#217 |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
I extended my O2 sensor wires so it would reach my downpipe and I could route them away from exhaust. My downstream O2 sensor [after coverter] I just left connected and pulled through grommet hole inside on car. It is now under my carpet on the driver side. It took a long ride but my engine light came back on as well. Most likely for the downstream O2 sensor. I am hoping it is a converter efficiency code or evap. code due to boost pressure in the system.
I will go to autozone tomarrow and have them scan it. My scanner is not working on the newer cars.
#218 | |
Bathroom + Laptop = <3
#219 | |
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
pimp my yaris, lemme know what code(s) you have asap. Best case is we have similar codes... It's interesting that it took a good deal of driving for your code to come on, because it was the same with me. You'd think that if this theory is correct that the light would come on almost immediately. I need to check how the ECU tests for this and determines there's a problem... |
#220 |
Ok, I looked into all this further and realized two things. Firstly, the codes wouldn't come on immediately because it takes two drive cycles for the ECU to determine there is actually a recurring issue. Secondly, I was reading these codes as per the Yaris manual hosted online. P0101 definitely seems to be the maf signal voltage out of range (too high), as a result of boost conditions. As for P2238, the manual lists it as the O2 sensor acting up, not the barometric pressure circuit intermittent. I THINK this is a result of the car running excessively lean. Low positive current on the AF+ wire directly equates to lean conditions. I have a scangauge on the way so I'll run some diagnostics before getting tuned.
Definitely would rather see CELs after boosting than not seeing them. Otherwise the car would clearly just be baffled as to what's happening to it lol. The cool thing is that if I'm right, a tune will sort out those two CELs. MAF clamping to represent boost conditions, and the proper air/fuel ratio done by fuels map would eliminate P2238. |
#221 |
C'est la vie
P0101 is cyl. #1 missfire detected
#222 |
C'est la vie
#223 |
Mr. 155 and climbing
Drives: Seriously Modded 07 Sedan Join Date: Jun 2006
how do you have your gauges set up? Can you take a picture?
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. |
#224 |
![]() Top -> Bottom = Boost -> Narrowband -> Trans Temp Transmission temperature is currently not installed. The gauge pod is a generic one from Summit Racing, and it fits pretty eh, but it works nicely. It comes with foam to fill gaps, but I don't care enough. ![]() Here's the turbo timer I'm not using. The gauge next to it is oil pressure. To the right of it is a voltmeter. I just wanna point out that they're not really 100% setup because I'm waiting on blue LED bulbs for the backlights before I seal the gauges in place and hold the pods with screws in the dash. I have a scangauge on the way that will sit on the steering column. |
#225 |
I'm curious why you are using a narrowband?
#226 |
C'est la vie
Jerzy I finally checked my codes today at autozone. I had only one and it was PO137 bank 1 sensor 2 low voltage. I am sure its because I have no cat. and the sensor is still connected but I pulled it inside my car. Its now under the carpet on the driver side. I think I will need a electronic o2 simulatar to pass emissions. I think I will also buy a vaccume check valve to put in on my evap. line.
#227 | |
#228 |
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
Has any yaris owner expirience an explosion on their turbo?
#229 |
C'est la vie
#230 |
They sell O2 Sensor "defoulers" at any auto store, its basically a spacer that pushes the sensor away from the stream so it won't throw codes.
#231 |
Tightened most of my piping connections, checked the MAF, and finally dealt with a small exhaust leak I had. Cleared the code, drove to class, came back on the way home. There must have been a small error on my part when I installed part of the air induction system for this code to keep coming up, otherwise pimp would have it too. I'm confident my MAF sensor works properly, so... maybe a vacuum leak? What would I see on a vacuum gauge if there was a leak?
Still gotta get this thing tuned and stuff... It's like I got lazier now that schools going again
#232 |
C'est la vie
Just take it easy on the gas till U get her tuned. I can tell U with the wideband, I can tell exactly what my engine is doing and at high rpm's under boost it runs lean without tuning. Too lean! I cant wait to get my piggy back and try to learn some tuning myself. U should invest in the aem wideband. It works great and is made to work with your AEM FIC. I think the mass air sensor max's out under boost and can't properly adjust fuel supply. With the internal map sensor on the FIC we can keep adding fuel after the mass air has maxed out.
Hey jerzy: How much boost are U runing anyway? I dont think a vaccume guage will help that problem. It will only find a leak between the throttle and the engine. I would double check all connections and make sure those silicone connectors and clamps are straight and tight. If they are cocked or crooked they my not seal. Ya that sounded funny! Last edited by pimp my yaris; 09-15-2010 at 11:42 PM. |
#233 | |
#234 |
The Zage actuator is set to .5 bar. I've only really pushed the boost to 7 psi twice, for now I barely even touch 5 psi during daily driving, for the exact reason you're telling me to take it easy on the gas. I guess the next step really is to see whether or not MAF clamping sorts this trivial code out or not. I'm probably going to tell my tuner to leave the fuel maps alone where the ECU is able to properly adjust, and just focus on the mid and upper RPM range.
Oh yeah, my stupid return flange on the turbo is leaking oil... AGAIN. It's incredibly slow and hasn't really effected my oil level after two weeks of driving, but it needs to be dealt with. My big meaty hands must be over-tightening the bolts. Frustrating
| FS: Autometer Cobalt 6170 Boost Gauge | Nexus1155 | Items for Sale by private party | 2 | 02-02-2011 04:08 PM |
| Multiple cylinder misfire under boost | LtNoogie | Forced Induction Forum | 13 | 11-02-2009 04:44 AM |
| Fill up with Super before starting your boost project | LtNoogie | Forced Induction Forum | 5 | 12-01-2008 06:41 PM |
| Supercharger Selection and Limiting Boost | Nexus1155 | Forced Induction Forum | 1 | 12-01-2008 03:51 PM |
| WTB: Boost Gauges | Teruyume | Items for Sale by private party | 4 | 11-12-2006 02:42 PM |
