Old 12-14-2009, 06:34 PM   #217
.4mm is .0157 inches. Mine were gapped at .028 and we brought that down to .024 when tuning on the dyno. I think your gap is very tight!
A/F on my car:
Idle: 14.1-14.7
Cruising: 13.0 - 13.5 is the range I've seen, more or less
under boost: 12.5 down to 11.7 at full boost, depends on load etc.
hope that helps.
Old 12-14-2009, 06:36 PM   #218
Also, since I am considering replacing the injectors to above 600cc, does the engine will startup up rich or lean with a fuel map tune on 340cc inj?
you'll be under 5% duty cycle at idle, so could be a little rich, might need more tuning all around. Overall though, your management should maintain correct A/F.
Old 12-14-2009, 08:51 PM   #219
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
yes when I mean "should work fine", i mean as long as your fuel management can handle the increased size. The injectors themselves will drop right in. Same denso casing as factory. Depending on your projected whp choose between the 550's and 750's. Im thinking 550's would be plenty considering you have a return set-up.
Ptuning.com
Old 12-15-2009, 01:20 PM   #220
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
A/F on my car:
Idle: 14.1-14.7
hope that helps.
What Brand are the plugs? Thus this gap difference might be related to octane difference? I am running 90 octane so sure your fuel ignites better so thats what might the gap serve for!
Thanks for that afr reading garm, I never seen 12s on either level! BTW you are sure that these readings are good for lower octane level fuel?
What do you think about the TC injectors Garm? Do you recommend these for my setup? Is there anyone using them on his motor?
Old 12-16-2009, 10:03 PM   #221
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
the tC injectors (factory) would be ok for low boost. I was not able to get past 149whp with them as they maxed out. Seeing as you have a return set up im thinking they can put out more juice.
As far as AFR ratio and octane rating, timing is what is most important to optimize power and to prevent knock/detonation. The only way to optimize timing is on the dyno though. AFR should be targeted the same regardless of octane rating.
We tuned 2 customers tC's for 400whp, one with 91 octane (what was readily availible to that customer) and one with 93 octane. AFR were the same, timing is what has to be adjusted(less timing for 91)
Ptuning.com
Old 12-16-2009, 10:36 PM   #222
Parmas
Parmas's Avatar
I don't know how much do you mean by low boost but since I built the engine it's none sense to stay low boosted!
I am projecting 16psi on a Garret T28 though!
Old 12-17-2009, 09:18 PM   #223
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
oh yea factory tC injectors would be way too small. 550's would be good
Ptuning.com
Old 12-23-2009, 12:10 AM   #224
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
Hi Parmas,
Just want to share with you that I purchased a set of 445cc customized injectors from FIC for my rebuilt next month, but I can't tell you whether they'll work great until its in.
Am already thinking they might be too small as I'm not converting to a return setup? :(
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 12-23-2009, 01:26 AM   #225
90tsi
90tsi's Avatar
Drives: 09 yaris
this may sound out there but there was an article in turbo mag a year or 2 back and it had an equation that you could use. dont quote me exactly but if i remember right you could plug in displacement,horsepower goal, and a few other factors and it would get you a good estimate of what cc injector you needed.
90tsi is offline   Reply With Quote
Old 12-23-2009, 06:48 AM   #226
Parmas
Parmas's Avatar
Originally Posted by changchewsoon View Post
Hi Parmas,
Mine are 340cc with a return setup running rich at all times @ 10psi. So the 445cc should work fine till 250BHP.
Old 12-23-2009, 02:00 PM   #227
Parmas
Parmas's Avatar
Finally we decided what injectors will suit best and we chose the Siemens Deka 4 630cc.
These injectors flow 220 lbs/hr at 43.5 PSI ( 3 BAR ) and more at higher PSI! These units are low-impedance and require peak and hold injector drivers or additional resistors for saturation drivers. Despite the high flow rate, they are linear and controllable at low pulse widths compared to other extreme flow injectors! These injectors are sometimes referred to as 212lb/hr or 225lb/hr injectors
Any has experience on these?
Old 12-27-2009, 12:48 PM   #228
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
If I remember correctly, these injectors were pretty popular with WRX guys.
Old 12-29-2009, 02:06 PM   #229
Parmas
Parmas's Avatar
Well that's good news since that increase the probability of being ones of the very best racing injectors one could own.
I hope they are efficient as advertised as these will probably be a good indeed upgrade. Bye Bye tuning probs :)
Old 01-07-2010, 02:44 PM   #230
Parmas
Parmas's Avatar
Some pictures of the rear mounting. Sorry about the blured image but the camera sucks at close ups!
Old 01-13-2010, 11:56 AM   #231
Parmas
Parmas's Avatar
UPDATES:
UPGRADED INTERCOOLER HOSES TO SAMCO RED :)
SHOWING CUSTOM BLUE WATER HOSES ASWELL
TRD CAP
Old 01-13-2010, 01:48 PM   #232
cool, very colorful -- what throttle body is that?
Old 01-13-2010, 02:41 PM   #233
Parmas
Parmas's Avatar
Stock 1NZ one
What do you think about the rear mounting I posted before garm?
Old 01-27-2010, 01:40 AM   #234
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Sexy engine! You need a pink dip stick to set it off!
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
