Old 02-04-2013, 06:59 PM   #1
Steve35
Steve35's Avatar
Drives: 2008 HB
Nope, no big wheel spin problems for me. The car was great, could it be better? Of course.
I wish you had your data logger...
Steve
Steve35 is offline   Reply With Quote
Old 02-04-2013, 07:28 PM   #2
Jason@SportsCar
Originally Posted by xnamerxx View Post
Jason quit trying to make me setup my car to be a more hateful DD experience LOL
Daily drive the Mustang.
LSD, flywheel, 13"x9" wheels, ECU, no cats.
Old 02-04-2013, 08:53 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Yes. I will be going fsp by summer. I want lsd so bad. U got a spare trans w lsd u wanna get rid of? Lol
Hell, I'm about ready to pull the trigger on LSD/gear ratios/final drive and go straight up EP. I don't plan on going national with it, and I don't AutoX to win, so being laughably un-competitive in that class is no big deal. It's just where my egg will land when I get done scrambling it.
Old 02-04-2013, 09:05 PM   #4
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
It didn't feel heavy enough to me to be solid so I'm going to hazard a guess that its hollow.
Got Z2 street tires on, I'm pretty sure there not faster than the Toyo's, but they have the best steering feel of any tire I've ever driven on, there so unbelievably sharp, definitely one of the best street tires I've ever driven on.
Old 02-04-2013, 09:26 PM   #5
NJ Drive
Drives: 2012 Yaris SE
Thanks. I'm trying to decide if it's worth forgoing the front sway bar altogether or reinstall a smaller one.
What size ZIIs did you go with? I have a pair of 225/45/16 for the front. The Star Specs were already a great tire, can't wait to see how the ZIIs run. Pretty sure by now you've heard that the 195 Toyos aren't the only size that gets the good stuff all the way down either, according to Mr. Lugod.
NJ Drive is offline   Reply With Quote
Old 02-04-2013, 09:44 PM   #6
xnamerxx
0-60 in slow
xnamerxx's Avatar
Well I kept the front bar for body roll reasons, I also didn't like the way the car felt running without it. The steering is really really numb without a front bar but you can get power down a little bit better. After running without it I found it was just better to run more spring in the back and call it a day.
Both the 50 and 55 get it afaik, but Lugod's in my region so I can ask him next event. From what I heard from Andy Hollis it was just those 2 sizes.
I went with the 225/45/16.
I don't expect any of the newcomers to overshadow the R1R's, even though I hate that tire with a passion it does work really well.
Old 02-05-2013, 12:24 AM   #7
Jason@SportsCar
Based on the OE 24.3mm spare bar I have I believe they are solid. It has no crimp marks on the ends, and based on its size it feels to heavy to be hollow. If you can find one there are 23.3mm OE bars out there, I have one on the HP car, came from an 07' sedan.
Old 02-04-2013, 09:17 PM   #8
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I will probably end up in SM class by the end of the year. I really wanna go turbo. I think I made my debut last year by coming in 2nd overall and now I just wanna have some fun. I don't wanna get Rcomps yet til I get an LSD though.
-Derrick-
Old 02-04-2013, 08:00 PM   #9
NJ Drive
Does anyone know if the stock front sway bar is solid or hollow?
Old 02-04-2013, 10:21 PM   #10
NJ Drive
One thing I've learned is that the clock trumps 'feel' any day. I remember first running my STR S2000 w/o a rear bar. It felt weird, I had to make adjustments to my driving, but ultimately was much faster w/o it than with it. I'm still kicking myself for being stubborn at Nationals in 2010 for not removing it because I didn't think it was quicker. Never again.
Old 02-04-2013, 11:44 PM   #11
xnamerxx
0-60 in slow
xnamerxx's Avatar
Well yes and no, when going over my data it always showed that I had more corner speed with a bar than without, but I had better exit speed with the bar. My setup wasn't optimized for either bar or no bar so you never really got to know for sure if bar or no bar was better. Once I figured out the spring balance it felt better and was quite a bit faster than no bar on the previous setup. I think having the extra compliance over bumps is enough to make having a front bar worth it, rather than compensating with extra stiff springs.
Just for S n G's here is data from the last event of last year.
Data from a Miata course. I suck at braking.
Old 02-05-2013, 12:21 PM   #12
NJ Drive
Initially I was planning on staggering heavier in the front w/o a bar and give it a go. My wheelbase is a little longer than yours too so behavior under braking might not be as pronounced.
Your data acquisition is nice too.
Old 02-05-2013, 01:21 PM   #13
xnamerxx
0-60 in slow
xnamerxx's Avatar
So the more I stagger rear roll stiffness the more liftoff/brake oversteer I get, there was a fine line from nice rotation to fwd drift car. Just having the rear spring stagger gave me enough front end accel traction that inside spin wasn't such a bad problem, I still complain about it but its mostly due to me getting back on it too soon when the front inside wheel has no load and is at a sharp angle.
Now I'm not positive this is true so take it as here-say but you can't transfer load dynamically from the left front to the right front by using stiffer springs can you can do so from the left front to the right rear and vice versa so taking load off the front by using stiffer rear springs seemed to be the way to go in getting some more front end bite. I still feel I need -4 camber to fix to get the Toyos happy but I haven't pursued that path yet.
Old 02-05-2013, 09:23 PM   #14
racerb
Finally ran the Yaris in STF with the local SCCA group, was the only car in class but turned fairly respectable time. Only mods so far, 23mm UR rear bar, K&N drop-in filter, and some rock hard Goodyear Eagle GT tires.
http://www.ncrscca.com/sites/default...auto-x_fin.htm
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 02-05-2013, 09:32 PM   #15
ilikerice
ilikerice's Avatar
good job racerb. imagine what it CAN do now.. lol.. was that just a "all my other cars are down right now, lets just run the yaris" event? or will we see more STF mods to the yaris and more/better results?
-Derrick-
Old 02-05-2013, 09:39 PM   #16
racerb
Planning on doing about everything possible to prep the Yaris to the maximum of STF rules. I have been also concidering a B-Spec Yaris, but with an earlier chassis, 2007-2008 model from one of the salvage car sites, really cheap that way. Here is one of the salvage sites I mentioned....
http://www.salvageworld.net/search.p...2009&x=52&y=11
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 02-06-2013, 01:30 AM   #17
yep. That's really fun with 300+ to the wheels. I've done some power slides that made my passengers wonder what the heck was happening.
Old 02-17-2013, 07:18 PM   #18
xnamerxx
0-60 in slow
xnamerxx's Avatar
Well just wanted to add my feedback for the z2's.
I ran first session on my R1R's and second session on my z2's and I was about a second faster with my larger diameter z2 vs the R1R's. Had to go into the data to figure out why, but the limit of the Toyo's and the dunlops appear to be about the same with the z2's having a slighly higher limit, what made the Dunlops so much faster was that I was able to keep the car on the limit from the entrance of the turn to the exit.
How many posts till ChinoCharles locks this thread? *MAD DOG* Off-topic / Other Cars / Everything else Discussions 9 04-14-2009 05:54 AM
Reported posts ChinoCharles Suggestions - Feedback - Questions 10 09-25-2007 07:48 AM
