris timing is right on the border of you being able to use 87 octane. slight change of slopes and temp even with its ecu adjusting..gives you a sluggish feel...89 got better outcome..its could also be just my car.. "Dont you guys notice a whirring sound when you accelerate , try driving beside a wall" i need to know if this is normal. or a slight knockin on the engine?
I know the sound you're talking about....my old '97 Camry did the same...that sound is NOT pinging...it is just the fuel injectors doing their thing....yea, my Yaris does the same thing when I drive near a wall....again, not pinging, just valve and injector noise....no worries.
Old 08-15-2007, 02:03 PM   #209
marcus
toyota
marcus's Avatar
thanks pavel.
thanks pavel ur the first to mention the fuel injectors..atleast im not the only one that notices the noiise during acceleration..
marcus is offline
Old 08-15-2007, 02:07 PM   #210
Speedz
Will work for Yaris...
Speedz's Avatar
There isnt any noticeable difference in performance or economy when using 87 or 100... I tried all of them... nah zilch nothing...
Only thing is your money been spent... mine you in Australia Shell's 100 octane was about $1.45/L vs $1.06/L for the 91 octane...
Speedz is offline
Old 08-15-2007, 02:53 PM   #211
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
My take:
Got a cheap car? Buy cheap gas.
Use "87 or higher" (per Yaris manual).
Maintain your car diligently and drive sensibly.
aca72 is offline
Old 08-15-2007, 03:05 PM   #212
Black Yaris
der Zeck
Black Yaris's Avatar
everytime I use more premium fuel I get better fuel econimy..... the econ rating on the sticker from the factory were tested with 89 octane.... I use 89 or 91
Black Yaris is offline
Old 08-15-2007, 03:07 PM   #213
brought back from the dead again. lol...i have't used premium every since the last time this thread was resurrected.
Old 08-15-2007, 03:10 PM   #214
Black Yaris
der Zeck
I am half temped to kill it.... I think we have all repeated our selves 3 times in this thead argueing the same thing back and forth, getting nowear... everyone is going to believe what they are going to believe... and not one is going to change there minds
Old 08-15-2007, 03:17 PM   #215
yes, please kill my thread. let someone else start a war. i did it with this thread and my synthetic oil thread.
Old 08-15-2007, 03:24 PM   #216
Black Yaris
der Zeck
dead... too much bickering...
I'd like to know this right now.. is brand name gas better for my new Yaris? fantabulousbaby General Yaris / Vitz Discussion 12 09-19-2006 09:14 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
Tired of poor gas mileage & buying premium gas. Boosted Peon New YARIS Purchase Forum 29 08-25-2006 08:59 PM
poll concerning gas prices foober General Yaris / Vitz Discussion 15 07-24-2006 12:47 AM
