Old 08-11-2012, 02:42 AM   #1
bongskitamtam
bongski
Drives: yaris homeboyz
@ syntax: opo sir un nga, air intake filter?
bongskitamtam is offline   Reply With Quote
Old 08-11-2012, 08:33 AM   #2
syntax
syntax's Avatar
ang epekto ay mas marami at mas mabilis ang paghigop ng hangin that equals to mas mabilis na arangkada ( short ram intake or SRI) or mas mabilis na top end speed (rektahan kapag Cold Air Intake or CAI) ang drawback ay dapat lagi mo nililinis ang air filter mo at throttle body...other than that wala na ako maisip na magiging epekto sa makina, at hindi rin ito guaranteed na may dagdag na HP kung ito lang ang ilalagay na aftermarket parts
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
Old 08-12-2012, 03:59 AM   #3
bongskitamtam
bongski
@ kaemong: Sir nasubukan nyo po bang ibalik ung stock nyo na filter para malaman nyo kung may iilaw pa din?
Old 08-14-2012, 08:59 AM   #4
kaemong
Drives: yaris 2008
ok na sir, sa wakas natanggal din ung malfunction indicator, nagpalit ako ng vvt (140 SAR + 60 labor). ang problema ko na lang ngayon ung tunog na nanggagaling sa air compressor.
kaemong is offline   Reply With Quote
Old 08-22-2012, 05:15 PM   #5
macky
Drives: yaris
mga bro. paano ba mag palit head light bulb . dito kasi maabot masikip
macky is offline   Reply With Quote
Old 08-23-2012, 02:24 AM   #6
syntax
syntax's Avatar
@ duke pasooookkkkkk
Old 08-23-2012, 09:55 AM   #7
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
@macky, if that's the case kailangan mong tanggalin yung buong headlight(housing) para mas komportable kang maalis ang headlight bulb, pero normally nadudukot yan ng iba.
jonimac is offline   Reply With Quote
Old 08-25-2012, 12:15 PM   #8
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
bakit masikip? head light bulb yata ang pinakamadaling palitan sa lahat ng bulb, hehe.. pagnahugot mo na ung rubber sealed cap angat mo lang ang clip ng bulb matatanggal na kusa un
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 08-26-2012, 01:57 AM   #9
bongskitamtam
bongski
Mga pre konting katanungan lang about dun sa CAI nagtanung kase ako sa ghurabi nung pipe kay (Ford) kaya lng may sinasabi pa sila na may kailangan pa daw i modify para sa lagayan nung sensor parang magdadagdag ng elbow daw, panu n san ba idudugtong yun?
thanks..
Old 08-26-2012, 05:56 AM   #10
jonimac
jonimac's Avatar
thanks..
@bongskitamtam, eto yung nilalagyan ng MAF sensor. Dati kasi pinuputol namin yung STOCK, makuha lang yung mounting ng MAF, pero ngayon may nabibili ng ready made. Pumunta ka sa AL AQSA may kabayan dun ROY ang pangalan, nandun din sa kanila yung mga tube extenders kung gusto mo ng CAI. Location? ....going out from Jolibee st., intersection yun diba? Pag kaliwa mo nasa kanan mo kagad yun AL AQSA na, daming anik-anik sa oto dun. enjoy!
Old 08-26-2012, 08:36 AM   #11
bongskitamtam
bongski
@jonimac , salamat pre cge punta ko dun, sya nga pala baka pede ako maging member ng yaris dito sa riyadh naririnig n nakikita ko kc ung mga kita kits nyo dito. salamat.:)
Old 08-30-2012, 06:27 PM   #12
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Pao nice to hear you are still here, musta na tol
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 09-01-2012, 08:07 AM   #13
bongskitamtam
bongski
mga pre magandang bukang liwayway sa inyong lahat! anu bang oil ang magandang gamitin? castrol 5w/30 or bili na lng sa toyota nung mismong oil na ginagamit nila? and ilang kilometers ba bago mag palit ulit 3,000 or 5,000?
thanks.
Old 09-01-2012, 11:42 AM   #14
duke_afterdeath
thanks.
sir bong, ito yung thread for changing engine oil http://www.yarisworld.com/forums/showthread.php?t=38393
Old 09-01-2012, 02:39 PM   #15
rickyml
rickyml's Avatar
Drives: Yaris 2008
sino nkapag differential oil na dito at nagchange na ng break fluid at transmission fluid? 80k na ako e kaya required na ito. mga magkano kaya ito?
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 09-16-2012, 09:26 AM   #16
bongskitamtam
bongski
Mga sir, ung simota ba na filter ok lng ba yun kesa sa k&N? para sa SRI lng. medyo mahal kc ung k&N.
thanks
Old 09-16-2012, 11:33 AM   #17
duke_afterdeath
thanks
ok din yun sir tested na yan,, yung ibang tropa nga generic lang gamit
Old 09-22-2012, 06:24 AM   #18
rickyml
rickyml's Avatar
Drives: Yaris 2008
magkano na ngayon ang market value ng angel eye headlight para sa yaris natin? yan ang next project ko eh.
