Old 04-03-2011, 06:52 PM   #1
SKurj
Drives: 09 Yaris 3dr HB, BRZ
Ok would like to know which offset you would recommend... Looking at a 2008, 3 dr with Tein springs, Kosei 17x7 with 205 40 17, the rims come in 2 offsets, 38 and 42. Which would be the wiser choice?
Thanks
SKurj is offline   Reply With Quote
Old 04-03-2011, 07:00 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
Thanks
I would recommend ET42. With the drop and 205mm rubber, ET42 works best up front.
Old 04-03-2011, 09:22 PM   #3
Murtaza_murti
Drives: Toyota Belta
How much would my Belta's fuel consumption be affected by adding 185/65/R15 after the stock 165/70/R14.
Murtaza_murti is offline   Reply With Quote
Old 04-29-2011, 09:53 PM   #4
MitchReeves2967
Drives: 2010 Toyota Yaris Sedan
I don't understand what this stuff means. I'm not the most knowledgable about this stuff.
MitchReeves2967 is offline   Reply With Quote
Old 04-30-2011, 09:11 AM   #5
kimona
kimona's Avatar
What information are you looking for?
Old 04-30-2011, 01:04 PM   #6
MitchReeves2967
Like what all goes into choosing wheels?
Old 05-04-2011, 05:11 PM   #7
SKurj
Ok still trying to make up my mind....
How about 17x7.5 ET40 rear and ET45 front with 205/40/17?
With Tien springs... on a 3dr hatch
Old 05-04-2011, 05:20 PM   #8
kimona
kimona's Avatar
That should work.
Old 06-16-2011, 12:50 AM   #9
wanako
Drives: '07 Yaris LB, '87 Beretta
Here's my plan: '10 Yaris 5-door LB, Rota RB 15x7 either +35 or +40 and 195/60/15's on H&R Sport Springs. Anybody have a similar setup and have rubbed? I would prefer the +35 but +40 would ok.
Thanks.
wanako is offline   Reply With Quote
Old 06-16-2011, 05:03 AM   #10
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
you will be ok with +35 with 195/50.
Old 06-17-2011, 12:12 PM   #11
wanako
so If I wanted to keep the 60 sidewall, +40 would be better right? Why I want 195/60 is so I can have that extra 10mm of tread width but still be able to purchase long life tires. The little car isn't gonna be a racer but a daily driver. An awesome looking one.
Old 06-17-2011, 11:16 PM   #12
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
195/50 and 195/60 are the same width.
Old 06-18-2011, 01:56 AM   #13
wanako
yes, i know. I was referring to 10mm more from stock size. I see I didn't mention that sooner.
Old 06-17-2011, 12:31 PM   #14
ilikerice
ilikerice's Avatar
DEFINITLY^ I got 195/60/15 on my rota's also. +40 offset 15x7
You will PLENTY of room, and im on coilovers also reallly low
Old 06-17-2011, 10:53 PM   #15
ChitownY@Ris
ChitownY@Ris's Avatar
Drives: '07 Yaris Sedan
Please help. Will 215/45/17 tires (from a Scion Tc) fit on my rims that are currently wrapped in 205/40/17.
I want to change the tires because I currently have some no-name summer tires and I'd like to swap them for the all-season Yokohamas.
ChitownY@Ris is offline   Reply With Quote
Old 06-17-2011, 11:18 PM   #16
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Yes, the tires will fit on the wheels. Whether or not they will rub on the fenders is another question.
Old 06-17-2011, 11:37 PM   #17
ChitownY@Ris
Thanks for the help. I am not lowered, just stock. It is the daily driver, with two kids in the back, wife and I in front. Does this matter?
Old 06-19-2011, 12:22 AM   #18
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
^^My bad.
Stock height should be no problem.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
